Old Apr 23, 2010, 08:20 PM
Roo2's Avatar
Joined Aug 2007
Good FPV Cam?
Hi,
Is this camera good for FPV?
http://www.securitycamera2000.com/pr...ed-Camera.html
If not please point me toward something that is better suited, good definition and good value?
Andrew
Roo2 is offline Find More Posts by Roo2
Old Apr 24, 2010, 05:18 AM
FPV-UK's Avatar
UK
Joined Feb 2008
Seems like you're trying to reinvent the wheel... There are thousands of security cameras available but only a handful have been used by FPVers consistently worldwide. If you choose one of these you know you'll be getting a known quantity which behaves well in an FPV situation (good light handling, etc) and there are loads of videos available online to see what you think.
You should consider the KX131, SN555, KX171 or the OSC camera which are available from pretty much all FPV stores.
All the best
Simon Dale
From FirstPersonView.co.uk
FPV-UK is offline Find More Posts by FPV-UK
Old Apr 24, 2010, 08:28 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Get a KPC - VSN500. Best know camera for FPV use. $75 and it comes completely encased. I believe 123 Security products sells them.
You could also watch this video on Ebay cameras and determine what you like for yourself:
FPV Camera Comparision video (7 min 14 sec)
IBCrazy is offline Find More Posts by IBCrazy
Old Apr 24, 2010, 12:30 PM
L14m's Avatar
Joined Apr 2009
Ibcrazy whats the KPC - VSN500 like for rf noise as im looking into getting a uhf rc lrs system and I hear they dont like rf noise from certain camera's. Also it looks very similar to the SN-555 camera!
Regards Liam.
L14m is offline Find More Posts by L14m
Old Apr 25, 2010, 01:19 AM
Roo2's Avatar
Joined Aug 2007
Thanks for your replies. I like the look of the VSN500 but it's NTSC. I think I need PAL for my region? Is this important?
Old Apr 25, 2010, 01:37 AM
http://drone-pilot.blogspot.fr
lovegroove's Avatar
Rhone Alps, France
Joined Aug 2008
It depends on how you plan to capture your flights. If you are going to use a video camera (miniDV or hi-8 or whatever) then you will need a PAL camera if PAL is the standard in your country. If you are using a digital recorder or USB capture, then most of these devices can record PAL or NTSC so it doesn't matter. The other consideration is what you are going to use as a monitor. I don't know of any video goggles that don't accept PAL and NTSC, but there are some LCD monitors that only do PAL or NTSC.
I'm in Europe where the standard is PAL, but have a mixture of cameras and all of my equipment is compatible with both video standards, apart from a portable DVD player that I bought in the US, which only works in NTSC and gives black and white images when used with a PAL camera.
lovegroove is offline Find More Posts by lovegroove
Discussion test- my rc controlled zoom cam fpv glassfox FPV Talk 77 Jul 31, 2014 07:06 AM
Gallery RC ADVENTURES - 1 D*MN GOOD RC VIDEO! Tachyon XC Micro Cam MEDiC2009 Car Talk 3 Apr 24, 2010 01:49 PM
Discussion FPV Cam ranges b-29er FPV Talk 0 Feb 14, 2010 12:45 AM
Help! Help with FPV cables to Cam and Tx Trackercal FPV Talk 4 Jan 31, 2010 05:05 PM
Discussion New FPV video_ how to get smother cam movements??? fpvbird FPV Talk 9 Sep 19, 2009 06:24 PM
