Charging at greater than 1C. I have been doing it for over three years. I have started a couple or three Threads on the subject. I have posted my charging results using different chargers such as TP1010C,Cell Pro 10,Hyperion DUO and 720i ,recently charging 3S and 4S 3300 mAh LiPolys and 3S 2P 4400 LiPolys.
A post by RC Man showing charge time at different rates. Note date of post http://www.rcgroups.com/forums/showp...&postcount=483 Capacity versus shape? There are NiMH AA cells ,all te same size from 600 to 2700 mAh capacity. If you notice charging times increasing then also note how much longer the CV stage is taking and /or perhaps how much more balancing is going on. These are signs ot the battery wearing out or showing results of damage / abuse or just low quality cells dieing early as they most often do. . Charles |
I posted : Quote:
I wonder if you have ever perfectly balanced a cross section of you packs, let them set for a few hours then rechecked their balance? Along the same lines I wonder if you have ever checked the inbalance of a discharge pack then charged it to say 4.1 per cell average without balancing then rechecked its' balance? Again just curious. Some may find this post from 4 years ago back when I first started checking pack balance interesting. http://www.rcgroups.com/forums/showp...64&postcount=2 Snip Quote:
Dover DE USA
Joined Feb 2007
i would say i balance them after 3-4 cycles and usually if i see that when i bring them home and they sit for a couple hours after a flight, the balance is off say 3.56 - 3.67 - 3.75 something weird like that in different orders --- Scott |
Dover DE USA
Joined Feb 2007
Hey Charles,
My BC610 tries to balance to the one hundredth of a volt, and so far is able to do so on all my packs. Whever I've checked them after some time goes by, they are off by at most .01, which seems great to me. Since I use a balancing charger, I have no experience in trying to bring out of balance cells back into balance. Also, as far as what a realistic "acceptable" balance difference is, you have a much better feel for that than I do. -G |
| Thread Tools | |
| Can a charger with a 2000mah charge rate charge a Gp3300? | butserflyer | Batteries and Chargers | 7 | Jun 02, 2004 07:43 AM |
| How can I increase my roll rate? (Logo 20) | Ben74 | Electric Heli Talk | 18 | Jan 19, 2003 01:09 AM |
| Can some one explain the C in charge rate? And what do you charge your He-cell at? | rspiegel | Batteries and Chargers | 10 | Jan 08, 2003 09:50 AM |
| C/10 Charge Rate Tolerance | ToddO | Power Systems | 4 | Apr 17, 2002 06:14 AM |
| Is OK to continue pumping in C/10 charge rate after peak? | Mitch G | Power Systems | 12 | Dec 04, 2001 06:53 PM |
