Old Jul 11, 2009, 11:50 AM
kanchana is offline
Find More Posts by kanchana
Joined Feb 2009
Does this code work with mega 8
Originally Posted by rich smith
Luckily the chips were unlocked so here's code. Should work unmodified on a Tiny26 too or any old AVR with a port B. Pinout should be same as the Tiny13 one with extra channels added on after 4. Just from memory, it's been a few years.
No chance to test it myself because my Futabas batt is dead and also I don't have a Mega8 socket wired up. Please post result so we'll know. Photo would be nice too so others can benefit.
SRVPPM83.HEX:
:020000020000FC
:100000007FE97DBFBC9A61E010D062E00ED064E071
:100010000CD068E00AD060E208D060E406D060E866
:1000200004D0C49A0CD0C498EECF76B37623E9F30B
:10003000C49A05D0C49876B37623E9F7089593E07F
:100040000197F1F708952863292032303036205285
:060050002E536D69746877
:00000001FF
Does this cod work for mega 8 or any other code for mega 8
kanchana is offline Find More Posts by kanchana
Old Jul 13, 2009, 04:19 AM
rich smith is offline
Find More Posts by rich smith
7000mw of raw power!
rich smith's Avatar
New Hampshire (not the old one)
Joined Dec 2006
Yes. Any AVR that has "original" address for Port B like Mega8, Mega8515, and all of the Tiny family.
rich smith is offline Find More Posts by rich smith
Old Jul 16, 2009, 10:50 AM
DanNsk is offline
Find More Posts by DanNsk
Joined Jul 2009
I have ATtiny12l , which is max 4mhz, can i use unmodified original code for this converter, or it needs to be changed, or unluckily i can not use that at all ?
DanNsk is offline Find More Posts by DanNsk
Old Jul 17, 2009, 06:44 AM
rich smith's Avatar
Joined Dec 2006
The 4mhz spec is for use with very low voltage (1.8v). At 5v the chip runs at 8mhz and higher so there is no problem. In fact I've run them at 20mhz with xtl.
Also note this program is pretty much frequency indpendent. 8mhz will give about 300us gap which is close to real PPM.
Old Jul 17, 2009, 08:13 AM
DanNsk is offline
Joined Jul 2009
ATtiny12L datasheet says 2.7 - 5.5V , 0-4 MHz, but ok thanks , i'll try.
Old Jul 17, 2009, 08:39 AM
rich smith's Avatar
Joined Dec 2006
IIRC there are charts at the end of the spec that show more details. But you get the idea.
Old Aug 10, 2009, 09:26 AM
SadSack is offline
Find More Posts by SadSack
United Kingdom, Bristol
Joined Aug 2008
Well this looks great. Few Q:
Try for hour or so and don't appear to work with my futaba 2.4 but could be fuse's set wrong.
1: Will it work with Futaba 2.4 and/or Spektrum RX ?
2: fuse? what should it be for attiny 45
3: See other code for 4 or more channels. But only have attiny 13/45/85. Could i use a pair of attinys ?? to give me 6/8 channels ?
Hoping i can go wireless on Phoenix Sim
SadSack is offline Find More Posts by SadSack
Old Aug 11, 2009, 07:00 AM
rich smith's Avatar
Joined Dec 2006
1. As long as servo pulses do not all start at the same time it should work.
2. Any setting for 8mhz no WDT. I use fuseh=d7 fusel=e2 for my Tiny45. Actually almost any clock will work, even the stock 1mhz setting, but faster gives more accurate PPM train.
3. Using a pair will result in two separate PPM signals so not sure if this is useful.
Old Sep 21, 2009, 12:19 PM
kanchana is offline
Joined Feb 2009
I have 8 channel version
I ave 8 channel version programmed in a atmega8 chips whic i can ship if interested
Old Sep 21, 2009, 01:18 PM
rich smith's Avatar
Joined Dec 2006
If you're willing to do it on a non-profit basis that sounds fine. I released my code as a contribution to RCG hobbyists and would have no problem if others passed on the favor.
Old Sep 23, 2009, 08:09 AM
druzara is offline
Find More Posts by druzara
Toronto Canada
Joined Feb 2008
SRVPPM83.HEX:
:020000020000FC
:00000001FF
Thanks rich! 7 channel hex image does work Verified even on an obsolete 8MHz 2313 that I had otherwise no use for these days :P
Just a couple of observations that I have noticed that others may find useful:
1.You must supply pulses to all 7 inputs PB0-PB3, PB5-PB7 as there are some blocking codes that will hang if any channel(s) are missing. Which led me to modify the code slightly for a 6 channel Spektrum 6100 reciever.
2.Your receiver must output pulse sequence in order from PB0 to PB7, otherwise, the generated PPM will be all messed up. I found out the hard way by wiring up a Spektrum 6100 receiver with a DX7. It turns out the channels are sequenced in the following order:
1 Aileron
2 Aux
3 Elevator
4 Rudder
5 Throttle
6 Gear
This sequence appears to be dependent on the transmitter, using an Eflite LP5DSM, the pulse sequence is in order of the receiver header pins.
1 Throttle
2 Aileron
3 Elevator
4 Rudder
5 Gear
6 Aux
druzara is offline Find More Posts by druzara
Old Sep 23, 2009, 08:59 AM
rich smith's Avatar
Joined Dec 2006
Thanks for verifying! It would be wonderful if you and Kanchana posted your code so others could take advantage. A local fellow has modified for 5 channel and I'm trying to get a copy to post. I would personally find your 6ch more useful than any of the other versions.
Maybe some day I'll get a chance to upgrade to a version that does not require fixed number of channels. Probably would be more than couple dozen instructions though.
Thanks for clearing up the pinout issue too. Makes it easier for those who don't have a scope.
Old Sep 23, 2009, 09:00 AM
SadSack is offline
Joined Aug 2008
1 Aileron
2 Aux
3 Elevator
4 Rudder
5 Throttle
6 Gear
1 Throttle
2 Aileron
3 Elevator
4 Rudder
5 Gear
6 Aux
Any chance of sharing code ?
And how did you work out correct conections ? I'm hopeing to use futaba 2.4 and i don't have a scope
Old Sep 23, 2009, 09:02 AM
rich smith's Avatar
Joined Dec 2006
One minute later!!!
Old Sep 23, 2009, 09:04 AM
SadSack is offline
Joined Aug 2008
or maybe i can do a best guess from this http://jreise.de/PPM/R617FS.html
Discussion how to convert PWM servo signal to DC voltage sahilkit DIY Electronics 15 Oct 05, 2008 09:23 PM
Mini-HowTo Motor PWM to PPM impulse converter quax DIY Electronics 27 Jun 16, 2008 11:38 PM
PWM to servo signal conversion? mcross DIY Electronics 13 Jul 05, 2005 08:48 PM
Futaba PCM receiver servo pulse other than PPM? risto Power Systems 14 Feb 14, 2002 12:18 PM
