**The Tuffy** Pusher type Primary Trainer by Tony65x55
Here is some basic info on the **Tuffy** Tony's concept of a Pusher trainer that is pratically indestructible. Video clips over a long flying session without prop damage or repairs.
http://www.rcgroups.com/forums/showthread.php?t=998138 I'll get some more pictures and other details to you this week. In the meantime take a look at the drawing and I'll try to answer any of your questions. I've built a second prototype with a laminated a EPP fuse nose-piece which I think will be even tougher than the first one. I have no other drawings available at this time. Power is a TP 2408-21 which is a BP-21 clone with a 1060 prop and 1100 mah 2s lipo. Edit: 03/04/09Tony is back and has provided us with the remainder of the drawings to complete the set. Please let me know if you have any questions. |
Okay,
I'll watch this one too! Ken
Latest blog entry: MPF M6 Mermaid Scratch and Kit Built
OOoooo. I think I see another AP candidate! I'll be watching this thread...
Latest blog entry: TheCrashCast.com - Episode 210
Pat... I just printed out the pages I needed. For instance the fuse is pages 13-15 (I think). I just measure out the other pieces on the foam rather than cut patterns the trace or past them. Then if I'm not clear about something I just scroll along till I find what I'm looking for and print it. Hope this helps, Bob |
**Tuffy** Udate.
Here is some info on **Tuffy** number III. The second build used the same wing and tailfeathers as the first. The only replacement was the fuselage. I was still able to break the fuse in front of the motor mount so it was cutting down on our durability goal. I was able to get five good prangs on it with on site repairs with hot glue gun.
The third **Tuffy** pictured here has a new wing per the plans made from Elmer's Foamboard with the colored backing (in this case, red and green) left on. The fuselage is new with slight changes in the bamboo rod positioning to gain some strength. The tail feathers and boom (1/2/" square balsa) from the original and have been through much abuse. AUW with 1000 mah lip is 22 oz (324 gms.) **Tuffy** three has eight flights, all excellent. Take offs are straight and power is just right for an primary trainer. Stalls are imaginary, very gentle and straight. Control is very smooth using rudder only in a basic trainer configuration. Add in ailerons and turns are precise with a touch of rudder (my habit). With a little wind and flaperons programmed in, short field landings are a blast. The only thing left to do if desired by the builder is to add fuselage skins to cover the equipment. Personnally I have kinda grown to like the looks of everything hanging out there for the world to see. I have no video of this one so far as my camera has bombed on me.
Another Tuffy Started in PI.
Hi Folks,
Well I got a bit done this afternoon. I hope to get gear installed tomorrow and maybe have her ready to fly. Looks like servos go in the fuse and pushrods are run low under the prop arc from your pictures, Bob. My motor centerline is 5.5" above top of wood boom. I'll be using a 10 x 4.7 Slow-Fly prop or smaller. I've attached some pics of what I have so far. I'm shooting for around 6 to 7 oz/sqft with camera installed. We'll see how it goes. I'll update and post more pictures as things progress. I will probably build a smaller 300+ sq" wing for sport with ailerons as well. The two wings I have available have about 450 sq" effective area. That's just over 3 sqft. However it turns out is the way I'll fly it. Probably go with LG to begin with to protect the pushrods and avoid hand launches but I could change my mind on that. We'll just have to see how she winds up. These things sort of have a development life of their own for me. I don't plan ahead much and they just turn out the way they turn out. Anyway it's all grins and giggles! Steve.
| Thread Tools | |
| Video **Tuffy** Pusher type Primary Trainer by Tony65x55 | Foamenator | Electric Plane Talk | 3 | Feb 23, 2009 08:31 PM |
| Revolution 3d EPP Trainer! by 3d_crazy Part 2 | Martin Hunter | 3D Flying | 598 | Aug 27, 2004 11:07 AM |
| Help! pusher type propeller? | C-MIC | Power Systems | 7 | Dec 15, 2003 12:22 PM |
| Where's the Fan Trainer by Steve Neil? | rcdude | Electric Ducted Fan Jet Talk | 11 | Jun 06, 2001 02:42 AM |
