Old Apr 10, 2012, 03:08 AM
Thermal Wrangler
DrFragnasty's Avatar
Launceston Tasmania
Joined Mar 2004
Data
Ceres Sub-Spar
Just an FYI for those interested in how Jiri Baudis makes his Ceres sub-spars.
Likely made en-masse from a big sheet of 4mm balsa, faced with uni-carbon on one side and light 'glass on the other.
Uni-carbon is laid-up 90 deg to the balsa grain. Don't know about the 'glass bias.
Then cut to suit the depth required and cut so the uni-carbon runs from top to bottom skins and the balsa simply has the grain running root- to- tip.
DrFragnasty is offline Find More Posts by DrFragnasty
Last edited by DrFragnasty; Apr 10, 2012 at 03:09 AM. Reason: The monkey says "boo"
Old Apr 10, 2012, 07:13 AM
chetosmachine's Avatar
Madrid, Spain
Joined Sep 2004
On cyril and fosa, he replaced the balsa by rohacell.
And puts vertical uni carbon on both sides of rohacell.
The sub spar and the flap/aileron spar are made the same way.
chetosmachine is online now Find More Posts by chetosmachine
Gallery Sub Committee - 2011 West Coast Sub Run - - 1 October craig_c Submarines 15 May 16, 2013 04:57 AM
Off Site *** Phil Davy Aircraft - Sailplanes (FS/W) 0 Apr 06, 2012 07:34 AM
Sold Merriman Type VII Sub and Sub Driver ir3 Boats (FS/W) 0 Dec 20, 2011 09:59 AM
Discussion Top-driven flaps - sub-TE spar in the way? Neil Walker Slope 12 Mar 23, 2007 01:59 PM
