Old Mar 09, 2010, 10:14 AM
mikebergy is offline
Find More Posts by mikebergy
I Love My Ember!
Arroyo Grande, CA
Joined Jun 2008
Originally Posted by Tommygunn View Post
Just received a new bunch of motors from HobbyKing and they have cherry red tops and smooth cans.
Tom.
I wish they would do that with the dt750...
mikebergy is offline Find More Posts by mikebergy
Old Mar 09, 2010, 11:33 AM
Coil is offline
Find More Posts by Coil
Coil's Avatar
Slovenia
Joined Mar 2008
They changed just the cans. Can you look if they have thinner stator laminates?
Coil is offline Find More Posts by Coil
Old Mar 11, 2010, 01:33 AM
manuel v is offline
Find More Posts by manuel v
manuel v's Avatar
Mexico, BC, Mexicali
Joined Aug 2004
Using only the drive calc program and 200 watts of input power get the rpm and efficiency of various motors off 55-58 grams.
With GWS 10x6
Manuel V.
manuel v is offline Find More Posts by manuel v
Old Mar 11, 2010, 01:42 AM
Tommygunn is offline
Find More Posts by Tommygunn
My name is Tom
Tommygunn's Avatar
Italy, Emilia-Romagna, Misano Adriatico
Joined Aug 2009
Sukalo,
I've just compared the old to the new motors and there is no difference between the stator laminates.
Only change is the can.
Tom.
Tommygunn is offline Find More Posts by Tommygunn
Old Mar 11, 2010, 03:04 AM
Truglodite is offline
Find More Posts by Truglodite
Registered Aircraft Offender
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
I got a red can on my last order too. Better get 'em while they're hot Dave.
Kev
PS: I have a very special project brewing up at the moment, and it's getting a rewound 2213n. The only hint I'm giving is... it can be flown when everything else is grounded.
Truglodite is offline Find More Posts by Truglodite
Old Mar 11, 2010, 08:37 AM
timocharis is offline
Find More Posts by timocharis
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
That's a very interesting chart Manuel. I would not have expected some of those motors to hold up as well as they did. The GWS, however, does not surprise me by coming in last!
Dave
timocharis is offline Find More Posts by timocharis
Old Mar 11, 2010, 09:08 AM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Tommygunn - thanks
Can someone please measure the distance between two mounting screws on 2213.
Old Mar 11, 2010, 09:16 AM
My name is Tom
Tommygunn's Avatar
Joined Aug 2009
The hole distance CtoC is 23mm.
Hole diameter is 1.85mm or just over.
Wall thickness to outer edge of mount is 1mm.
Mount diameter is a smidge under 27mm.
Tom.
If your interested here's how I mount my motors on my Quad. Holes in the boom arms are 19mm apart and the washers are 4mm but are kept snugly in place by the bracing effect of the bolt and the back wall of the mount.
I did try drilling the mounting holes out to 3mm but there simply isn't enough material for my satisfaction or the application.
Old Mar 11, 2010, 09:42 AM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Thanks, now i have all the data for drilling aluminium square tubing. The motors are one the way from HK.
Old Mar 11, 2010, 11:56 PM
manuel v is offline
manuel v's Avatar
Joined Aug 2004
Dave
I for goted the proppeler.
GWS 10x6.
Old Mar 17, 2010, 11:10 AM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
My 2213 7X0.65Y... I will add graph from DriveCalc later.
APC 10x4.7 - 11,02V - 7165rpm - 14,9A DriveCalc 73,4%eff
Old Mar 17, 2010, 12:02 PM
Dave North
timocharis's Avatar
USA, CA, San Jose
Joined Apr 2004
I think that's a pretty good match to 22 awg, for the metric challenged who might be checking in ... looking good!
Dave
Old Mar 17, 2010, 08:54 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
Nice motor Sukalo. I'm working on a 14T-24awg parallel Y, which should be similar. Not much hobby time lately, so might get to testing tomorrow if I'm lucky.
Not often a stator allows 13T on 2 layers. I actually started the wind planning on 12T--24a-D, but was surprised when I found 13T neatly fit in the first 2-layers. I checked the spreadsheet, then found Manuel's 7T-Y data, and decided to just go with it. I wanted to take full advantage of the roomy stator.
Kev
Old Mar 18, 2010, 01:42 PM
Coil is offline
Coil's Avatar
Slovenia
Joined Mar 2008
Thanks I have rewinded 12X0,5D and the eff. is better. So this is my final motor for MK.
Old Mar 18, 2010, 10:12 PM
Truglodite's Avatar
Carmichael, CA
Joined Feb 2007
AX2213n 7Tx2-24a-Y
Finally had a few minutes to test before this goes on my latest project:
AX2213n 7Tx2-24a-Y
Flightpower Evolite v2 3s1345
22.5C/29m
Rm = 0.0859ohm
NoLoad
9576RPM/11.25V/0.711A
->Kv = 851RPM/V
APC 10x4.7sf
7351RPM/11.08V/15.23A/34.8oz/80.4%
GWS 1060hd
7276RPM/10.15V/10.07A/23.4oz/86.0%
GWS 9050hd
7792RPM/10.38V/7.65A/20.0oz/79.7%
Oz and % from Badcock. Not bad, not bad at all. I'll be using this with a 10x4.7sf on a 3DHS Spider I'm setting up for night flying. Almost done, and the AUW looks to be around 15oz, depending on battery choice. Could use a much smaller pack, but CG prolly won't allow it.
Two New Brushed Motors & Props xwingnut Non R/C Items (FS/W) 2 Sep 19, 2007 01:54 PM
Sold FP stuff LG,Training Gear,two new tail motors and 3 MINI dragonfly canopys,head link littlepiston Aircraft - Electric - Helis (FS/W) 3 Jul 16, 2005 10:06 PM
Two NEW AXI motors for sale, 2208/34 & a 2208/26 rickc Aircraft - Electric - Helis (FS/W) 0 Jun 01, 2004 12:25 PM
Anyone looking for a New A-10 or two New DMC-20BB upgraded motors for the EDF-50 unit KZZ Electric Ducted Fan Jet Talk 3 May 17, 2003 08:23 PM
Two New GWS EPS DX370 motors. One 9:1 gear, one 5.33:1 gear F.S. Gerald Aircraft - Electric - Airplanes (FS/W) 1 Nov 16, 2002 09:48 AM
