This thread is privately moderated by 13Flatspins, who may elect to delete unwanted replies.
Old Feb 15, 2009, 11:24 AM
13Flatspins is offline
Find More Posts by 13Flatspins
Build it up!
13Flatspins's Avatar
United States, MN, Coon Rapids
Joined Dec 2007
Mini-HowTo
Cheap tools
2-15-09
I have documented some of the work that I have done to the B 400. Pardon the misspellings, etc. It's hard to edit your blog because you can't see it untill after it's posted. One of the things that got left out of the comments on the photos is that I discovered that six turns on the lower swash plate linkages equals a 10 degree change in pitch. According to the Blade 400 manual, you need to check for zero pitch in throttle hold with collective stick centered. I was showing 5 degrees positive pitch. I took the rotor head off and lengthened the lower swash plate linkages by 6 turns. Then I got a reading of 5 degrees negative pitch. I then shortened the linkages by 3 turns and came out at zero pitch. I hope that takes the guess work out of the equation for someone else.
13Flatspins is offline Find More Posts by 13Flatspins
Last edited by 13Flatspins; Feb 15, 2009 at 12:35 PM. Reason: Comments that were left out of attachments
Discussion Cheap tools inputs on alternates that gotta have. swatson144 Micro Helis 3 Dec 23, 2005 12:00 PM
