Old Jan 14, 2011, 04:05 PM
FISHER711 is offline
Find More Posts by FISHER711
Chuck Norris can drown a fish.
FISHER711's Avatar
United States, CA, Loyalton
Joined Dec 2003
Wait for it...
FISHER711 is offline Find More Posts by FISHER711
Old Mar 08, 2011, 05:06 AM
overedline is offline
Find More Posts by overedline
overedline's Avatar
Chino Hills, CA
Joined Dec 2006
Originally Posted by hallstudio View Post
you need a nicd or nimh charger and do a slow charge .3C untill you hit 3.25 volts per cell then charge with the ballance charger.
Can I do this with one of those AA nimh chargers from wal-mart? I have one that charges 4 AA batteries in about 8 hours. I am thinking I can wire it up so I can get it to charge a 3.7 volt lipo. I would connect three AA (1.5v) positive terminals in parallel and three negative terminals in parallel and that would be like charging a 4.5v battery. The fully charged state of the lipo is 4.2v.
Will this work?
overedline is offline Find More Posts by overedline
Old Mar 08, 2011, 05:30 AM
lipoflyer is offline
Find More Posts by lipoflyer
lipoflyer's Avatar
Australia
Joined Nov 2010
Will this work?
NO!
You need to use a charger where you can get a read out of the voltage and miliamps being delivered to the pack. Don't cut corners here as the results will not be pretty. Do ant charging outside away from combustable items just incase. As an example of what I mean, go to hobbyking.com and search for an accucel 6 charger. You will see they have an LCD screen so you can see what's going on etc.
Above all, be careful.
lipoflyer is offline Find More Posts by lipoflyer
Old Mar 08, 2011, 05:43 AM
overedline's Avatar
Chino Hills, CA
Joined Dec 2006
Originally Posted by lipoflyer View Post
NO!
Ok thanks. I will probably just buy a new lipo.
Old May 30, 2011, 03:40 PM
Bill0 is offline
Find More Posts by Bill0
Bill0's Avatar
United States, CA, Oceanside
Joined Aug 2010
I have a 2s 3300mah 7.4 battery bought new. I installed a deans plug, got the connections right, plugged it into a accucel 6 charger and all it will give me is a low cell voltage message. Can't get it to take a charge.
Any ideas on how to get it back, or is it dead.
Bill0 is offline Find More Posts by Bill0
Old May 30, 2011, 07:15 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Read this Sticky
First rule of Lipo's - After receipt of a pack and before doing anything with the pack, check the individual cell voltages. If they aren't 3.85+/-, contact the vendor as something is wrong with the pack.
hoppy is offline Find More Posts by hoppy
Old Aug 06, 2011, 09:03 PM
CooCoo is offline
Find More Posts by CooCoo
Joined Aug 2011
1500mah or 3000mah
hello im new to this stuff and clearly a rookie
my question is ...if i have a system running off a 3cell li-lion 1500mah
can i use a 3 cell 3000mah lipo without burning it up
CooCoo is offline Find More Posts by CooCoo
Old Aug 06, 2011, 09:46 PM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Most likely, yes.
Tell me how much current you are drawing or how long your plane flies on a charge.
Old Aug 06, 2011, 10:16 PM
CooCoo is offline
Joined Aug 2011
well its a helicopter running on 3s 1500mah li-lion
i dont know how much currant as i have no tester for that as of yet
and it flies for about 10-12mins i just dont want to burn out the esc as i dont know how big it is
Old Aug 07, 2011, 06:23 AM
hoppy is offline
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
If it flies for that long you should be OK with a larger pack.
Will the heli handle the extra weight?
You don't have to worry about the ESC, the amp draw in most cases will not change to any major degree by going to a larger pack. If it was a non-flying machine you could go to a 15000mah pack with out a problem.
Old Mar 15, 2012, 05:55 PM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
for those who dont have a NiCad or other appropriate means to 'jump charge' a Lipo up to 3v per cell, one can use wall wart chargers IF the ratings are appropriate. For example, I have a Futaba 12FG which uses a 7.2v pack. The charger delivers approx. 9.5 v peak with a rating of 8.45v @170 ma. Perfect for 3 cell packs from 300mah up. A few jumper wires and you're in business....also it seems the sooner you take care of over discharged batteries, the better the result, so dont wait.
crossup is offline Find More Posts by crossup
Old Apr 02, 2012, 11:40 AM
AsSoulsDream is offline
Find More Posts by AsSoulsDream
AsSoulsDream's Avatar
United States, FL, Ocala
Joined Sep 2011
I have a 3s 2500mah lipo i use for my tx so it does't have the big deans size connector and I left my tx on and it wont even register on my lipo voltage checker..
plz help me recover it
AsSoulsDream is offline Find More Posts by AsSoulsDream
Old Apr 02, 2012, 02:54 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Please be advised that is why there is this Sticky Thread which stays near the top of this Forum.
"My battery is dead - HELP" info.
http://www.rcgroups.com/forums/showthread.php?t=1074181
Charles
Old Apr 09, 2012, 02:07 PM
bionicbone is online now
Find More Posts by bionicbone
Whoops was it always in 2 bits
bionicbone's Avatar
United Kingdom, England, Rotherham
Joined Oct 2008
I tried this on what appeared to be a totally dead cell and it seemed to work in the fact that I managed to get it to start charging as a LiPo (single cell down the balance lead) and take it all the way to 4.2 volts putting in 4260mAh into the 5000mAh cell over the next 4 hours. However, almost instantly as the charging stopped it fell back to 3.6 volts.
Is it worth cycling this cell back down to 3.3 volts or am I flogging a dead horse?
Cheers
Kev
bionicbone is online now Find More Posts by bionicbone
Old Apr 09, 2012, 02:14 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
THAT horse is one that can catch fire. HUGE internal short. Discharge 100%, solder discharge leads together and toss in garbage.
Rick
rampman is online now Find More Posts by rampman
How to charge 1500mAh lipo lazerin Batteries and Chargers 3 Jun 09, 2015 10:25 AM
Discussion How do you charge a dead lipo sdclark Batteries and Chargers 12 Oct 19, 2007 04:50 PM
Discussion lipo how to charge chainick Batteries and Chargers 3 Jan 13, 2007 12:26 AM
Question how to charge multiple Lipo packs? hul Batteries and Chargers 11 Aug 21, 2006 09:41 AM
How too charge lipo's? jijohans Batteries and Chargers 2 Sep 15, 2005 01:11 PM
