Old Mar 17, 2009, 10:44 PM
Foamenator is offline
Find More Posts by Foamenator
AMA 8614
Foamenator's Avatar
Northern Nevada
Joined Mar 2007
Jack.... Many thanks for the great Tuffy build log. I know that took you a lot of time to put together. There is a lot to be learned from it.
Mike... Thanks for listing it in the sticky. Tony is going to have the most organized sticky in RC Groups. No doubt it will help a lot of people decide what to build. Thanks. Bob
Foamenator is offline Find More Posts by Foamenator
Old Mar 18, 2009, 06:31 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
Wow! I am published! And humbled too.
Now I'm under some pressure though, I con't leave this story unfinished can I?
We are 33 degrees with bright sun and clear skies in Maine this morning. I have my two Blu-Babies ready to go, and I'm going flying in a bit.
My pair of BBIS are getting pretty rough looking but they still fly nicely. I thought I had forgotten how to fly until my FB, JerryInMaine, went out with me last weekend and got my head grounded again on the principles of flying.
See you guys later...
Jack
jackerbes is offline Find More Posts by jackerbes
Old Mar 18, 2009, 08:22 AM
Hopalong X is offline
Find More Posts by Hopalong X
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Jack
You look at the sticky lately?
You are extremely published.
Go fly.
Your allowed to take short breaks to fly between build logs- not to long.
Hopalong X is offline Find More Posts by Hopalong X
Old Mar 18, 2009, 10:17 AM
CAVU is offline
Find More Posts by CAVU
CAVU's Avatar
Charlotte, NC
Joined Jul 2004
Has any one tried scaling the Tuffy down to between 24" and 33"? I fly in my back yard and the culd-a-sac and this looks fun to build and fly, plus the neighborhood kids would get a kick out of the design. Any help or ideas would be great.
Thanks, Chad
CAVU is offline Find More Posts by CAVU
Old Mar 18, 2009, 11:41 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Tuffy Trainer - 24" and 33" Wing Span Plans
Chad,
ScaleAndTile would do that. PosterRazor would too.
Here it is in both 24" and 33" from ScaleAndTile, both world plan and tiled, and with a grid overlaid.
Jack
P.S. I think those are right and OK, please post it here if there are any faults in them.
P.P.S - NOTE !! On any and all of these scaled plans, any dimensions noted on the plans will not be right any more. And the scale will not be right either, it cannot be used for determining dimensions any longer.
Old Mar 18, 2009, 01:18 PM
CAVU is offline
CAVU's Avatar
Charlotte, NC
Joined Jul 2004
Chad
Old Mar 18, 2009, 03:22 PM
laserman is offline
Find More Posts by laserman
In Rc for a LONG TIME FFAA#1
laserman's Avatar
Canada, ON, Ottawa
Joined Jun 2004
jacke could you post plans with out the grid as well please as i go to a local print shop and i don't really need the grid lines and that slows down the print process
thanks
jim
laserman is offline Find More Posts by laserman
Old Mar 18, 2009, 05:31 PM
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
Jack
Tuffy 24 and 33 added to sticky.
Old Mar 18, 2009, 06:32 PM
Jack
USA, ME, Ellsworth
Joined May 2008
"..Jack - Tuffy 24 and 33 added to sticky.
Man, I'm really keeping you busy. My apologies!
Jack
Old Mar 18, 2009, 06:45 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Tuffy Trainer - 24" and 33" Wing Span Plans, without grids
Hi all,
Here are the 24" and 33" plans with the grids removed.
Again, I think those are right and OK, please post it here if there are any faults in them.
Geaux Saints
Hopalong X's Avatar
Grafton, Il
Joined Nov 2007
That is what it is for.
I keep up with the sticky as we go it is a lot easier.
Old Mar 18, 2009, 06:47 PM
Jack
USA, ME, Ellsworth
Joined May 2008
You're right of course. It could be worse though, if this was the Blu-Baby thread I would have to edit the other sticky to add them all to the list of the plans in the Blu-Baby thread. :>)
Jack
Old Mar 19, 2009, 04:09 AM
bill dewey is offline
Find More Posts by bill dewey
Bill Dewey
Renton highlands above Lake Washington
Joined Jul 2008
Impressive Efforts
Jack You must not have a nagging wife. You put in a slug of work producing all that you have posted in a short time. I found your new pictures
much easier to follow than the old info. you referred me to on building the
wing. Probably because it was all produced at the same time in logical sequence.
I am still plugging along though and started on the fuse first as that is what I have the material for. I am only using two vertical 3/4" layers of blue foam that contains all my components like servos, battery, receiver controller and
push rods and boom. then this will be covered with a 1/2" layer of EPP with only the servo arm travel notches cut on the in side. then a 6 mil. layer of EPP over everything. I will send a picture when my EPP gets here and I get a little further along. I spent a good deal time just drawing out everything the way
I wanted it
Your finished wing looks good.
bill
bill dewey is offline Find More Posts by bill dewey
Old Mar 19, 2009, 06:20 AM
Jack
USA, ME, Ellsworth
Joined May 2008
Bill,
I have one but she's not down here in the basement with me where my playroom is.
Smartest thing I ever did was let them put radiant heating under the basement floor when this house was built in 2001. I have that set to 55F and the area stays about that temp year around and bone dry too. Adds very little to the fuel load because that thermostat down there only opens that zone a few times a week.
Sounds like your having an interesting build. It's always neat to see the different ways that people come up with to work out the details.
Jack
Old Mar 19, 2009, 09:25 AM
skyfisher is offline
Find More Posts by skyfisher
alberta canada
Joined Dec 2007
This looks like my kind of build at work for few more days then I can start on mine.
Keep the ideas coming I can use all the help I can get.
skyfisher is offline Find More Posts by skyfisher
Video **Tuffy** Pusher type Primary Trainer by Tony65x55 Foamenator Electric Plane Talk 3 Feb 23, 2009 08:31 PM
Revolution 3d EPP Trainer! by 3d_crazy Part 2 Martin Hunter 3D Flying 598 Aug 27, 2004 11:07 AM
Help! pusher type propeller? C-MIC Power Systems 7 Dec 15, 2003 12:22 PM
Where's the Fan Trainer by Steve Neil? rcdude Electric Ducted Fan Jet Talk 11 Jun 06, 2001 02:42 AM
