Old Feb 20, 2009, 05:52 PM
turnbui is offline
Find More Posts by turnbui
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
Tx stolen.4in1 from Twister CP V2 hacked but ELE servo goes wrong way on throttle-up?
http://www.rcgroups.com/forums/showthread.php?t=945019
http://www.rcgroups.com/forums/showp...postcount=8274
The above 2 posts talk about a fixed pitch 4in1 hack to replace the Rx part.
I have attempted to do this hack to use a Rx Tx pair from a busted King 2 heli which is also a 120 deg CCPM heli. However, when I throttle-up the front servo [ELE I believe] goes the wrong way. I tried to reverse this channel on the front of the Tx but it didn't work.
Is there a way to make it work properly? The Tx is not programmable.
Any help appreciated.
Would REVersing servo on Tx and mounting ELE servo upside down work?
turnbui is offline Find More Posts by turnbui
Old Feb 22, 2009, 05:55 AM
turnbui is offline
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
It didn't!
Old Feb 22, 2009, 08:58 AM
jppizhere is offline
Find More Posts by jppizhere
Sanford, NC
Joined Apr 2007
You can rewire the srevo pretty easily to run the other direction, or if it is anything other than a hitec servo switch to a hitec (they run backwards).
jppizhere is offline Find More Posts by jppizhere
Old Feb 22, 2009, 06:15 PM
turnbui is offline
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
jppizhere: Thanks. The servo works properly when the Mode 2 right stick is pushed/pulled just not when throttle is applied. I've tried both the E-sky xtals and the orig Twisters xtals but both cause the throttle to operate the front servo the wrong way. I've read some posts but none refer to this particular problem. They mention CCPM and negative/positive shift. I guess I've got to somehow hack the throttle electronics in the Tx but this is beyond my capabilities.
Old Feb 22, 2009, 08:42 PM
Martyn McKinney is offline
Find More Posts by Martyn McKinney
Toronto Canada
Joined Dec 2002
The crystals have nothing to do with servo rotation.
Negative and positive shift have nothing to do with servo rotation.
I am surprised that flipping the servo upside down and reversing the transmitter switch did not work.
Flipping the servo upside down would keep the rotation direction the same.
This means that if the arm is not changed, the swash will now move in the correct direction with throttle.
Reversing the elevator transmitter switch should then correct the now reversed elevator which I don't believe affects the CCPM mixing.
Martyn McKinney is offline Find More Posts by Martyn McKinney
Old Feb 23, 2009, 05:13 AM
daybyter is offline
Find More Posts by daybyter
Bundesrepublik Deutschland, Rheinland-Pfalz, Kaiserslautern
Joined Apr 2007
Is it actually the servo? Does pitch work correct und just elevator in the wrong direction? If so, it's a problem in the swashplate mixing and not the servo...
daybyter is offline Find More Posts by daybyter
Old Feb 23, 2009, 01:26 PM
turnbui is offline
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
Martyn McKinney: Thanks for your input. As far as the right stick [made 2] is concerned mounting the front servo upside down , REVersing ELE on the TX and using a longer conection to the swash did work fine. However, the same problem was experienced when the throttle was applied, ie. the ELE servo didn't move in the same direction as the AIL and pitch servos. On the Twister the servos move down pulling the back of the main blades down to increase pitch so the heli lifts off. This is the opposite on my King 2 where the front of the main bldes are pushed up by the servos when throttle is applied. Is this what negative & positive shift refer to?
I guess that somehow I need to get at the electronics in the Tx to operate the ELE servo the opposite way when throttle is applied leaving the functioning of the rest as is.
daybyter: Thanks. Yes AIL and pitch servos work fine, it's just the front [ELE I believe] servo working opposite to the other 2 servos but only when throttle is applied.
Old Feb 23, 2009, 02:33 PM
Toronto Canada
Joined Dec 2002
What happens if you turn the servo upside down, rotate the arm 180 degrees and don't flip the elevator switch on the transmitter?
This should correct the swash problem but leave the elevator (right stick) untouched.
One of these combinations has to work!
Old Feb 24, 2009, 06:21 AM
turnbui is offline
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
Martyn McKinney: Thanks for responding Martyn. I think you might have found the problem. I was forced to rotate the arm 180 deg when I installed the servo upside down otherwise the link would have been at an impossible angle. I had hoped to be able to mount the servo without rotating the arm but there was not enough room on the otherside of the main shaft housing. I will try it out tonight pretending to mount it the other side of the main shaft and report back just for future info and my peace of mind.
Nice one.
Old Feb 24, 2009, 11:45 AM
turnbui is offline
turnbui's Avatar
W. Sussex U.K.
Joined Sep 2007
The only way [unless I'm missing something obvious] is to mount the regular servo on the opposite side of the main shaft, not change the arm and not REV the servo on the Tx!?! But this is not possible as there is not enough room. Even if there was enough room the arm is no longer perpendicular to the swash connecting rod which would mess up the CCPM synchro?? How frustrating. I have never used a servo that runs the opposite way so perhaps there is a way to do it with one of these - a Hitec?
Discussion Twister CP V2 with 4in1 can main motor be changed to brushless? turnbui Micro Helis 3 Feb 19, 2009 10:41 AM
Discussion Cyclic = servos OK. Twister CP V2 apply throttle, swash goes down not up? turnbui Micro Helis 14 Nov 12, 2008 07:12 AM
Discussion Twister CP V2 - which channels for which servo into 4in1 pls? turnbui Micro Helis 2 Aug 14, 2008 02:47 PM
Help! Twister CP V2 tail motor jossUK Micro Helis 1 Feb 19, 2006 01:12 PM
Discussion Perkins Twister CP V2 --- your appraisal please peter frostick Micro Helis 0 Jan 12, 2006 10:38 AM
