Old Feb 16, 2009, 12:21 AM
steve wenban is online now
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Build Log
F8F2 Bearcat
Ok you PSS guru's I pulled out my old Ziroli Bearcat plans out and started tuning it into a sloper . So here's my Question the section at the root is about 3.0 " thick , I'm going to stretch it to 90" from the original 86" But changing the section to Rg14 . So do I thin it out or what ??? the old section is just so chunky . the fuse is coming along just fine and i think I'm aiming at around 15 kgs AUW but have to wait and see on that one ,Anyway your views would be greatly appreciated.
SteveW
vid for reference
The F8F-2 grumman Bearcat Maiden (4 min 3 sec)
steve wenban is online now Find More Posts by steve wenban
Last edited by steve wenban; Jun 26, 2012 at 02:34 AM. Reason: put it into correct category
Old Feb 16, 2009, 01:39 AM
r/c junkie is offline
Find More Posts by r/c junkie
TEAM OZSKUNKWORX
r/c junkie's Avatar
KORUMBURRA IN THE BOONDOCS
Joined Jan 2006
Very good Steve looking forward to seeing the progress of this beauty.
Shane
r/c junkie is offline Find More Posts by r/c junkie
Old Feb 16, 2009, 02:25 AM
Joined Dec 2003
Thanks Shane ,
I would like to get some Idea's on the wing thickness though cutting a 3.0"thick wing sort is against thegrain for me these days lol.
SteveW
Old Feb 16, 2009, 02:37 AM
salisbug is offline
Find More Posts by salisbug
I failed linkage geometry
salisbug's Avatar
Melbourne, Australia
Joined Jun 2002
Looking good Steve. That's a novel building method. I've not seen it before.
As for the RG14. How thick will it be at the root? A warbird looks rediculous with a really thin section IMO.
salisbug is offline Find More Posts by salisbug
Old Feb 16, 2009, 10:15 AM
rcairnut is offline
Find More Posts by rcairnut
"Still Crashing since 1960"
rcairnut's Avatar
Pierre, SD, USA
Joined Dec 2001
SteveW
This looks like a very interesting project,
Are you locked into the RG14?
I would go for a thicker foil also maybe an MH32? It is a good all rounder and will not need epic lift. Or an AG-40 could be nice looking and a touch faster. As you know there is a LOT of options.
my $0.02
nut
rcairnut is offline Find More Posts by rcairnut
Old Feb 16, 2009, 10:39 AM
nauga is offline
Find More Posts by nauga
Embrace the suck
nauga's Avatar
Joined Nov 2004
Love the frame-up. Are you going to strip plank it or is this a plug or...?
Nauga,
with his own ironworks
nauga is offline Find More Posts by nauga
Old Feb 16, 2009, 10:54 AM
BillO is offline
Find More Posts by BillO
Firecracker!
BillO's Avatar
San Francisco & Santa Cruz
I'm no expert, but Nauga builds chunky jets with a regular slope 7% RG14 foil and about a 20-25 oz/sq ft wing loading. He seems to like the results, but then he flies them at Fermin...
Check out http://www.rcgroups.com/forums/showp...8&postcount=17 and there are several others too.
BillO is offline Find More Posts by BillO
Old Feb 16, 2009, 11:43 AM
Joined Dec 2003
wing thickness Glenn Probably stay with the big chunky 3.0" section however I do like the MH32 that Nut suggested . The method of build I'm making up as I go along lol , of course there will be some stiffeners and load speaders installed around high stress area's,such as wing saddle and tail mounting . and a few ligthening hole through the keel . Nauga nope this is a one off no plug , I'd love to get my hands on some 10 litho plate and sheet it ala fullsize complete with rivets failing that it will be covered in 0.020" cardboard and resin coated once again sheeting as per full size that way I get the Panel lines without a marking pen .
SteveW carver of block foam
P.S if GWS can do it so can I
Old Feb 16, 2009, 12:07 PM
Joined Dec 2003
have to get hold of Ziroli and order a Canopy to.
SteveW
Old Feb 16, 2009, 12:28 PM
Joined Dec 2003
More thinking out loud , i was considering making the centre section fixed and have detachable outer panels that way i could do a built up centre section which would be a hell of a lotl lighter than 3 inches X24 inch chord block of foam .
SteveW
Old Feb 16, 2009, 12:35 PM
Geode is offline
Find More Posts by Geode
Geode's Avatar
San Jose, CA
Joined Jan 2007
That's a creative way to make the fuselage. Thanks for sharing.
Geode is offline Find More Posts by Geode
Old Feb 16, 2009, 02:19 PM
Joined Dec 2003
Thanks ,
I cant take credit for the form of building My late mentor Lloyd Dipple was the one that gave my the inspiration to use this method many years back he built a JU W33 Junkers on floats had a 16 foot span and a 125cc lawnmower motor in it , built for the flying shots of a mini series called Flight into hell same technique he used Ive kept in the back of my mind for along time . Yes its really a quick method of model building need to be for the movie business . And the more I think about it the more I like the Idea of a built up centre section for the wing the outer panels will be foam core card board sheeted and resin coated as well . All I can say at the moment is that its taken over my entire work bench and after shaping I walk out of the workshop looking like I just walked through a blizzard .
SteveW working with snow shoes on
Old Feb 16, 2009, 02:32 PM
rcairnut is offline
rcairnut's Avatar
Pierre, SD, USA
Joined Dec 2001
Originally Posted by steve wenban
Thanks ,
I cant take credit for the form of building My late mentor Lloyd Dipple was the one that gave my the inspiration to use this method many years back he built a Ju32 Junkers on floats had a 16 foot span and a 125cc lawnmower motor in it , built for the flying shots of a mini series called Flight into hell same technique he used Ive kept in the back of my mind for along time . Yes its really a quick method of model building need to be for the movie business . And the more I think about it the more I like the Idea of a built up centre section for the wing the outer panels will be foam core card board sheeted and resin coated as well . All I can say at the moment is that its taken over my entire work bench and after shaping I walk out of the workshop looking like I just walked through a blizzard .
This method is not new but with foam it is, the slab and formers method was used in the dark ages of control line models and maybe before that, but this brings it right up to date.
Is the foam EPP, high density or beer cooler
nut
Old Feb 16, 2009, 02:39 PM
Joined Dec 2003
Its actually HD EPS similar to blue foam consistancy but not quite as dense, its really only there to hold a shape the monocoupe contruction is really the key to locking it all together as a solid unit.
SteveW who came from those dark ages of which you speak
Old Feb 16, 2009, 02:55 PM
Joined Dec 2003
hmmmm now there's a thought I'm sanding it round
SteveW
