Old Oct 23, 2002, 10:42 PM
jbourke is offline
Find More Posts by jbourke
Administrator
jbourke's Avatar
United States, OR, Corvallis
Joined Nov 1998
anyone ever built a laser cutter?
I have been looking at CO2 laser kits and I think I could build a simple laser cutter for around $1500.
Has anyone ever tried this?
Jim
jbourke is offline Find More Posts by jbourke
Administrator
Old Oct 23, 2002, 11:14 PM
Quacker is online now
Find More Posts by Quacker
Sweet!
Quacker's Avatar
United States, CO, Longmont
Joined Jul 2001
Excerpt from old thread "How much does a laser cutter cost?"
"...I use a 3.5 KW excimer laser which I CA'd to a precision, high-speed XY flatbed plotter. I feed in the plans in a binary format derived from Autodesk's DXF format. The 20 megabyte on-board buffer in the plotter holds the entire file with room to spare. (I usually keep several menus form local Chinese takeout kitchens in there as well). I then place the balsa sheet on the plotter bed which has been enhanced by replacing the bed material with that from an air-hockey table with the air pump inlet and outlet swapped. Then I turn on what is now the vacuum pump. This holds the Balsa sheet flat and tight against the bed. I slip on my safety goggles and run up the laser onto a water-cooled graphite target until it comes up to full power, then I fire up the plotter. In about 2.5 seconds an entire piece of 1/16" x 3" x 36" wood is reduced to a highly accurate collection of ribs, gussets and other assorted parts. The entire setup only cost me about $175,000.00 to slap together! Since I've already built 3 planes this way, I figure it only cost me just over $58,000.00 each. (Seems reasonable). One last note: if you try this, don't forget to vent the vacuum pump outside or the smell of burning balsa might be overwhelming or even set off your smoke detectors. I also highly recommend that you keep your cat out of the room during the entire operation.
Q
Quacker is online now Find More Posts by Quacker
Old Oct 24, 2002, 05:10 PM
Coder is offline
Find More Posts by Coder
Balsa Member
Nashua, NH
Joined Aug 2002
Jim,
I've been thinking about the same idea. I may be oversimplifying but replacing the router with a 25 or 35 watt CO laser should do the job.
Have you located a source for the laser?
Coder is offline Find More Posts by Coder
Old Oct 24, 2002, 06:54 PM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
Yes, I found a kit on the web for about $1100: http://www.amazing1.com/laser4.htm
I don't think we are oversimplifying the situation at all. At its core, this is a very simple idea:
Laser Cutter = Laser + CNC Table
Hidden within that simplicity are a whole host of challenges.
I'm going to get my feet wet by building a dremel-based CNC tool of some kind. If I pick the right design it should be easy to mount a laser as well. Ideally the laser should remain stationary or move in only a single axis.
Jim
Administrator
Old Oct 24, 2002, 10:51 PM
foam_man is offline
Find More Posts by foam_man
Cupertino, CA, USA
Joined Jan 2001
The link is not active ?
foam_man is offline Find More Posts by foam_man
Old Oct 24, 2002, 10:59 PM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
Weird. It works for me.
Jim
Administrator
Old Oct 25, 2002, 10:38 AM
tom_yellowblue is offline
Find More Posts by tom_yellowblue
Sunnyvale, CA
Joined May 2001
Link worked for me too.
If only I had the space to set one of these up...
tom_yellowblue is offline Find More Posts by tom_yellowblue
Old Oct 28, 2002, 10:13 AM
CoClimber is offline
Find More Posts by CoClimber
Mountain Models Wannabe
CoClimber's Avatar
Ithaca, NY USA
Joined Mar 2001
A few things to consider:
The laser should be stationary which means mirrors places extremely accurately. Laser mirrors are expensive. If you try to move the laser, the cutter will be very slow. Alignment will be fun because you can't see the beam. I check my beam alignment by burning a hole in some masking tape.
You will need focusing optics. Also expensive. You will need to focus to within 1/32". 1/16" may be acceptable.
I wonder about the beam divergence on this $1100 laser. My laser tubes run around $5000. Universal laser (www.ulsinc.com)will only make a cutting bed that is 18" x 32" because once you get further away, the beam divergence starts to get too great.
This is a great engineering exercise. I started down this road and ended up just buying a real laser cutter. I've got a bunch of parts to a CNC router collecting dust in the garage.
Doug Binder
Mountain Models
CoClimber is offline Find More Posts by CoClimber
Old Oct 28, 2002, 04:12 PM
Gary Warner is offline
Find More Posts by Gary Warner
York Electronics
Gary Warner's Avatar
Dallas Tx USA
Joined Apr 1999
Hey Jim,
I'd love to work with you on making the CNC cutter (laser or router). Let me know if you want another hand. I'm fairly good at this kind of stuff.
My own latest project "idea" is to make a stand-alone "NC" foam wing cutter. It would not require a computer in the shop to run it. PIC CPU driven, 2x16 display and key pad, and with USB port to store airfoil data. Would be capable of holding 100's of airfoils and the can be modified (thickness, sheeting, cords, TE, LE, etc.) from the stand-alone controller. Not all the details have been considered yet.
Gary Warner is offline Find More Posts by Gary Warner
Old Oct 30, 2002, 09:32 AM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
Well, here is a great link for people interested in this project: http://www.emissiontechnologies.com/
They sell kits for a working gantry table and laser cutter. The total cost for complete set-up will be around $6,000 including laser.
Jim
Administrator
Old Oct 30, 2002, 10:43 AM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
These look like acceptable mirrors: http://www.edmundoptics.com/IOD/Disp...productid=1931
NT45-758 would be a good choice.
Jim
Administrator
Old Oct 31, 2002, 11:23 AM
DNA is offline
DNA
Find More Posts by DNA
DNA
registered user
DNA's Avatar
NE Ohio
Joined Jun 2001
Balsa laser cutting video...
http://www.pichler.de/okmodel/videos/lazercut.wmv
DNA is offline Find More Posts by DNA
Old Nov 03, 2002, 02:30 PM
AirBornOne is offline
Find More Posts by AirBornOne
Life-abstract=conformity
S.F. Bay Area
Joined Aug 2002
Laser Sites/Info
WOW!
My mind is whirling.
I understand now why a laser beam wing core foam cutter is impractical...
beam divergence.
Bummer.
Lase on all you creative geni.
AirBornOne is offline Find More Posts by AirBornOne
Old Nov 03, 2002, 06:33 PM
crossup is offline
Find More Posts by crossup
Senior to who? Member
crossup's Avatar
Annapolis, Maryland USA
Joined Feb 2001
CNC milling machine kit:
http://www.rcmodels.net/cnc/hobby/cnc.html
crossup is offline Find More Posts by crossup
Old Nov 06, 2002, 04:09 PM
jbourke is offline
Administrator
jbourke's Avatar
Joined Nov 1998
Ok, I located a sealed laser for about $1200 that will do the job. It's a surplus 35 watt laser with a variable power supply.
I'm going to spend some time drawing up plans for the table.
Administrator
Has anyone ever built a tango ? Mr_Flibble Fuel Plane Talk 0 Sep 22, 2004 03:41 AM
Anyone ever built one of these? Joe Ford Parkflyers 17 Dec 08, 2003 09:35 PM
Anyone ever built a electric version of 1/2A .049 A-10 from 1992 Model Airplane News? GWhaling Electric Ducted Fan Jet Talk 1 Oct 08, 2003 06:07 PM
Anyone ever built a JK Aerotech plane? squelchF18 Electric Plane Talk 6 Apr 27, 2002 09:04 AM
Has Anyone Ever Built One of These? Acer Electric Sailplanes 4 Dec 02, 2001 04:38 AM
