Old Apr 19, 2001, 03:59 PM
Daniel English is offline
Find More Posts by Daniel English
NY NY USA
Joined Jun 2000
Anybody use two packs for speed 400 twins?
I was thinking on making a twin speed 400 plane and using two power systems mixed together on the radio. How does this sound? Two speed 400 6V on 8x600AE each?
Dan
Daniel English is offline Find More Posts by Daniel English
Old Apr 19, 2001, 04:08 PM
dave_lilley is offline
Find More Posts by dave_lilley
Texas
Joined Aug 1999
Heavy
dave_lilley is offline Find More Posts by dave_lilley
Old Apr 19, 2001, 04:09 PM
Larry Dudeck is offline
Find More Posts by Larry Dudeck
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Sounds like a lot of additional work, esp. if you plan on 2 ESC's.
What benefit do you perceive?
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Apr 19, 2001, 04:33 PM
NY NY USA
Joined Jun 2000
Well I have a lot of 600mah packs.....
Old Apr 19, 2001, 04:34 PM
tim hooper is offline
Find More Posts by tim hooper
Single-task at best...
tim hooper's Avatar
Telford, UK
Joined Feb 2000
Dan,
Digging deep here.....I think someone has done this with a Twinstar. A seperate ESC for each motor, somehow mixed into the Tx.
He was able to throttle each motor independently, and induce such tricks as high-speed flat spins.
I'm sure that somebody will be able to shed more light.
tim
Bingo! Email Jim Myers;
KMyersEFO@aol.com
and ask for a file of the Ampeer newsletter from July 99.
[This message has been edited by tim hooper (edited 04-19-2001).]
tim hooper is offline Find More Posts by tim hooper
Old Apr 19, 2001, 04:38 PM
NY NY USA
Joined Jun 2000
I just checked the specs and 2 8 cell 600 AE packs works out to 10.4 ounces. An 8 cell 2400 pack weighs 18 ounces, and a 8 cell 1200 pack weighs 12 ounces.
It would just be the extra weight of a controller which is less than one ounce. It could actually be lighter.
Dan
Old Apr 19, 2001, 04:46 PM
cmulder is offline
Find More Posts by cmulder
Ireland
Joined Apr 2001
earm what if one pack discharges faster then the other?
cmulder is offline Find More Posts by cmulder
Old Apr 19, 2001, 05:22 PM
Sabrejock is offline
Find More Posts by Sabrejock
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Dan: If you want to use your 600 packs and don't want to go series, 'Y' your packs in parallel to give you 1200 mAh and still use BEC. You can charge them as individual packs. Tex.
Sabrejock is offline Find More Posts by Sabrejock
Old Apr 19, 2001, 05:31 PM
NY NY USA
Joined Jun 2000
Thats theother otion, but then I need a 16 cell controller.
Old Apr 19, 2001, 06:20 PM
Sabrejock's Avatar
Winnipeg, MB Canada
Joined Jan 2000
Dan, if you join your packs pos to pos, neg to neg, and take the power from there, you still have 8 cells in reality. That's parallel. Tex.
Old Apr 19, 2001, 06:36 PM
gdb1973 is offline
Find More Posts by gdb1973
Senior Member
Oxford(ish), England
Joined Feb 2001
Good question, what happens if one flattens first? Assemetric thrusts, that's what. With a pinwheeling prop on the other side (heaps of drag) this COULD be dangerous!
You could wire them up in parallel. This is the option i'd choose as you only need one ESC and that can be a standard 8-cell one.
If you're interested in assymetric thrust for steering, you'd need to wire things up so you had a Y lead like a delta. You'd have throttle on the "Elevator" channel and rudder on your "aileron" channel. I don't know how you'd go about sorting the power supply for the radio, though. Obviously you could use the BEC's in the ESC, but i haven't a clue how it might be effected by this extra complexity!
gdb1973 is offline Find More Posts by gdb1973
Old Apr 19, 2001, 10:06 PM
NY NY USA
Joined Jun 2000
Parrallel like Sabrejock says would probably be theeasiestway, I was thnk series together weoud be 16 cells, or series seperately would be 2 8 cell packs. Maybe I should just buy some 1250's
Dan
Old Apr 19, 2001, 11:51 PM
sf_247 is offline
Find More Posts by sf_247
Austin, Texas USA
Joined Mar 2001
I read somewhere about a Twinstar with the motors wires in parallel and 2 battery packs wired in parallel. This would be the simplest way to do it and use your existing equipment.
sf_247 is offline Find More Posts by sf_247
Old Apr 20, 2001, 05:37 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
I've done the mixing twice now, but both times with two speed controls and only one battery. The systems worked well, with all mixing done in the transmitter, mixed to the rudder stick so that rudder stick movement causes one motor to speed up, the other to slow down, depending on the location of the throttle stick, it can be quite dramatic. I did this successfully on the TwinStar, but my attempt at converting a JC Hobbies fun bat was not as successful, not because the mixing didn't work, but because we never could get it in the air, even with a bungee. There was obviously enough power to fly, it wanted to pull out of your hand, I think the airfoil was so thick that we just couldn't get it going fast enough at launch. It looked OK though, here's a pic.
Azarr
www.azarr.com
OK, for some reason I can't get the photo to appear, let's try this:
<a href=http://albums.photopoint.com/j/View?u=94931&a=12646387&p=46897672>See my photo, twinbat1 at PhotoPoint</a>
[This message has been edited by Azarr (edited 04-20-2001).]
Azarr is offline Find More Posts by Azarr
Old Feb 27, 2004, 02:22 PM
fprintf is offline
Find More Posts by fprintf
[intentionally blank]
fprintf's Avatar
Cheshire, CT, USA
Joined Jan 2001
So this was this first post in this forum eh? Cool!
fprintf is offline Find More Posts by fprintf
Looking for a cheap lithium capable ESC for speed 400 use... papasmurf Power Systems 5 Apr 24, 2004 10:38 PM
Has anybody USed Vario Props What size for speed 400? DPupko Scale Kit/Scratch Built 7 Mar 05, 2003 08:08 PM
Cheap Battery Packs for Speed 400 Fliers SchiessCo Aircraft - Electric - Airplanes (FS/W) 4 Mar 02, 2003 09:35 PM
Anybody use Tape Solder for battery packs?? saint152 Foamies (Kits) 4 Apr 30, 2002 11:54 AM
Radiator for a Speed 400? Tim Seidenstricker Electric Plane Talk 22 Jun 02, 2001 01:02 PM
