Old Jan 22, 2015, 04:46 PM
United States, NC, Chapel Hill
Joined May 2013
Originally Posted by Kevin Matney View Post
Has any one ever try Corel 14 to cut with as a plotter ?
If you are asking if Corel can be used to cut vinyl, to my knowledge the answer is no. Vinyl cutters require software that us either specific to a cutter, or know to interface with a given cutter.
Corel, like several graphics programs with vector capabilities, can be used to create content - which ultimately must to be imported in to the software driving the cutter.
That said, keep in mind that the kind of vector drawing tools required to create and cut simple single color vinyl patterns for an rc plane is not nearly as taxiing as required for normal graphic design applications. In other words, it does not take a sophisticated graphics app like illustrator or Corel to draw to get the job done IMO.
bb
bobbysbrother is offline Find More Posts by bobbysbrother
Old Jan 22, 2015, 05:10 PM
All under control, Grommit!
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
ISTR that you can cut directly from Corel X4 using the Corel Connect plug-in.
How to Cut Straight To The Silhouette Cameo using the TRW Stone Wizard or CorelDraw! (11 min 42 sec)
Haven't tried it myself, I just export the Corel Draw files as PNGs and use the trace utility in the Silhouette software.
leccyflyer is offline Find More Posts by leccyflyer
Old Jan 22, 2015, 07:42 PM
bullseye000's Avatar
Aurora Municipal, Illinois, United States
Joined Jul 2002
I use a Graphtec cutter and they have plugins for both Adobe Illustrator and Corel.
bullseye000 is offline Find More Posts by bullseye000
Old Jan 22, 2015, 08:57 PM
To Infinity and beyond!
PropsnWings's Avatar
Joined Jun 2011
bb
True, however using the Silhouette, for about a year now, I am looking to do more than single color trace cuttings. I'd like to try either printing on vinyl, or doing layered cuts to get a multicolored graphic. I am still not sure how to do either.
PropsnWings is online now Find More Posts by PropsnWings
Old Jan 23, 2015, 12:17 AM
Joined May 2013
I've used my Silhouette Cameo to cover ( in part or in whole) 9 foamies so far 99.9% of which I use Oracal adhesive vinyl. On rare occasions I will print using my HP inkjet on printable vinyl, driven from the same software - then cut it out with the cutter. The cameo's method of laying down reg marks for the cutter to does work and is not that complicated to do, but it has it's limitations.
1. Not all printable vinyl stock is the same. Some absorb ink better than others. Some are thinner than others.
2. Printable vinyl typically comes in individual sheets as opposed to rolled vinyl - I use 8.5 x 11 - and as a result is significantly more expensive
3. The finish is mat and requires a protective coating after the fact to protect the ink from the elements.
I've used it for certain details, like multicolored logos and such, but it's totally impractical to use on a large scale IMO.
bb
Old Jan 23, 2015, 06:07 AM
Joined Jun 2011
Do you have a link for the printable vinyl that you've used?
Old Jan 23, 2015, 06:47 AM
umdpru's Avatar
United States, MA, Boston
Joined Jun 2006
I like the idea of printable vinyl, too. I have been printing on sticker paper using print/cut methods available on Silhouette studio.
umdpru is offline Find More Posts by umdpru
Old Jan 23, 2015, 07:27 AM
Joined May 2013
I've gotten the best results using the following. I prefer the "contouring" white printable vinyl they offer. It's a tad lighter, cuts easier, and lays down better on curved surfaces.
http://www.texascraft.com/hps/SAMPLE....-1-Sheet.html
Don't forget to coat the print before applying by using either the spray on they offer or something like the decal protector sold by Testor.
bb
Old Jan 23, 2015, 09:29 AM
Citizen 46
rnettles's Avatar
United States, WA, Vancouver
Joined Jan 2012
I'm just getting started working with vinyl and I've heard good things about the printable vinyl from Expressions vinyl. It not only comes in the typical 8-1/2x11 sheets, but also have different sizes up to a 8-1/2 in by 5 yd roll.
I've just ordered some to try. The website is http://www.expressionsvinyl.com
rnettles is offline Find More Posts by rnettles
Old Jan 23, 2015, 01:37 PM
Joined May 2013
I respectfully disagree.
I buy the majority of my Oracal adhesive vinyl from expressions vinyl but judging from firsthand experience, the no name printable vinyl they sell is not nearly as good as the printable vinyl from the link I posted. It's very obvious if you were to work with both side by side as I have.
For one thing the expressions printable vinyl is noticeably thicker than the "contour" vinyl from Papilion. That can make it harder to cut and weed a more intricate design. More important, I also found the color saturation to be better.
bb
Old Jan 23, 2015, 01:47 PM
Joined Jun 2011
bb
Thank you sir. I appreciate all the info.
Old Jan 23, 2015, 07:03 PM
Citizen 46
rnettles's Avatar
Joined Jan 2012
The Quest for an Economical Vinyl Cutter
bb
Thanks bb for your thoughts. I haven't worked with either and never heard of anyone do a head to head between them. I'll order some of the Papilion as well.
Oh, and it appears the stuff from Texascraft is a little cheaper per sheet too.
Old Jan 23, 2015, 08:15 PM
Nergall's Avatar
Joined Aug 2009
Has anyone tried this with a laser printer??
http://www.texascraft.com/hps/Adhesi...ear-and-White/
Nergall is offline Find More Posts by Nergall
Old Mar 04, 2015, 09:21 PM
United States, NY, Mastic
Joined Jan 2009
Just a note-just picked up a Silhouette Cameo from Michaels for 179.99 plus tax. Seems they are clearing them out before the new model is released.
gman1185 is offline Find More Posts by gman1185
Old Mar 04, 2015, 09:48 PM
Joined Jun 2011
New model has been out since before Christmas I believe.
Sold Roland Stika 15" Vinyl Cutter FASTALJR Aircraft - General - Miscellaneous (FS/W) 5 Sep 12, 2011 04:25 PM
Discussion Vinyl cutter for decals etc.. The End Painting and Finishing Tips 3 Jan 16, 2009 05:47 PM
Vinyl cutter for making airbrush masks? mluniewicz The Builders Workshop 6 Mar 21, 2005 03:13 PM
Is there an economical radial mount for the AXI 2808 series? papasmurf Power Systems 1 Jan 24, 2005 07:05 PM
Need software for a stika vinyl cutter scp85 tbstep Aircraft - Electric - Airplanes (FS/W) 2 Jan 27, 2003 11:43 AM
