Old Dec 30, 2010, 03:15 PM
Wisdom can not be granted.
Orion Pax's Avatar
Shreveport Louisiana
Joined Dec 2006
Got the new controller in 20 min ago. Programmed it, plugged it in, and "Bobs your uncle", it WORKED! The controller was the problem and the new one solved it. Thank you Antslake for helping me trouble shoot every possibility before I purchased another one. Now I can wrap this thing up in the next day or 2 and if weather allows I can go fly this baby before I paint her up.
Orion Pax is offline Find More Posts by Orion Pax
Old Dec 30, 2010, 06:59 PM
How high will it go?
antslake's Avatar
Greenwood Lake NY
Joined Oct 2003
Your welcome! Good luck with the plane.
antslake is offline Find More Posts by antslake
Old Jan 16, 2011, 01:26 PM
Toronto Canada
De controller problem
Hi there guys,
I just purchased this kit, (starter kit) and it was fine when i got it but now, channels 1 and 2 dont work. Its strange though, because when i first plug the de controller into power, they come on and then go off. I have tried resetting eeprom and drivers. Its only channels 1 and 2. Any ideas? It work fine for the first ten mins but now, it seems they are dead. Its weird how they quickly turn on, then go back off. Channels one and two are getting power obviously. Any ideas??
lilphil26 is offline Find More Posts by lilphil26
Old Dec 19, 2011, 09:55 PM
No ! Your other left !
aramsdell's Avatar
United States, ME, Sanford
Joined Jun 2006
I want to run a nav light and beacon in each wingtip. It looks as if the positives of the connector block are all connected. If I use a 3 wire servo extension out to the wing and run my 150 ma LED's near max current will this setup have any decreased performance? I would set it up for Red + shared by two LED's, Black to neg on an LED and the 'signal' wire to the other LED Neg..
Alan
aramsdell is offline Find More Posts by aramsdell
Old Dec 30, 2011, 01:00 PM
Joined Feb 2010
Alan
You will have no issues using the controller this way. The positive is shared and the ground is switched.
Best,
Alex
DE
thenrz is offline Find More Posts by thenrz
Old Mar 17, 2012, 11:58 PM
United States, MD, Rockville
Joined Feb 2010
Originally Posted by Darth_Elevator View Post
After uploading the file, I took another look at the red channel programming and saw that my zero and 10% slots somehow got slid together so they were extremely short, probably too short for a perceptible black. So I made them longer and reprogrammed and now I can distinctly see it go completely off. So that just leaves the green. With the three LEDs do I just need to experiment with other values below 50% until I get a perceptible drop in brightness? I reprogrammed with 20% and 30% and now I can see it dim, with the 20% being more noticeable than 30.
Here's another little quirk I wonder if anyone else has experienced. When I plugged in the delink just now to reprogram these changes, only one LED came on and when I hit "program" it said unable to connect to delink. (See attached screenshot.) I unplugged the delink from the USB cable and plugged it in again. This time 2 LEDs came on and still unable to connect. I unplugged and plugged in again and 3 LEDs came on, and unable to connect. Then I unplugged and plugged in again and 4 came on and it DID connect. Weird.
resurrecting this. i love this system, but have the same problem with connecting. I was able to program it once, but thats it.
aquaanox is offline Find More Posts by aquaanox
Old Mar 21, 2013, 03:10 AM
Flying Wood For Fun
irun4fundotca's Avatar
Canada, ON, Harrowsmith
Joined Jan 2012
Cessna 400
just thought I would post my Cessna 400 program file
if someone can tweak the flashing better feel free to revise and repost
theres always room for v2 lol
See next post of mine for fixed version
irun4fundotca is offline Find More Posts by irun4fundotca
Old Mar 22, 2013, 01:37 AM
H2oSmokey
dainw's Avatar
Mill Creek, WA
Joined Jun 2009
What is your goal to improve?
dainw is offline Find More Posts by dainw
Old Mar 22, 2013, 01:46 AM
Flying Wood For Fun
Joined Jan 2012
I just wasnt sure if the flash sequence looks ok/right
i noticed i had the lights in the wrong places
and the colors were flashing where they shouldnt be
added the rear flashers on wings and top red front tail flasher & white rear tail light
Old Jun 14, 2013, 02:04 AM
Flying Wood For Fun
Joined Jan 2012
Newer more scale Version Cessna400
did a mockup on my f86 just because of space restrictions
but you get the locations of the leds and see the finished timings
DElight Starter Kit - Programming Mockup 2 (0 min 0 sec)
Old Sep 13, 2013, 12:32 AM
Got Another Prop?
WadesRC's Avatar
United States, VA, Hampton
Joined Aug 2006
https://www.youtube.com/watch?v=lhYEfjRr9rI
Jets are a lot of fun to light up with this system.
This is a foamy I did a while back and It still works perfectly.
http://www.rcgroups.com/forums/showp...&postcount=276
WadesRC is offline Find More Posts by WadesRC
Old Sep 13, 2013, 10:22 AM
Flying Wood For Fun
Joined Jan 2012
thats awesome did you add the sound to the video, or is it a onboard sound module?
I haven't had much luck flying the f86 ..cg problems and not having the sized packs that fit
it was just a mock up for my cessna because I dont have room for the wings to be installed to test the look of the leds
Old Sep 13, 2013, 03:57 PM
Got Another Prop?
WadesRC's Avatar
Joined Aug 2006
Actually the audio track was something I composed using jet engine tracks and a few select audio grabs from an old TV show.
Intro - Six Million Dollar Man (1 min 27 sec)
Model plane lighting system Joe Yap Modeling Science 23 Aug 06, 2007 02:47 PM
Looking for one beta tester for lighting system.. Nik-rc Parkflyers 9 Sep 12, 2004 07:50 PM
PIcture of MPI Micro Lighting System konaboy Parkflyers 7 Jan 21, 2003 03:16 AM
Lighting system for your Heli. Fred Bronk Electric Heli Talk 11 Jan 15, 2003 02:00 AM
Miniflash with a Curtek lighting system! Martin Hunter Parkflyers 15 Dec 24, 2002 04:06 PM
