Old Feb 21, 2009, 02:56 PM
Sillyness is offline
Find More Posts by Sillyness
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
12V power strip or bus bar
Hi all,
I am trying to run 5 chargers off my new IOTA 55Amp power supply. Right now I have an Integy 12V power strip, but the input wire gets friggen hot during charging with only 20 amps going through it.
Wondering if there is a better 12V power strip or bus-bar solution out there. I found the West Mountian Radio Rig Runners, but they are not switched outlets, which I would prefer.
Anyone have any gold nuggests out there?
Jason
Sillyness is offline Find More Posts by Sillyness
Old Feb 21, 2009, 02:59 PM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
I use 12 ga silicon super flex pigtails with APP connectors and matching APP on my chargers. Switches just add resistence ,so do fuses.
Charles
everydayflyer is online now Find More Posts by everydayflyer
Old Feb 21, 2009, 04:08 PM
Ohmic is offline
Find More Posts by Ohmic
USA
Joined Jan 2002
I use multiple Rigrunners. Since the idle current of most chargers is minimal the lack of individual switched ports doesn't bother me.
Ohmic is offline Find More Posts by Ohmic
Old Feb 21, 2009, 04:26 PM
ray foley is offline
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
hi there from Toledo
I have used the West Mountain Radio rig runner with the power poles since they became available. The lack of switch is of minimal concern to me since each output is fused to your own specifications and the power poles come apart fairly easily. I like it.
ciao -rjf
ray foley is offline Find More Posts by ray foley
Old Feb 21, 2009, 06:22 PM
ebill3 is offline
Find More Posts by ebill3
ebill3's Avatar
United States, WA, Puyallup
I also prefer power poles, but if banana jacks are your preference, check out MFJ products. Here is one - there are several others.
Bill
ebill3 is offline Find More Posts by ebill3
Old Feb 21, 2009, 08:42 PM
sketchyB is offline
Find More Posts by sketchyB
Joined Nov 2008
I had a similar situation and ended up making my own distribution strip out of a project box. I used two binding posts as the input and three more sets of them in parallel for the output. I like binding posts because I do a lot of stuff with my power supply and they let me use banana plugs or just clamp alligator clips or bare wires in them. I also added a voltmeter and ammeter so I could keep an eye on my power supply since I was using a converted chassis mount one with no readouts.
Looks sort of like below, you could add as many outputs as you needed. Just one option for you!
sketchyB is offline Find More Posts by sketchyB
Old Feb 22, 2009, 09:50 AM
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
There is one on the MFJ website I think I will go with... it has 4 sets of Power Poles, 2 sets of high-current banannas, uses 8-gauge input wire, and is good to 40 Amps.
The project would probably cost me $30-40 bones to build... the quality stuff at radio shack is expensive.
I don't really need meters.... I don't care about stressing my power supply... it's good to 55 Amps. The 40 amp fuse in the distro box will blow before I exceed the power-supply's limits. Plus, the PS has built in safeties. Additionally... all my chargers tell me the input voltage.
Thanks for all your inputs!!!
Old Feb 22, 2009, 09:53 AM
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
FWIW... here is the one I'm grabbing:
http://www.mfjenterprises.com/Produc...uctid=MFJ-1124
Even comes with extra Power Poles. Two of my chargers have banannas... I'll leave those. The other ones have alligator clips... I'll snip those off and crimp the included PPs on... too easy!!!
Old Feb 22, 2009, 10:12 AM
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
OK... here's a much better price with much cheaper shipping...
http://aero-smith.net/cart/index.php...ort=20a&page=1
Cheers!
Old Feb 22, 2009, 10:48 AM
Ohmic is offline
USA
Joined Jan 2002
Okay, but if you're trying run five charges as you indicated in your original post then some will have to have Powerpoles and some will have to have banana plugs in order to run five charges simultaneously.
I've standardized all my chargers on Powerpoles so I can plug any charger into any Rigrunner I have. No worries about mis-matched connectors or adapter cords.
Old Feb 22, 2009, 11:52 AM
Sillyness's Avatar
Little Rock, AR
Joined Apr 2004
I thought the variety would be nice... it keeps me from having to change some plugs, and it allows friends with both types of charger leads to use my strip at mass events. The bannana jacks will allow those with alligator clips to use my setup too. I can actually fit 4 chargers on the 2 sets of bannana jacks... 2 bannanas and 2 clips.
I'll have 2 of my chargers with bannanas and the rest on PP, so no issues for me.
Old Feb 22, 2009, 12:44 PM
gwh is offline
gwh
Find More Posts by gwh
gwh
Fort Worth, Texas
Joined Dec 1996
These make mounting APPs easy. There are several sizes to hold from 4 to 10 APP housings.
https://www.alliedelec.com/Search/Pr...88&DESC=1470G4
https://www.alliedelec.com/Catalog/pf.aspx?FN=218.pdf
gwh is offline Find More Posts by gwh
For Sale Power supplies for sale 12v/8, 9, or 15 amp Tennwalker Aircraft - Electric - Batteries & Chargers (FS/W) 3 Feb 27, 2008 03:38 PM
the 12V Power supply for charger ..Hobbico or Astro? GTOVR4 Electric Heli Talk 2 May 27, 2004 10:16 PM
How can you use a 12V Power Supply from PC Rocken Parkflyers 4 Sep 09, 2001 02:02 AM
12v Power Supply CheeseWing Electric Plane Talk 0 Sep 06, 2001 05:36 PM
battery charger as 12v power supply sandman Power Systems 6 May 09, 2001 03:15 AM
