Old Mar 15, 2015, 06:59 AM
Goinav8n is offline
Find More Posts by Goinav8n
Jeff Carr
Ft. Mill SC / Charlotte NC
Joined Mar 2001
Hiperbipe
Well I have my Bill Hemple project just about done. I am the 3rd owner and have always liked this plane. I have had the motor for about 5 years just waiting for something to come along. I'm using a CC 160 HV controller with 12s 5000 packs. A 29x10 carbon prop. It may be over propped a bit but I'll give this combo a shot. Dual receiver batteries of A123 batteries.
Just a little more soldering to do
Jeff
Goinav8n is offline Find More Posts by Goinav8n
Old Apr 13, 2015, 07:50 PM
Goinav8n is offline
Jeff Carr
Joined Mar 2001
I Flew the Hiperbipe today. All went good. I have to see if low timing will help with the batteries. They were warm after the flight. ESC CC 160 was warm but not hot and the motor was cool.
I ran it on 12s and a 29x10 carbon prop. Very good power and only flew at about 1/2 power. Nothing real wild just a few rolls and hammer heads.
It seems to like rudder. I'm glad I know how to use it. It likes to skid in the turns without it.
I may prop down some as it might be just a little big. As I said there was good power.
Jeff
Old Apr 14, 2015, 12:22 AM
David Hogue is offline
Find More Posts by David Hogue
Go Dawgs!!!!!!!
David Hogue's Avatar
USA, NC, Clayton
Joined Feb 2001
Cool project Jeff!! Have always loved the hiperbipe. I remember Dave Blum saying his had some interesting quirks, but I cant remember what he said they were.
David Hogue is offline Find More Posts by David Hogue
Old Apr 14, 2015, 11:48 AM
Doug Bartley is offline
Find More Posts by Doug Bartley
Doug Bartley's Avatar
Canada, ON, Owen Sound
Joined Oct 2008
Nice Bipe!! How about some detail on the power system? Motor/brand/kv? Whats the motor rated for (max amps)? What does the wattmeter say? You did test this for amp and voltage, right? Batterys/size/c ratings?
I would not change timing if the motor runs fine as set. Losing synch will destroy things promptly!
Whats warm to you, can you hold the battery in your hand comfortably? Same with Esc, it will not likely run cold, especially at reduced throttle setting (all that switching going on), nything under 120 degrees is fine. Most people can't hold anything hotter than 105 or so without feeling uncomfortable. Doug B
Doug Bartley is offline Find More Posts by Doug Bartley
Old Apr 15, 2015, 11:08 PM
SteveT. is offline
Find More Posts by SteveT.
I fly, therefore, I crash!!!
SteveT.'s Avatar
San Jose, CA
Jeff
Lipo batteries that aren't getting warm aren't putting out any power. Warm yes, hot no....
SteveT.
SteveT. is offline Find More Posts by SteveT.
Latest blog entry: My hangar...
Discussion Sorrell SNS7 Hiperbipe DBlum Scale Kit/Scratch Built 41 May 03, 2007 08:42 PM
Hiperbipe flies (nope, no pix) Megowcoupe Scale Kit/Scratch Built 7 Oct 22, 2005 02:03 PM
Depron Hiperbipe build Curare Foamies (Kits) 32 Aug 18, 2005 02:24 AM
HiperBipe 3D/Pattern - CNC build electric-2000 3D Flying 26 Aug 17, 2005 02:31 PM
Idea WTB: MK Hiperbipe Kit Bob Radvansky Aircraft - Fuel - Airplanes (FS/W) 3 Feb 04, 2005 12:33 PM
