Old Feb 16, 2009, 01:55 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
Question
Elmer's Yellow Wood Glue Drying Time?
I decided to build with Elmer's yellow wood glue and I was wondering how long it takes to dry before I can remove what I'm working on from the building board. The instructions say over night but so does the Elmer's white glue instructions for full strength but Elmer's white glue actually bonds in 30 minutes.
Kev
kevin matthews is offline Find More Posts by kevin matthews
Old Feb 16, 2009, 04:39 PM
kpriddle is offline
Find More Posts by kpriddle
Slow 'n Steady...Grease 'r In
kpriddle's Avatar
Maine
Joined Oct 2008
I build with this too and it takes the same amount of time as with Titebond(Titebond and this type of Elmers are exactly that same except for the smell ). I hope that you have built with this before! I can't answer you directly, though, because I'm not really sure what you are working on. Sorry!
Can someone else help?
KP
kpriddle is offline Find More Posts by kpriddle
Old Feb 16, 2009, 07:37 PM
schrederman is offline
Find More Posts by schrederman
Hot Dawg Glider Pilot
schrederman's Avatar
United States, TX, Weatherford
Joined Nov 2002
It depends on where you live. In Clovis, where avg. humidity is about 12%, I leave it for a 3 or 4 hours. In Houston, I left it for 24 hours before disturbing.
JW
schrederman is offline Find More Posts by schrederman
Old Feb 16, 2009, 08:01 PM
kpriddle is offline
kpriddle's Avatar
Maine
Joined Oct 2008
That's a good point. I would say, though, that the room humidity is more of an issue than where you live.
KP
Old Feb 16, 2009, 09:19 PM
carbondale il
Joined Jan 2007
Thanks, I took a chance on 30 minutes and no problems.
Kev
Old Feb 16, 2009, 10:02 PM
Joined Nov 2002
Since I have always built in the garage... The humidity's what it is...
JW
Old Feb 17, 2009, 12:53 AM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
I usually use Titebond. It seems to set solid within an hour but the way and rate I build I just leave stuff overnight. Sometimes I'll take stuff off the board after a couple of hours and haven't had a problem.
Ian Easton is offline Find More Posts by Ian Easton
Old Feb 17, 2009, 06:52 AM
carbondale il
Joined Jan 2007
I know I should wait for at least an hour in the future. Actually I should wait for four hours, I don't recommend removing after only 30 minutes.
Kev
Old Feb 17, 2009, 10:10 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
It depends on the fit. I know that in conventional woodworking with tight joints and heavy clamping, you can safely take your work apart before an hour has passed. Maybe even by 20 minutes or so. I suspect it's quite a bit longer if the joint is not tight, even with balsa.
lincoln is offline Find More Posts by lincoln
Old Feb 17, 2009, 11:32 AM
TLyttle is offline
Find More Posts by TLyttle
TLyttle's Avatar
Keremeos, BC Canada
Joined Mar 2004
I'm with Ian on this; who's in a rush? Overnight is insurance.
TLyttle is offline Find More Posts by TLyttle
Elmer's Ultimate Glue mrichley Foamies (Kits) 15 Jun 30, 2006 04:40 PM
Elmer's glue and packing tape finishing? JMBRAD GWS (Grand Wing Servo) 1 Dec 09, 2004 10:18 AM
Question Elmer's "Ultimate Glue"? 54newgate Foamies (Kits) 6 Feb 23, 2004 04:09 PM
MP Jet pinion glue drying time? astroboy Power Systems 1 Apr 08, 2003 05:09 PM
