Then starting with the internal battery depleted, I again wiped the card, plugged into my car charger, and began another recording sequence, filling the 4GB card again. After which I wiped the file from the card, and immediately started another recording without charging the battery from my PC USB port. That recording lasted just under 39 minutes, indicating the battery was fully charged while it was recording! So it is clear to me that not ALL #2 cameras have the same charging issue that yours does. One thing I noticed from your voltage measurements is the voltage levels you measured appear to be higher than normal (I assume they are accurate measurements). I may be mis-understanding your readings, but a properly functioning protection circuit board should clamp the upper voltage limit available to the battery at nominally 4.2V +/- going into the battery. Anything higher can damage the battery, or worse, cause it to over-heat, swell, and possibly ignite if the voltage gets too high. There are some representative tests to show this on the chucklohr.com web site for the similar #3 SD version of the camera. Assuming the external power source has sufficient current available at the proper voltage, the parallel connection with the battery should work in unison, with external source doing most all of the work if the battery is fully charged, and taking up the slack as the internal battery starts to be depleted, keeping the battery charged in the process. A special charging circuit is not needed if the voltage levelat the battery terminals is clamped at a nominal 4.2V. A lipo cell will stay charged to the voltage level on it's terminals. I routinely charge up to 4 cells in parallel with my flight battery packs, with the charger maintaining a steady 4.2V on the charging connection for the latter half of the charge cycle. |
Joined Apr 2011
Sorry, they are not accurate. My old lab power supply was not stable enough and the camera significantly changes its power consumption depending on voltage. If you are interested, I can measure my camera again. Now I have a new equipment and I can measure accurately now. Quote:
If I power the camera from pin 4, the only protection represents the breaker inside the battery. I can measure exact voltage when it breaks, but is is probably a bit more than 4.2V (4.3V?). Keep in mind, that the circuit inside the battery module is not intended as charging controller. It is a last resort damage protection. I seen 5.5V and more on battery module terminals when powering via pin 4! So there is no other protection in my camera than the circuit inside the battery module. Quote:
Joined Nov 2010
However, after reading all the postings in this thread (good job I started early!), this seems to be what a lot of people do. Early in 2010, while I was trying to find a way to power the #3 with an external power source, I was also told: "... And connecting 2 lipo in parallel can also be a very bad idea." So, I'm a bit , but common logic tells me that it is, indeed, not such a good idea to connect lipos in parallel. However, given the fact that the internal battery only lasts about 3 or 4 months (at least my last two didn't last any longer), I guess not too much harm can be done. On the other hand, perhaps my batteries don't last long because I always use the special cable - and as you say, there is no external regulation.Since I always need long recording times, I'm forced to use external power supplies, and I'm sure your design will give me the extra protection. Now I just need the time to get the components/materials and make the board. |
Jumbo #11 Auto Standby Shutoff?
I love the #11 Jumbo camera, but it does not have an auto standby shutoff. So if the power button on the unit gets accidently pushed, it will boot up and sit there until the battery goes dead. I think my regular #11 would have shut off after a short period. Anybody know of a fix?
tnx, Ken |
Joined Apr 2011
If you are charging two cells in parallel, you do not you have control over the charging current and temperature of particular cells. But here you connect external power supply with the LiPol battery (well, via a diode and an emergency breaker). |
United Kingdom, Blackpool
Joined Aug 2011
![]() Could the mark actually be alive? Could it literally be A MICROSCOPIC BUG ????? For anyone who's interested, here is a link to a webpage showing the fault occurring:- http://web.mac.com/modea2/Rangeway.TV/Keyfob_Fault.html Does the other fault previously mentioned by other posters look like this? |
Joined Dec 2006
files only accessible if camera is left on
Hi --
I've been searching to see if this has been addressed. Sorry if this is a duplicate question. I have two 808 #11 cameras. I've updated the firmware to remove the time on both. One works great. On the other camera, if I record a video lasting more than one minute or so and turn the camera off, no file is saved. If I leave the camera on and can connect to a computer before it turns off, I've been able to access files of 5 or 6 minutes in length. Any suggestions? Many thanks! George |
On my second test sequence I used the car charger that came with my Jumbo #11 to power the same small #11 used in the prior test. That car charger has a plug with no integrated cable. Instead it plugs into the car charge socket and has a standard 4 pin female USB plug, with two supplied cables... one being a two wire cable terminated with the special mini-USB plug for powering the camera while recording, and the other a standard 4 wire mini-USB cable for just charging the camera, I guess, via the normal voltage on Pin #1 through the camera's dedicated CC-CV charging IC. I was able to measure the voltage on JUST the charger plug (with no attached cable), and that outputs an even 5.0V between the two outer contacts, consistent with a standard USB plug. And I was able to check continuity on the two-wire special mini-USB plug, confirming that the +5V from the car charge plug normal USB pin#1 does, indeed, cross over to pin#4 on the mini-USB end. So this car charger supplies a full 5V to the camera! I don't know if the Jumbo circuit board has any other components to drop the voltage down futher, or just relies on the battery protection circuit board to clamp the excess voltage from reaching the battery terminals (but I will contact the developer to find out. I have used my 4 AAA cell NiMH external battery pack to power my #2 with no adverse results (yet!), and it delivers close to 5V to the camera when freshly charged. I guess this newer charger cable could be used to power the camera from a computer while recording. Quote:
Yes, I understand this, too. I did not mean to imply otherwise. When I connect my lipo flight packs in parallel prior to charging, I make sure they are within .1V of each other using a cell balancer, and they are charged and balanced with a dedicated lipo charger. The voltage surge when connecting lipos in this manner is well controlled and safe. If the resting voltage of the camera cell is about 3.7V after the battery gets low as mentioned above, this represents about 15% of the battery capacity still remaining in the cell. Not fully depleted, but low never the less. Connecting an external battery pack is best done with the internal cell fully charged, though I have done it with the camera having just shut down from a low battery voltage with no obvious problems. |
Joined Apr 2011
Well, I am starting to suspect that there is only one V2 camera, but two versions of car charger:
- 5V (?): Fully charges the battery while driving but probably overcharges. - powering one - 4.20V: Starts to power the camera when the battery is nearly depleted. I have the second version of the car "charger". Quote:
The protection breaker activates when the voltage on battery terminals reaches 4.76V-4.88V and charging current 0.25A-0.33A. In that moment charging current drops abruptly to 0A. I am not sure whether it is current activated or voltage activated, but both values are unsafe for terminals of a fully charged battery. And yes, the breaker resets somewhere above 3V. Pin 4 voltage reaches in that time 4.88V-5.00V. To be sure that the protection activated, I had to use at least 5.01V. Powering pin 4 with 4.54V, the battery terminal reached 4.20V/0.03A. It means that everything above that voltage on pin 4 is unsafe. If somebody built a special pin 4 cable to power the camera from USB: - If USB provides 4.88V or less, your battery is overcharged forever and quickly dies. - If your USB provides 5.01 or more, your battery is overcharged only for a limited time and dies less quickly. - Using a standard silicon diode in the power line may improve things a bit. Two diodes in series should be safe even if USB provides 5.5V. Here is new corrected list of pin 4 power voltage safety: - 4.32V and less: safe, but battery partially depletes while recording - 4.38V-4.52V: unsafe: Charging voltage is correct, but charging never finishes. - 4.56V-4.88V: quick battery damage: Battery is overcharged potentially forever. - 5.01V and more: less quick battery damage: Battery is strongly overcharged, but then charging stops. The emergency charger provides 5.624V without any load => it overcharges the battery. I stopped my experiment at 4.22V at battery terminals and 4.54V on the charger. Current was 19mA and slowly raised. |
Jumbo #11
Ken |
| Thread Tools | |
| Video Samurai with key cam | AeroNut45 | Electric Plane Talk | 2 | Oct 30, 2010 11:40 PM |
| Found found | beladog | FPV/RPV - Equipment and Vehicles (FS/W) | 1 | Oct 30, 2010 01:01 PM |
| Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! | khaled_abobakr | Video Piloting (FPV/RPV) | 8 | Oct 10, 2010 07:13 AM |
| Mini-Review Key Chain Cam for your autogyro!!! | imsofaman | Auto Gyros | 7 | Sep 10, 2010 07:10 AM |
