Espritmodel.com Heli Air
Old Dec 31, 2005, 08:23 PM
Registered Boozer
Ralph_D's Avatar
United States, CA, Tustin
Joined Sep 2003
Angle of incidence question? - Long EZ Build
I'm almost done with my Raidentech Long EZ build. All I have left is to glue the wings to the wing roots and affix the decals.
In the very limited instructions it is stated that you MUST get the angle of incidence for each wing to match. Any suggestions on the best method for achieving this?
-Ralph-
Ralph_D is offline Find More Posts by Ralph_D
Old Dec 31, 2005, 09:48 PM
Boynton Beach, FL
Joined Jul 2005
THAT.......looks really good.
gotime242 is offline Find More Posts by gotime242
Old Jan 01, 2006, 12:20 AM
Crossville, TN
Joined Dec 2004
Prop up the fuselage and use two identical spirit levels placed at the same exact location on each wing,shimmed as needed.Double check with a Robart Incidence Meter,if available.
Art Schmitz is offline Find More Posts by Art Schmitz
Old Jan 01, 2006, 01:29 AM
Tenino WA.
Joined May 2004
Rlaph what are u going to power that with ???
CRASHED AGAIN is offline Find More Posts by CRASHED AGAIN
Old Jan 01, 2006, 01:53 AM
Registered Boozer
Ralph_D's Avatar
Joined Sep 2003
Gotime242, thanks for the compliment! I hope if flys half as good as it looks.
Art, thanks for the info, I have a level, I don't have the Robart meter. Is there any quick and dirty method that's not reliant on equipment I probably don't have
Carshed Again , I'm going to use a HET-RC - Typhoon EDF 4W . I've been told this motor is similar to a mega 16/15/4 in amp draw and power. It'll be turning an APC 7x4 prop and I'll be using a Thunder Power 3 cell 2100 prolite pack. With this setup I'm pulling 25 amps at full throttle when the model is held so I figure in the air that'll come down a bit. It does want to pull out of my hand so I'm thinking I won't be short on power. Do you have experience with this model?
-Ralph-
...Happy New Year!!
Old Jan 01, 2006, 12:25 PM
Tenino WA.
Joined May 2004
Ralph nope no experance with this model, but you sure have me interested in it.. Will be watching to see how it flys with that power plant.. keep us informed, Plane looks great
Old Jan 01, 2006, 04:09 PM
Crossville, TN
Joined Dec 2004
Ralph,the plastic spirit levels that I use are about a dollar each at a hardware store.They have a hook on the top of each end that lets them hang from a tightly stretched string.The end caps are hexagon in shape,which allows them to rest flat on a slightly curved surface.
Andy Lennon's book on 'R/C Model AIRPLANE DESIGN' has a chapter on CANARD AND TANDEM WING DESIGN that is very informative.HTH. art
Old Jan 01, 2006, 07:40 PM
Registered Boozer
Ralph_D's Avatar
Joined Sep 2003
I took some measurments and used my levels and in the end eyeballed the distance between the canard and main wing to make sure it all lined up equally.
If you look at the pic below what I did was stand in front of the plane and look directly down the nose, I then eyeballed the distances in the circled area and made sure they were equal...same way I line up the horizontal stab to the main wing on a regular plane.
-Ralph-
Discussion Long EZ 36" ARF Electric Build canard addict Scale Electric Planes 266 May 15, 2012 07:00 AM
Discussion Long EZ Voyager Electric configuration question. bor Power Systems 1 Mar 15, 2007 06:08 PM
Discussion Long Eze build question RonB Sport Planes 2 Sep 24, 2006 09:21 PM
Angle of incidence question dshly Power Systems 6 Apr 06, 2002 07:14 PM
k-a mig 15 incidence question Herb Electric Ducted Fan Jet Talk 2 Sep 10, 2001 12:22 AM
