Old Oct 15, 2014, 08:24 AM
Joined May 2013
Version 4.1 Telemetry Reader available
Version 4.1 telemetry reader available.
See details here :-
http://www.helifreak.com/showpost.ph...&postcount=105
Version 4.0 had an issue related to custom graphs and vario data.
kevinww is online now Find More Posts by kevinww
Old Oct 20, 2014, 03:26 AM
Joined May 2013
Version 4.2 Available
Version 4.2 telemetry reader available.
See details here :-
http://www.helifreak.com/showpost.ph...&postcount=117
Old Oct 22, 2014, 05:38 PM
Sydney, Australia
Joined May 2005
Temp Sensor Errors
Hi Andy,
The Temp sensor on one of my aircraft started to play up last weekend. You can see in the attached data file. There are some obviously good readings where the temp goes up to about 100deg C as expected from previous flights, but there are also a lot of data points in the 300 to 500deg C range !!
So, I would really like to know what caused them and how I can fix the problem.
Could it be caused by an open circuit in the temp sensor ?
A short circuit in the temp sensor ?
A nick in the heatshrink allowing it to touch the metal of the motor head ?
We don't have time during competitions to download the data and look at it, just a quick look at the maximums on the Transmitter screen after landing to see if there are any signs of problems. Not much help when it says 514deg C !!
The installation is on a 20cc glow motor. The sensor is on/in the gap between the top and second top cooling fins on the head, on the exhaust port side of the motor. A small amount of glue has been used on the wires each side of the sensor to hold it to the fins (without blocking them) so it hopefully does not move with vibration and chafe the heat shrink over the temp sensor.
I actually seem to be getting a similar problem with a 55cc petrol engine installation, though it is not as bad yet. Can send the data file for that one as well if it would help.
Jag
jrandle is offline Find More Posts by jrandle
Old Oct 22, 2014, 06:01 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
http://www.rcgroups.com/forums/showt...0#post29736229
Andy
AndyKunz is offline Find More Posts by AndyKunz
Site Sponsor
Old Feb 08, 2015, 12:25 PM
Joined Aug 2011
Originally Posted by AndyKunz View Post
Hi Andy,
Are there any plans to produce a supported PC / Android telemetry viewer ?
I have purchased a lot of telemetry gear (GPS, altimeter, RPM, External Voltage, TM1100/1000) for my gliders over the years which I find extremely useful at the slope.
I now want to view & analyse the logs once at home and find it a little amazing that Spektrum haven't yet produced software to view this data. I for one would be more than ready to pay for supported software.
I am aware of two viewers (one payware and one freeware) but I have had trouble using both. The viewer's efforts are highly commendable but I would far prefer to have a Spektrum supported piece of software that will work with all Spektrum logged data. (I do not own (or want to own) an iPhone btw).
Surely Spektrum is the logical company to produce such software ?
Kind regards,
MikeTheBike is offline Find More Posts by MikeTheBike
Old Feb 08, 2015, 12:36 PM
AndyKunz's Avatar
Illinois
Joined Sep 2001
www.robo-software.com - that's the one we use. The author is part of Team Horizon Hobby. He gets updates to the header files to use in his system - that's how we support it.
Andy
Site Sponsor
Old Feb 09, 2015, 02:09 PM
Joined Aug 2011
Andy
I wasn't aware of this connection. I already have this software. Thanks for the reply
Discussion Format of DJI Wookong Ground Station log files ? sPiKes777 Multirotor Electronics 39 Jan 09, 2015 09:02 AM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 0 Aug 28, 2012 01:59 PM
Sold NEW Spektrum DX8 Transmitter DSMX W/charger and sd card HD Hucker Aircraft - General - Radio Equipment (FS/W) 3 Aug 27, 2012 07:55 PM
Sold Spektrum DX8 Transmitter w/Charger and SD Card! NEW HD Hucker Aircraft - General - Radio Equipment (FS/W) 2 Aug 24, 2012 12:28 PM
Discussion DX7s (perhaps DX8) SD card storage format editor? A Useless Geek Radios 54 Jan 03, 2012 12:27 AM
