Feb 12, 2009, 10:22 PM
Evansville, WI
Joined Dec 2006
How can I tell if my prop balancer is running true?
I made my own magnetic prop balancer. I bought one of those "finger tip" balancers that's basically a threaded shaft with points on the ends, and come cones to center the prop. I then suspended it between some rare earth magnets. It seems to work well with props down to my 4" GWS's. Now however, I'm trying to balance an EDF rotor and I'm having a heck of a time with it. It doesn't seem to be consistently out of balance, but I know it's not slipping and everything is tight. The rotor is so thick I'm only catching a few threads on the balancer shaft with the cones, and I think that might be causing a wobble. I'm also wondering if the drag of the points on the magnets might be throwing it off(it takes some extra magnets on the back side to hold the heavy rotor. Is there a way to tell if the balancer is out of true or if I just suck at balancing rotors? Thanks.
