Old Aug 07, 2011, 02:22 PM
Aircraft re-kitter
ergocentric's Avatar
15NM from CYYZ on 06L
Joined Feb 2007
Originally Posted by djdavies83 View Post
Hi sorry if this has been covered already, or is a little off-topic, this is the closet search I have found to what I am looking for.
Can this chip be programmed (or has someone done it) to do the reverse, take a PPM signal and output 4-8 channels?
The reason I ask is I've been very interested in the iPhly: Open-Source R/C on the iPhone thread and would like to use the PPM out from the phone and connecting it directly (though a chip of course) to the servos for any projects where a radio Tx/Rx set is not needed.
Many thanks Dave.
Like a Signetics NE4055? difficult to find now.
ergocentric is offline Find More Posts by ergocentric
Old Aug 08, 2011, 03:45 AM
Sleurhutje's Avatar
Netherlands
Joined Sep 2008
Anybody any experience with this interface on a Spektrum AR7000 (or any other receiver with servo sync)?
Sleurhutje is offline Find More Posts by Sleurhutje
Old Aug 09, 2011, 07:26 AM
Aircraft re-kitter
Joined Feb 2007
They have source code available on the page too, nice.
Old Aug 12, 2011, 04:33 AM
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swansea
Joined Apr 2010
Would this 8CH GWS-8M 35mhz FM receiver be hackable to take a direct PPM in put and give me the servo pwm outputs?
djdavies83 is offline Find More Posts by djdavies83
Old Aug 12, 2011, 10:23 AM
Aircraft re-kitter
Joined Feb 2007
need to know the chip number
a bit pricey for a single conversion receiver
Old Aug 12, 2011, 09:43 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
I've asked the seller but he didn't know the chip number, It's a used on on eBay I'm thinking of getting, I would never buy new for a conversion like this.
I think I know who to ask, I'll post my findings to help anyone who may look for this info.
Old Sep 12, 2011, 08:20 AM
NW England
Joined Jul 2005
EDIT - Atmega8 does in fact have 8 pins in PORTB... I didn't look hard enough So ignore this
Thanks for the code! I've got an atmega8 lying around so I'd like to use this to sum 6 channels. I've not clue about assembly but have made the changes to the code to try to do this :
Code:
          ; Atmel Win32 AVR Disassembler V1.01 by SXPILOT450
          ; Byte Address & ASCII Column by WagnerLip - 2009
          ; Instruction         ADDR HEXA OPERANDS     BYTE#  ASCII NEXT 8
	  ; Modified by Druzara/Rex 09/22/2009
	  ; http://acholic.turningaway.net
	  ; 6 Channel operation for Spektrum 6xxx receivers
	  ; PPM output on C0, inputs on PB0-PB5
          ; ATMEGA8 8MHz
          ; changes to original code are commented out but left in source
         ;.DEVICE AT90S2313
         .INCLUDE "m8def.inc"
         .cseg
         .org	0
          ldi    r23, 0x9F    ; 0000 E97F              0000   Setup stack pointer
          out    SPL, r23     ; 0001 BF7D              0002
;         sbi    DDRB, 4      ; 0002 9ABC              0004   PB4 as ppm output
          sbi    DDRC, 0      ;                        0004   PC0 as ppm output
avr0003:  ldi    r22, 0x01    ; 0003 E061              0006   load r22 with bit to test
          rcall  avr0015      ; 0004 D010              0008   call avr0015 to set output
          ldi    r22, 0x02    ; 0005 E062              000A   repeat for all bits
          rcall  avr0015      ; 0006 D00E              000C
          ldi    r22, 0x04    ; 0007 E064              000E
          rcall  avr0015      ; 0008 D00C              0010
          ldi    r22, 0x08    ; 0009 E068              0012
          rcall  avr0015      ; 000A D00A              0014
;         ldi    r22, 0x20    ; 000B E260              0016
          ldi    r22, 0x10    ; 000B E260              0016
          rcall  avr0015      ; 000C D008              0018
;         ldi    r22, 0x40    ; 000D E460              001A
          rcall  avr0015      ; 000E D006              001C
;         ldi    r22, 0x80    ; 000F E860              001E
;         rcall  avr0015      ; 0010 D004              0020
;         sbi    PORTB, 4     ; 0011 9AC4              0022
          sbi    PORTC, 0     ; 0011 9AC4              0022   ppm out high
          rcall  avr001F      ; 0012 D00C              0024   short delay
;         cbi    PORTB, 4     ; 0013 98C4              0026
          cbi    PORTC, 0     ; 0013 98C4              0026   ppm out low
          rjmp   avr0003      ; 0014 CFEE              0028   loop for next cycle
avr0015:  in     r23, PINB    ; 0015 B376              002A   test PB bit masked
          and    r23, r22     ; 0016 2376              002C   by r22
          breq   avr0015      ; 0017 F3E9              002E
;         sbi    PORTB, 4     ; 0018 9AC4              0030
          sbi    PORTC, 0     ; 0018 9AC4              0030   set ppm out high
          rcall  avr001F      ; 0019 D005              0032   short delay to inject gap
;         cbi    PORTB, 4     ; 001A 98C4              0034
avr001B:  in     r23, PINB    ; 001B B376              0036   wait until current
          and    r23, r22     ; 001C 2376              0038   channel is done
          brne   avr001B      ; 001D F7E9              003A
          ret                 ; 001E 9508              003C
avr001F:  ldi    r25, 0x03    ; 001F E093              003E   delay for proper gap between pulses
avr0020:  sbiw   r24, 0x01    ; 0020 9701              0040   ie: "needle" glitch as generated
          brne   avr0020      ; 0021 F7F1              0042       by diode circuits
          ret                 ; 0022 9508              0044
          ori    r18, 0x38    ; 0023 6328              0046   '(c) 2006 R.Smith'
          and    r2, r9       ; 0024 2029              0048   ') 2006 R.Smith..'
          cpi    r19, 0x02    ; 0025 3032              004A   '2006 R.Smith....'
          cpi    r19, 0x60    ; 0026 3630              004C   '06 R.Smith......'
          subi   r18, 0x20    ; 0027 5220              004E   ' R.Smith........'
          subi   r18, 0x3E    ; 0028 532E              0050   '.Smith..........'
          ori    r22, 0x9D    ; 0029 696D              0052   'mith............'
          ori    r23, 0x84    ; 002A 6874              0054   'th..............'
         .exit
Basically channels 1-6 are B0-5, and as PORTB only has 6 pins on the Atmega8 I've tried to output the PPM Sum to C0. Will this work?
Thanks!
Ben.
ben123 is offline Find More Posts by ben123
Old Sep 12, 2011, 12:07 PM
NW England
Joined Jul 2005
Also can anyone help me out with what fuses to use with an atmega8? I've looked at the fuse calculator and it's going right over my head
Ben.
Old Sep 13, 2011, 07:27 AM
USA, NY, Syracuse
Joined May 2005
I believe the code change should work, on the fuse bit , there are some calculators on the web. I don't have any links right now (at work).
beer-man is offline Find More Posts by beer-man
Old Sep 13, 2011, 10:15 AM
NW England
Joined Jul 2005
Thanks beer-man... I've looked through the code and with the help of Lord Google I've figured out what it's doing. Unfortunately though I think I've bricked my atmega8 as the programmer can't find it's signature now (it's all Fs). I was attempting to set the fuse bits but my lack of knowledge killed it
Ben.
Old Sep 13, 2011, 12:18 PM
USA, NY, Syracuse
Joined May 2005
I've done the same a couple times, sometimes you can revive them by connecting an external clock to the clock input. If that doesn't bring it back then it needs a high voltage programmer which is harder to find.
Old Sep 13, 2011, 02:02 PM
NW England
Joined Jul 2005
Yep tried the external clock thing but no go. So I tried the code on a spare atmega48 dip I found and it worked like a charm. Lovely square PPM on the scope! Was able to use the original code (B7 ppm out) with the 48
Ben.
Old Oct 30, 2011, 05:45 PM
Xnaron's Avatar
Joined Feb 2003
Originally Posted by pipsqueak View Post
Hi Rich,
I've been using your fantastic converter for a couple of months now - thanks again for posting the code.
I've been using your HEX on a Tiny13 (i.e. four channels only) - making an almost exact-looking replica of yours.
Btw, If there are any arduino users out there who'd want to decode the PPM that comes out of this, I'll post the modified sketch I use at the bottom:
However Rich, It would be really great to get a version to handle more channels - Ie. use the extra pins on the Tiny26 version. However, without the source I can't make the tweaks above that you mentioned.
So I was wondering, would you either possibly be up for (a) tweaking your code, and posting a HEX for a new version that could handle up to 8 inputs, or (b) posting the source so that I could have a go myself - If successful I'd post the version back to the thread
No matter what, I'm really grateful to have found such a neat 4 channel solution - So thanks again.
Cheers,
Pip
Code:
// TX PPM INPUT STUFF
#define TXINPUTPIN 8 // Define TX PPM input signal - HARDCODED (so changing this won't make any difference)
unsigned int serinp[8]; // For the input PPM signal
#define TX_PITCH serinp[0]  // Related to the PPM order and wiring
#define TX_ROLL serinp[1]
#define TX_THROTTLE serinp[2]
#define TX_YAW serinp[3]
                      Setup
void pmm_setup()
  // Setup the TX PPM input
  pinMode(TXINPUTPIN, INPUT); // Ensure the TX PPM pin is input
  setup_timer1(); // Start the timer that does the PPM
                      Functions & Subroutines
void setup_timer1(){
//disable all interupts
TIMSK1 &= ~( _BV(TOIE1) | _BV(ICIE1) | _BV(OCIE1A) | _BV(OCIE1B));
//set timer mode
TCCR1A &= ~( _BV(WGM11) | _BV(WGM10) );
TCCR1B &= ~( _BV(WGM12) | _BV(WGM13) | _BV(ICNC1));
//capture raising edge
TCCR1B |= _BV(ICES1); //capture raising edge
//prescaler 1/8
TCCR1B |= _BV(CS11);
TCCR1B &= ~( _BV(CS12) | _BV(CS10) );
//disable outputs
TCCR1A &= ~( _BV(COM1A0) | _BV(COM1A1) | _BV(COM1B0) | _BV(COM1B1));
//enable capture interupt
TIMSK1 |= (1<<ICIE1);
ISR(TIMER1_CAPT_vect){
static unsigned int lasticr; //icr at last caputre
static unsigned char cserinp; //current input servo
unsigned int licr;
//TCCR1B ^= _BV(ICES1);
licr=ICR1-lasticr;
lasticr=ICR1;
if (licr<10000) { //pulse not super long - so Ok, otherwise totally ignore
if(licr>5000){ //pulse too long, means start of new frame
cserinp=0;
serinp[cserinp]=licr;
cserinp++;
}else if(licr>500){ //pulse good, take reading, go to next channel
if(cserinp<8){
cserinp++;
}else{
//too short, nothing to see here
//updateTXVals();  // So at the end lets update our calibrate vals
I'm just looking for some simple interrupt driven code to read a channel from an rx. I don't want to use pulsein. I have tried so many sketches I've googled and haven't found anything that works the way I wanted. Anyone have an example? I am using arduino pro mini (328p).
thanks,
Bendin
Xnaron is offline Find More Posts by Xnaron
Old Oct 31, 2011, 03:42 PM
hungary
Joined Jan 2011
Hi,
I made my own PWM2PPM converter based on ATtiny2313. Mine can handle up to 8 channels (it uses the entire port B of the ATtiny2313) and I have a power LED and a PWM signal indicator LED. I have also added 4 pull-down resistors for channels 4-8 to avoid any problems with floating inputs.
This can only handle PWM pulses which are not simultaneous - the pulses may not overlap; they have to occur one after another.
The source code is written in C. I used the 8 bit timer interrupt to generate the 300us PPM pulse, but I think a delay_us(300) could be used instead just as well. I also thought about using pin change interrupts instead of polling, but I think polling makes things a little simpler. As I said, the program can handle any number of channels (up to 8), but I don't recommend less than 4 because only channels 4-8 have the pull-downs.
I have attached the Eagle CAD schematic and PCB. I made the circuit and PCB so that I can plug my receiver directly into the converter.
I have tested it with a HK6DF TX/RX and I use it for controlling a simulator. It seems to work just fine.
Enjoy!
kile is offline Find More Posts by kile
Old Jan 23, 2012, 10:43 PM
Joined Jan 2012
Hello,
I don't mean to revive an old thread but I was wondering if anyone could maybe modify the code for three channels with a ATTiny13A. I am trying to include this as a method to transmit data over some distance via cable. Except I only need the three channels.
Thank you, any help is much appreciated. I will try and understand it as best i can in the meantime. I am more mechanically inclined, software is a foreign language to me.
Andrew
torquemonster is offline Find More Posts by torquemonster
Discussion how to convert PWM servo signal to DC voltage sahilkit DIY Electronics 15 Oct 05, 2008 09:23 PM
Mini-HowTo Motor PWM to PPM impulse converter quax DIY Electronics 27 Jun 16, 2008 11:38 PM
PWM to servo signal conversion? mcross DIY Electronics 13 Jul 05, 2005 08:48 PM
Futaba PCM receiver servo pulse other than PPM? risto Power Systems 14 Feb 14, 2002 12:18 PM
