Old Sep 23, 2009, 09:05 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
or maybe i can do a best guess from this http://jreise.de/PPM/R617FS.html
Hoping i can use this with Phoenix sim lead
SadSack is offline Find More Posts by SadSack
Old Sep 23, 2009, 09:25 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Das schaltplan ist einfach!
rich smith is offline Find More Posts by rich smith
Old Sep 23, 2009, 09:40 AM
SadSack is offline
Joined Aug 2008
even with babelfish all greek to me
Old Sep 23, 2009, 10:29 AM
ergocentric is offline
Find More Posts by ergocentric
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
Originally Posted by Tomapowa
This might even be a simpler non-PIC/AVR solution for converting multiple PWM signals into a single PPM signal.. simply add more diodes for more channels/inputs:
http://www.rcgroups.com/forums/showp...6&postcount=35
Something like a eight input nor/or gate?
Edit: Good for most older receivers that don't sync servo movement
ergocentric is offline Find More Posts by ergocentric
Old Sep 23, 2009, 03:16 PM
druzara is offline
Find More Posts by druzara
Toronto Canada
Joined Feb 2008
Originally Posted by rich smith
Thanks for verifying! It would be wonderful if you and Kanchana posted your code so others could take advantage. A local fellow has modified for 5 channel and I'm trying to get a copy to post. I would personally find your 6ch more useful than any of the other versions.
Maybe some day I'll get a chance to upgrade to a version that does not require fixed number of channels. Probably would be more than couple dozen instructions though.
Thanks for clearing up the pinout issue too. Makes it easier for those who don't have a scope.
sure thing! will post asm and hex files when i get home this evening, wanted your permissions first since it was "reverse engineered" from your hex
druzara is offline Find More Posts by druzara
Old Sep 23, 2009, 10:30 PM
druzara is offline
Toronto Canada
Joined Feb 2008
Here they are, enjoy!
Atmel ASM file:
Code:
          ; Atmel Win32 AVR Disassembler V1.01 by SXPILOT450
          ; Byte Address & ASCII Column by WagnerLip - 2009
          ; Instruction         ADDR HEXA OPERANDS     BYTE#  ASCII NEXT 8
	  ; Modified by Druzara/Rex 09/22/2009
	  ; http://acholic.turningaway.net
	  ; 6 Channel operation for Spektrum 6xxx receivers
	  ; PPM output on PB7, inputs on PB0-PB5
          ; AT90S2313 8MHz
          ; changes to original code are commented out but left in source
         .DEVICE AT90S2313
         .INCLUDE "2313def.inc"
         .cseg
         .org	0
          ldi    r23, 0x9F    ; 0000 E97F              0000   Setup stack pointer
          out    SPL, r23     ; 0001 BF7D              0002
;         sbi    DDRB, 4      ; 0002 9ABC              0004   PB4 as ppm output
          sbi    DDRB, 7      ;                        0004   PB7 as ppm output
avr0003:  ldi    r22, 0x01    ; 0003 E061              0006   load r22 with bit to test
          rcall  avr0015      ; 0004 D010              0008   call avr0015 to set output
          ldi    r22, 0x02    ; 0005 E062              000A   repeat for all bits
          rcall  avr0015      ; 0006 D00E              000C
          ldi    r22, 0x04    ; 0007 E064              000E
          rcall  avr0015      ; 0008 D00C              0010
          ldi    r22, 0x08    ; 0009 E068              0012
          rcall  avr0015      ; 000A D00A              0014
;         ldi    r22, 0x20    ; 000B E260              0016
          ldi    r22, 0x10    ; 000B E260              0016
          rcall  avr0015      ; 000C D008              0018
;         ldi    r22, 0x40    ; 000D E460              001A
          rcall  avr0015      ; 000E D006              001C
;         ldi    r22, 0x80    ; 000F E860              001E
;         rcall  avr0015      ; 0010 D004              0020
;         sbi    PORTB, 4     ; 0011 9AC4              0022
          sbi    PORTB, 7     ; 0011 9AC4              0022   ppm out high
          rcall  avr001F      ; 0012 D00C              0024   short delay
;         cbi    PORTB, 4     ; 0013 98C4              0026
          cbi    PORTB, 7     ; 0013 98C4              0026   ppm out low
          rjmp   avr0003      ; 0014 CFEE              0028   loop for next cycle
avr0015:  in     r23, PINB    ; 0015 B376              002A   test PB bit masked
          and    r23, r22     ; 0016 2376              002C   by r22
          breq   avr0015      ; 0017 F3E9              002E
;         sbi    PORTB, 4     ; 0018 9AC4              0030
          sbi    PORTB, 7     ; 0018 9AC4              0030   set ppm out high
          rcall  avr001F      ; 0019 D005              0032   short delay to inject gap
;         cbi    PORTB, 4     ; 001A 98C4              0034
avr001B:  in     r23, PINB    ; 001B B376              0036   wait until current
          and    r23, r22     ; 001C 2376              0038   channel is done
          brne   avr001B      ; 001D F7E9              003A
          ret                 ; 001E 9508              003C
avr001F:  ldi    r25, 0x03    ; 001F E093              003E   delay for proper gap between pulses
avr0020:  sbiw   r24, 0x01    ; 0020 9701              0040   ie: "needle" glitch as generated
          brne   avr0020      ; 0021 F7F1              0042       by diode circuits
          ret                 ; 0022 9508              0044
          ori    r18, 0x38    ; 0023 6328              0046   '(c) 2006 R.Smith'
          and    r2, r9       ; 0024 2029              0048   ') 2006 R.Smith..'
          cpi    r19, 0x02    ; 0025 3032              004A   '2006 R.Smith....'
          cpi    r19, 0x60    ; 0026 3630              004C   '06 R.Smith......'
          subi   r18, 0x20    ; 0027 5220              004E   ' R.Smith........'
          subi   r18, 0x3E    ; 0028 532E              0050   '.Smith..........'
          ori    r22, 0x9D    ; 0029 696D              0052   'mith............'
          ori    r23, 0x84    ; 002A 6874              0054   'th..............'
         .exit
and the hex file:
:020000020000FC
:100000007FE97DBFBF9A61E00ED062E00CD064E072
:100010000AD068E008D060E106D060E204D0C79A58
:100020000CD0C798F0CF76B37623E9F3C79A05D002
:10003000C79876B37623E9F7089593E00197F1F72F
:100040000895286329203230303620522E536D69AE
:020050007468D2
:00000001FF
thanks again, rich!
Old Sep 24, 2009, 06:58 AM
rich smith's Avatar
Joined Dec 2006
thanks again, rich!
Thank you!
Now I don't have to hunt down my source. This will make it a trivial matter to change number of channels too.
Old Sep 24, 2009, 08:27 AM
SadSack is offline
Joined Aug 2008
Nice one thanks druzara
I'll guess you used scope to find out which pin order ?
Old Sep 24, 2009, 02:21 PM
druzara is offline
Toronto Canada
Joined Feb 2008
aye, was troubleshooting it with scope when it worked for eflite and not with dx7 TX.
btw, worked fine with Phoenix sim. Wireless infront of a projected screen is just like a day in the park except the part where i am looking for the broken parts in the grass.
Old Sep 24, 2009, 02:27 PM
SadSack is offline
Joined Aug 2008
hmmmmm guess i'll figure it out other boring way then.
Q: could that be complied to run on mega 88v? Got to order otherwise
Thx
Old Sep 24, 2009, 04:08 PM
rich smith's Avatar
Joined Dec 2006
Thx
Easy to figure channels. Just move a servo from one to the other and wiggle TX sticks.
To work with 88 you need to change addresses for Port B.
Old Sep 29, 2009, 03:41 PM
SadSack is offline
Joined Aug 2008
Well ATTINY2313-20PU 8-BIT came to day
Well built it and well few issues...
Unsure of fuse setting, appears too work. Still rather be on same page.
Well may untrained eye it appears to be inverted but you tell me how its wrong
I've used same setting to pick both signels
First pic is PPM output from 12FG trainer port
Next output from convertor. Looks like pins PB0~PB06 in order go into Futaba R606FS in order PB0=ch1 PB1-ch2 and so on, nice.
So any help would be great, Thanks
Old Sep 29, 2009, 03:46 PM
SadSack is offline
Joined Aug 2008
btw have tried my specktrum module and that appears to be inverted too.
And not guessed channel order either.
Old Sep 30, 2009, 03:02 AM
rich smith's Avatar
Joined Dec 2006
All servo PWM signals are activie hi. My Hitec TX PPM signals are active hi too so that's what the code outputs. Other TX may be active low so If your quad, autopilot, etc expects that you can add a transistor (i.e. 2n7000) on the output to invert or mod the code.
And ch1-7 inputs are PB0-6. They must be in order for this to work right.
Old Sep 30, 2009, 04:53 AM
SadSack is offline
Joined Aug 2008
hoping for code fix...this will be very handy for sim. And 1 mcu few leads simple
But can't code myself ;( Can't do much...apart from read(kinda) and drive soldering iron!
Discussion how to convert PWM servo signal to DC voltage sahilkit DIY Electronics 15 Oct 05, 2008 09:23 PM
Mini-HowTo Motor PWM to PPM impulse converter quax DIY Electronics 27 Jun 16, 2008 11:38 PM
PWM to servo signal conversion? mcross DIY Electronics 13 Jul 05, 2005 08:48 PM
Futaba PCM receiver servo pulse other than PPM? risto Power Systems 14 Feb 14, 2002 12:18 PM
