This thread is privately moderated by GWS CHEN, who may elect to delete unwanted replies.
Old Apr 15, 2014, 05:33 PM
Jet-Addicted!
United States, SC, Greenville
Joined May 2012
believe it or not, I'm using a 5 or 6 bladed "stock" eflite 69mm - 3600 kv, the thing is no joke I have to say.. on 3S is more than capable, on 4S ballistic. ahving said that, the real fun of the plane is not HIGH speed, but LOW speed flight. For a non-TV plane, it is a SUPER beginning-to-learn-jet-3D and high-alpha plane. (not to mention if you fly it too hard/high speed you'll rip the canards right off it).
it is a VERY light plane - many would be skeptical of it- but if it's built right, and set up right, this plane RIPS. GWS is priced very fairly, and although it's a little more work (and NOT an EPO airplane) they fly like a joy, and are very realistic and scale. I highly recommend this plane. mine's in 54a castle, 69mm eflite on 4s/2200 35c zippy or simlar. the plane hauls ass, but again, is even more a joy in the nose-up/high-alpha attitudes at low speeds. if you add a rudder, and fly is 4s it can easily hover
NickFox is offline Find More Posts by NickFox
Old May 02, 2014, 08:33 AM
Jet-Addicted!
Joined May 2012
Jank -= not sure if you saw my other posts, but man, this thing is KILLER. I DO NOT recommend the changesun - it's so many blades and this plane will beg you for lots of throttle variances and punches, etc -- Accordingly, I think a lesser-blade rotor is a smarter idea, and less thrust-latency too (all key reasons why I assert this).
Mine is on eflite 3600kv on 3S OR 4S -- I like flying it either way, actually. It has plenty of glide/float either way, but it definitey behaves a little differently in bank, because of the slight weight differences. canard mixing can be tinkered with to help avoid "falling out" or "picking up" out of turns, which is common when starting and flying a canard plane first time(s).
Save the changesun for something straight-jet like an F18, or albatross, etc. This J-10 is WAY too much fun for Both fast and slow flight. I added a rudder and I can almost just about hover- it is FRigging AWESOME. the GWS kit was overlooked by ALOT of people. I found it by happenstance and will be loking to acquire more kits, since as a 70mm easy-to-tote airframe, it is most certainly one of the most fun (and impressive in the air) 70mm's I know. I would say I like it more than my 70mm V2 starmax F18 70, however that's not true - I like them both equally, for different reasons.
hope that helps. Again, I highly suggest LESS blades - if not the eflite, than a HET or Wemo with a nice high Kv motor on 3S (or slightly lesser for 4s) is advisable. The plane is amazing - you will like it. DO ADD A RUDDER!
Last note: BEWARE YOUR THROWS - I set up triple rates thinking I'd reduced travel enough for low - It was a near disaster and rquired alot of skill to get it to turn without spiraliing. LOW RATES NEEDED FOR AILERONS!!!
Originally Posted by Jankomatic View Post
I have this kit, but no ducted fan or motor to power it. Can anyone recommend a fan and motor from perhaps Hobbyking that will fit in this plane?
Thanks!
Old Jul 16, 2014, 02:11 PM
United States, GA, Clayton
Joined Jan 2010
My 1st GWS J-10 build and I will Start with a 6s power plant. All GWS servos even on the Canards.
dirdredd is offline Find More Posts by dirdredd
Reply With Quote  (Disabled)
Old Jul 16, 2014, 09:42 PM
Taipei, Taiwan
Joined Oct 2005
Hi Dirdredd,
Thanks, it's nice to know that you applied all GWS servos on this GWS J-10.
The power setup shown on the pictures should give you more than enough thrust on it.
Chen
GWS CHEN is offline Find More Posts by GWS CHEN
Old Jul 21, 2014, 12:08 PM
Joined Jan 2010
Thank You Mr. Chen.
Old Jan 21, 2015, 02:34 AM
Patrizio_g's Avatar
London, Ontario
Joined May 2006
Hi guys nice to see this thread is not dead you believe or not my J10 is not finish i week ago i started to think it was time to finish it i have in there a tornado motor for 6s and capable of over 1k of thrush but right now i am thinking something with more torque and less kv would have being better but too late for that no.
where are you guys buying the kit? i got mine from rccastle but i don't think they are carrying it anymore.
Patrizio_g is offline Find More Posts by Patrizio_g
Old Jan 21, 2015, 05:37 AM
Schwalbe
Junkers Jumo's Avatar
Australia, WA, Yokine
Joined Aug 2011
Yep, I think you're right. Not showing up on RC Castle anymore. I bought two when I bought my Freewing Mirage late last year. Haven't started on them yet, untouched still in box, I'll have to be very careful with them now! They may be the last two in existence...
Junkers Jumo is offline Find More Posts by Junkers Jumo
Old Jan 21, 2015, 09:52 AM
Patrizio_g's Avatar
London, Ontario
Joined May 2006
i did a little goggle and found a store that have them $75 not too bad, do you have videos of yours?
Discussion GWS 262 EDF Jet GWS4CEO Foamy EDFs 14 Aug 03, 2008 08:28 AM
Cool Chinese J-10(Depron foam) picture & video aero-dreamworks Parkflyers 12 Aug 02, 2008 07:48 AM
Discussion Chinese J-10 aero-dreamworks Pusher Prop Jet Models 17 Jan 03, 2008 06:07 AM
Sold Good old Vet GWS A-10 twin EDF jet fighter bomber with 2 servos shschon Aircraft - Electric - Jets (FS/W) 3 Nov 24, 2006 02:26 PM
New to EDF - Opinions please! Best handlaunch parkflyer sized EDF jet model StahlmanGC Electric Ducted Fan Jet Talk 7 Aug 19, 2004 07:21 PM
