Go Back   RC Groups > Aircraft - Electric - Helis > Micro Helis
This thread is privately moderated by microkites, who may elect to delete unwanted replies.
Old Feb 13, 2009, 10:07 AM   #1
I HOOVER because I SUCK!
Common rcg abreviations for Helis
this is to help new fliers or posters, to understand some of the abbreviations commonly used on rcg
will edit all to next post if there is actually interest
will probably fade in a few days
but worth a try
mk
guess it wont fade- they stickyed it!
here is link to toshis ehbg glossary
http://www.swashplate.co.uk/ehbg-v17/ch31.html#N13ECF
thanks elan
microkites is offline Find More Posts by microkites   Reply With Quote
Old Feb 13, 2009, 10:13 AM   #2
most common abreviations
POS--!&^%%&%$^%% = piece of sh*t - first thing a new flyer will call his perfectly set up heli --swearing mandatory
Shill,,,,,,,,,,,,,
A shill is an associate of a person selling goods or services(Helis), who pretends to have no association to the seller/group and assumes the air of an enthusiastic customer. The intention of the shill is, using crowd psychology, to encourage others unaware of the set-up to purchase said goods or services (Helis) or support the group's ideological claims.
cnc--Computerized Numerical Control. It is method utilized to machine precise parts
lipo- lithium polymer battery
fff- fast forward flight
h/s- head speed
lhs- local hobby store
t/r- tail rotor
t/g- training gear
l/g- landing gear
b/h- bell- hiller
rx-reciever
tx- transmitter
ESC-electronic speed controller
cf-carbon fibre
fg-fibre glass
FP- fixed pitch
CP- collective pitch
Bl - Brushless
CoG - Center of gravity
Pita - PAIN IN THE A@@ (the story of these little helis)
NiMh = Nickel Metal Hydride (type of rechargeable battery now commonly used in TXs)
NiCd = Nickel Cadmium (older type of rechargeable battery chemistry)
Gov = Governor, ESC based regulation of headspeed
BEC = Battery Eliminator Circuit (derived as a solution from the practice of utilizing two separate batterys in an aircraft/vehicle, one for running the motors, one for running the radio gear, it "eliminates" the need for a separate battery for the radio gear)
PPM = Pulse-Phase-Modulation, or Pulse-Position-Modulation (conventional radio signal type that many RTF models come with, and many 72/75/27/50mhz radio systems utilize)
PCM = Pulse-Code-Modulation (radio signal type that encodes servo positions with a digital "coded" signal, many 72/75/50mhz radio systems utilize this, but are typically proprietary signals standards per manufacturer)
2.4ghz or SS = Newer generation of radios that do not use "fixed" frequencies per model (ie, co-exist automatically without human frequency organization required). SS standing for Spread Spectrum
Acro = Conventional acrobatics, loops, rolls, stall turns, etc
3D = Acrobatic manuevering flying style that involves significant time inverted
Scale (used as a flight style reference) = Typically milder flight style with smooth "full scale helicopter"-like transitions
Auto (maneuver type) = Landing a helicopter with the motor off (google: autorotation)
Rekit = The catastrophic event of turning our carefully built models into a scattering of parts (ie. crash )
AUW = All-Up-Weight, most often the weight of a model with all components to fly as the manufacturer intended it to installed (ie model + canopy + battery).
eCCPM: Electronic Cyclic Collective Pitch Mixing
mCCPM: Mechanical Cyclic Collective Pitch Mixing
FBL: Fly Bar Less, which can include multi blade rotors.
2S, 3S, 4S, etc. -- Lipo battery configuration indicating the number cells in the pack. An xSxP format is also used to indicate parallel configuration (e.g. 4S2P - two 4S packs in parallel).
OWB -- one-way bearing - makes the main rotor capable of auto-rotation
C in relation to lipos...don't know what it stands for but its an "indication" of the speed the amps can be drawn from the pack: Amps (in A not in mah) x C = Amps the pack can safely supply...eg 400mah 20C.....0.4x20=8Amps
TE Trailing Edge
LE Leading Edge
TBE Toilet Bowl Effect
Nose In, Heli points front to pilot
Tail In, Heli points tail to pilot
Side In, Heli side to pilot
HBFP Honey Bee Fixed Pitch
HBCP Honey Bee Collective Pitch
TF-triflow
CA- Cyanoacrylate aka superglue
And here's a few in reference to people and stores.Not so much abreviations in most cases but may be helpful for newer flyers:
TFJ-Rc Babble! (tri flow joe)!
CJ-Helicrack dealer...Chinesejade...also Terrence
Berthold-Nanoheli
Sketch-Sketchaholic...Rotorfever
Jonathon-Wowhobbies
Brettw-Eastcoasthobbies
Mario-Microflight
GITech - GIT - Genuine Innovation Technologies
Servos:
HSxx or HSxxxx: HS followed by numbers is a Hitec servo. May have MG for metal gear or HB for carbonite gears.
Sxxxx, xxxx, Fxxxx, BLSxxx: Futaba servo. Some Futabas have odd designations.
NES-xxx, DS-xxx DS-xxxx: JR servo.
DSxx-GCB: Hyperion servo, the numbers are the thickness of the case in mm, the letters are the version.
BMS-xxx: Blue Bird. May have MG for metal gear or MAX for hi-torque metal.
HG-xxx, HG-Dxxx: Ino-Lab. D means digital, may have MG or HG as well.
DSxxx: Align digital servo (a bit ambiguous out of context because the abbrev looks like JR)
6X, 9XP: Align analog servo
HDS-xxx: Ashtek digital servo
P-xx: MKS Taiwan
HXTxxx, HXTxxxx: Hextronic
TP-xx: Tower Pro
Heilcopter types:
R30 R50: (nitro) Raptor 30 and 50. One version is called a Raptor 50 Titan in full
E550 E620: (electric) Raptor E550 and E620. There is also a Swift E620
MT, Mini-T: Mini-Titan
Rex: Align T-Rex, usually the 450
SE, SEv2, XL, SA, S: By themselves these are usually the different versions of the T-Rex 450
Walkera helis are flying abbreviations already
HBFP: Esky Honeybee Fixed Pitch
HBCP: Esky Honeybee Collective Pitch
NR3D: Venom Night Ranger 3D (Walkera derived)
EXI 450: Not actually an abbreviation, that's what it's called.
CX, CX2: EFlite Blade CX or CX2 coaxial
wot- wide open throttle
Flea - a 3A (amp) micro BL ESC with a PWM to PPM converter built in. Takes the PWM signal from a 4in1 used to run brushed motors and converts it into a PPM signal that is then used to drive its' built in brushless 3A ESC. There are two common variations, a "standard" one for main motors and a "fast" one for tail motors
Taco -is the most performed heli move- to bend or mangle in a crash!
there are a bunch more
will update as we go
mk
Old Feb 13, 2009, 10:53 AM   #3
rx-reciever
tx- transmitter
ESC-electonic speed controller
cf-carbon fibre
fg-fibre glass
FP- fixed pitch
your personal favorite-
LET- liquid electrical tape
Bill
Air Vaca is offline Find More Posts by Air Vaca   Reply With Quote
Old Feb 13, 2009, 10:58 AM   #4
Bl - Brushless
Carl
ReaLyze is offline Find More Posts by ReaLyze   Reply With Quote
Old Feb 13, 2009, 01:42 PM   #5
Crazy Heli Technogeek
Kai_Shiden's Avatar
In no particular order
-Kai
P.S. When I recall more, I'll make a new post so that you don't have to keep re-reviewing this one .
Kai_Shiden is offline Find More Posts by Kai_Shiden   Reply With Quote
Old Feb 13, 2009, 02:04 PM   #6
sweet
thanks guys
mk
Old Feb 13, 2009, 02:37 PM   #7
mk,
i caught a typo in my post...ESC- electronic---I left the "r" out.
sorry,
Bill
Old Feb 13, 2009, 02:44 PM   #8
Excellence is Expected
MakMov's Avatar
MakMov is offline Find More Posts by MakMov   Reply With Quote
Old Feb 13, 2009, 04:59 PM   #9
Quark, EP200V2se, E325se, mSR
mediclavina's Avatar
mediclavina is offline Find More Posts by mediclavina   Reply With Quote
Old Feb 13, 2009, 06:36 PM   #10
Originally Posted by Air Vaca
mk,
sorry,
Bill
fixed
added rest
mk
Old Feb 13, 2009, 07:17 PM   #11
Nice idea Mk. Wait till Babble sees this!!
TF-triflow
Flea-Small speed controller (esc) and converter in one for connecting to Walkera rx's for brushless main's and tails.
TheSteve-a member here and also a converter for bl walkera setups.
Berthold-Nanoheli
Jonathon-Wowhobbies
Mario-Microflight
Amp
Ampdraw is offline Find More Posts by Ampdraw   Reply With Quote
Old Feb 13, 2009, 07:26 PM   #12
Test Pilot, Stand Clear
Don't forget; POS
I have a lota that...
Great idea for a thread btw.
eatmydirt is offline Find More Posts by eatmydirt   Reply With Quote
Old Feb 13, 2009, 07:29 PM   #13
MakMov's Avatar
Originally Posted by eatmydirt
Don't forget; POS
Oh, yeah, a must have POS.
TE Trailing Edge
LE Leading Edge
Old Feb 13, 2009, 07:41 PM   #14
updated up to this point
I am not listing peoples credits on top
just the abbreviation
this thread will fade fast once we list most of them- nothing else to say
but bookmark the link to it to pass out to noobs
unless they sticky it
mk
Old Feb 13, 2009, 07:45 PM   #15
Heilcopter types:
Servos:
P-xx: MKS Taiwan
TP-xx: Tower Pro
Andrew McGregor is online now Find More Posts by Andrew McGregor   Reply With Quote
other kyosho motors any good for helis? hnearnest Electric Heli Talk 3 Feb 06, 2002 11:44 AM
Infra-Red Thermometer for Helis rscamp Electric Heli Talk 7 Jan 08, 2002 07:11 AM
teather forsale , for helis misskimo Aircraft - Electric - Airplanes (FS/W) 0 Oct 12, 2001 02:55 PM
Brushed motors for helis article in S&E Fred Bronk Electric Heli Talk 6 May 31, 2001 06:40 AM
Using Motocalc for helis J.Critchfield Electric Heli Talk 0 May 21, 2001 12:07 AM
Bored? Want to fight?
Join the RCGroups clan!
