Old Mar 04, 2007, 05:19 PM
Joined Mar 2007
X-UFO Battery Advice Needed
I have a Li-Poly 11.1v Battery Pack marked 15C is this safe enough to power my SilverLit UFO ?
Last thing I want to do is damage the circutboard,,
I have some long Cable ties..
This is the sort of Battery I was thinking of using:
Li-poly 11.1v
Or should I just stick with the normal Battery Pack, which only lasts about 5mins
nuttycomputer is offline Find More Posts by nuttycomputer
Old Mar 04, 2007, 06:16 PM
ebill3's Avatar
United States, WA, Puyallup
Nutty, you will probably get better response if you tell the forum what the SilverLit UFO requires in terms of volts and amps. What is the normal battery?
Bill
ebill3 is offline Find More Posts by ebill3
Old Mar 04, 2007, 06:22 PM
Joined Mar 2007
Bill
12v 350mAh
Old Mar 04, 2007, 07:40 PM
ebill3's Avatar
A 12 volt Ni battery at full charge is about 14.5 volts. An 11.1 LiPo batttery at full charge is about 12.6 volts, so no danger of overvoltage. Don't know what current your craft draws, so difficult to guess how the voltage will sag under load.
However, the LiPo you are looking at weighs 145 grams while your Ni pack probably weighs less than 80 grams. No idea what a SilverLit UFO is - can it handle the extra weight at a reduced voltage?
Don't forget, you need a charger specifically designed to charge LiPos.
BTW, welcome to RC Groups.
Bill
Old Mar 04, 2007, 07:59 PM
Joined Mar 2007
SilverLit UFO
Above link tells and shows you what a SilverLit UFO is..
Thanks for making me feel welcome.. Cheers !
Regards
NC .. .
Discussion X-UFO Battery Cable Connector name needed nuttycomputer Batteries and Chargers 0 Mar 09, 2007 06:19 AM
X-UFO Battery life and flight time... johnny5alv Coaxial Helicopters 3 Jul 16, 2005 06:09 PM
battery advice needed tomlescal Batteries and Chargers 1 Nov 29, 2004 11:45 AM
Rant Fundango motor/prop/battery advice needed WGRoper Parkflyers 12 Feb 21, 2002 03:45 PM
Battery advice needed YVR Beginner Training Area (Aircraft-Electric) 5 Oct 12, 2001 10:08 AM
