Old Feb 16, 2009, 05:48 PM
GreenAce92 is offline
Find More Posts by GreenAce92
Physics hate's my ideas
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Building a similar Minimoa kinda glider(scratch)
This is a scratchbuild, aside from the plane, im mainly concerned about launching, ive been trying DLG's but ive only gotten maybe 60ft max of height throw just because my planes are weak so i was wussy throwing them. Anyways... how high do you think a pole will take me? like a pole and some line, ill just drag the plane over my head... thinking a 40in span mini Minimoa... AUW around 10-12oz... R/E model, or maybe i could make one of those crossbow launchers or an over shoulder launcher like a missle launcher lol bottom line is i have no winch start, or bungee chords... so im just going to use string and something... ill figure it out, how strong do these gliders need to be?
GreenAce92 is offline Find More Posts by GreenAce92
Old Feb 16, 2009, 05:55 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Just an idea.... what if i took a rope, slung it over a branch, and attached on one end a really big rock, then i would pull that back, and attach my plane(i know a rigging system already that will release) ill hold the line taught till im ready to release then when i release, the rock will go down taking my plane up.... it wont go into the trees because it'll reach a fast enough speed... but that sounds kinda dumb... got a quick stupid stick figure pic comin up
Old Feb 16, 2009, 06:58 PM
FrogChief is offline
Find More Posts by FrogChief
Russian Federation, Sakha, Yakutsk
Joined May 2006
Wow...umm...
You'd have a MUCH easier time going with an upstart:
http://www3.towerhobbies.com/cgi-bin...&I=LXE638&P=ML
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
Old Feb 16, 2009, 07:09 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
yeah probably im broke at the moment soo...
i dont know...
thanks for the tip im not being dumb/ignorant im just poor at the moment lol
Old Feb 16, 2009, 07:32 PM
Joined May 2006
i dont know...
Well...being poor shouldn't stop you. Hell...I'm poor right now...
Go to a medical supply store and buy about 15-20 feet of surgical tubing. Should only cost a few bucks.
Then use some heavy twine or better yet 30 lb fishing line. Tie a streamer to the keychain ring on the end and you have an upstart on the cheap!
Use some sort of tent stake on the rubber end for ground attachment.
-Sean
Old Feb 16, 2009, 08:03 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Yeah sounds good ill see what i can do... thanks!
Old Feb 16, 2009, 08:08 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
I've heard of large rubber bands being looped together to make a low powered bungee. And there is always towline, where one runs with the glider on a long line. Still used with 2 runners in competition soaring.
DT56 is offline Find More Posts by DT56
Old Feb 16, 2009, 08:33 PM
glidermang is offline
Find More Posts by glidermang
Ace:
What Sean said!
You need about 20 feet of surgical tubing, and 100 feet of twine (engineering or surveying twine works good, from the DIY store, and you can get it in orange). A key ring at each end and a streamer just below the ring at the string end (keeps it from tangling on the way down). Anyway, the usual proportion is 1/5 tubing or rubber, 4/5 twine.
Several of us shared a hi-start in Las Vegas, and we measured the tension one day with a spring scale. Maximum tension was about 10 pounds. That hi-start was the Real Deal: about 600 feet total, and the tubing was probably 3/8 inch. We could launch ANYTHING, and typical launch height was 500-600 feet, depending on wind.
For your airplanes, you don't need heavy tubing, maybe 3/16 diameter. Use a BIG tent peg or nail at the ground end.
On your airplane, mount a tow hook about a 1/4 inch ahead of the CG. A simple L-shape is fine. Use a bolt with a nut inside, and a piece of plywood to spread the load.
Ring in the hook, pull it back and let go. The airplane will do the rest. Try to release the airplane LEVEL. It will rotate up and go up on the circumference of the circle with the twine as the radius,all by itself. If you do need to steer it, the rudder will do that fine.
At the top, nose down and let the airplane simply fly off the hook.
You should get every inch of line and tubing in vertical launch. As you get experienced, you will figure out how to "zoom" off the launch for additional height.
I was using my hi-start today. Wonderful, stress-free, cheap, only one moving part.
Build strong. The hook will have to hold the full line tension, whatever it is.
Yours, Greg
glidermang is offline Find More Posts by glidermang
Old Feb 16, 2009, 11:09 PM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Cool! thanks! yeah i really like the looks of some of those gliders great stuff! ill have to see about getting surgical tube stuff then. 600feet! man!! that is awesome!!! lol definitely can find thermals there!
Old Feb 17, 2009, 05:40 AM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
Upstart - $29 - 100-200 foot launches
http://www3.towerhobbies.com/cgi-bin...&I=LXE637&P=ML
hi-start- $60 300-500 foot launch
http://www3.towerhobbies.com/cgi-bin...?&I=LXE635&P=7
e-bay latex tubing -50 feet -make sure it is one continous piece.
http://cgi.ebay.com/Natural-Rubber-L...3A1%7C294%3A50
Learning to use a hi-start
http://forums.flyesl.com/topic.asp?TOPIC_ID=216
http://www.rcgroups.com/forums/showthread.php?t=155353
aeajr is offline Find More Posts by aeajr
Old Feb 17, 2009, 10:30 AM
GreenAce92's Avatar
USA, NY, Dunkirk
Joined May 2007
Im workin on getting surgical tube, i dont mind DLG Gliders in fact they are my favorite type of glider, but i cant fiberglass right now.. so im just going to build some look alike gliders...
thanks for the tips/info/help guys
i appreciate it
Scratch Building My Own Bird Dog Rogerdoger Parkflyers 78 Feb 03, 2004 12:47 PM
thinking of building my own newtonian telescope logan5 Life, The Universe, and Politics 23 Aug 29, 2003 09:55 PM
Going to start building my hornet adam_jorgensen Electric Heli Talk 1 Apr 16, 2002 07:37 PM
Going to be flying my Soarstar a lot less... GLOW WON! f2racer Electric Plane Talk 17 Oct 30, 2001 09:34 AM
Building my own NIMH packs? JayParke Power Systems 5 Oct 17, 2001 09:18 PM
