Old Aug 23, 2014, 05:38 AM
skyhulk is offline
Find More Posts by skyhulk
skyhulk's Avatar
Joined Jun 2009
how about a battery that get 25mins flight time for a 450 quad with gimbal gopro and fpv gear not that would be awesome
skyhulk is offline Find More Posts by skyhulk
Old Aug 24, 2014, 08:27 PM
plasoneal is offline
Find More Posts by plasoneal
plasoneal's Avatar
USA, OH, Hamilton
Joined Oct 2003
Experience with Puffing?
Looking for anyone with experience on these new BOLT batteries.
I've just finished a new EDF scratch build (http://www.rcgroups.com/forums/showp...&postcount=258) which basically I designed around the Nanotech 4s 2650 35-70c battery.
When I flew today, mostly flat-out for the full flight for the first time, when I landed my battery was extremely puffed. It was about a 3 1/2 minute flight, and the battery was pretty well exhausted. After it cooled for an hour or so, individual cells were around the 3.5 volt range.
Anyway, most 4s batteries out there are much "fatter", which simply won't fit my bird. The BOLT 2800 4s has almost the same dimensions as the Nanotech. At twice the price, I would hope its a substantially better battery. But can anyway tell me if the BOLT battery would solve my puffing issue? Obviously with the higher voltage, it could boost my performance a bit too... but if I continue to experience puffing like I just did today, it will litteraly split my fuselage open. (Battery sits on its "edge" in the fuselage, with not a lot of extra room.)
The current battery, looks like it drained about 2000 ma in those 3 1/2 minutes, so that should have been significantly less drain than the 35c constant rating... The battery is a couple years old, but only has about 12-15 cycles on it. Its never been "puffed" before, but it has gone down to its original size after cooling.
Thanks in advance for any perspectives.
Paul
plasoneal is offline Find More Posts by plasoneal
Old Aug 24, 2014, 09:00 PM
elecfryer is offline
Find More Posts by elecfryer
The 6 P principle works for me
elecfryer's Avatar
Ventura CA
Joined Aug 2007
So, I got to ask, can you check the IR of your battery (the one that puffed in your jet)? To the best of my knowledge, checking the IR of a lipo at around 72 degrees f is one of the best ways we have to determine the shape the lipo is in.
Additionally, running a lipo down to 3.5v per cell (measured after 1 hour rebound) means that the lipo was run down very close to 0% charge remaining (or 100% DOD, depth of discharge). This is not a good practice for lipo longevity! Puffing and excessive heating can result and, harm the lipo.
Michael
elecfryer is offline Find More Posts by elecfryer
Old Aug 24, 2014, 09:07 PM
desertstalker is offline
Find More Posts by desertstalker
Australia, VIC, Melbourne
Joined Feb 2010
You ran it below flat at a high rate, hardly surprising it puffed.
I dont see how the other packs will help, you need shorter flights or larger batteries.
desertstalker is offline Find More Posts by desertstalker
Old Aug 25, 2014, 08:13 AM
plasoneal's Avatar
USA, OH, Hamilton
Joined Oct 2003
Thanks to both of you for your responses. I'm certainly learning the nuances of electric flight as well as experimenting with this new bird.
After the fact, I fully agree that this particular flight pushed the battery too far... I was trying intentionally to push the plane for the first time... guess I just pushed it a bit too far (no room for my telemetry gear in the current fuselage).
I assume by IR you mean "Internal Resistance"? If so... I have a multi-function test meter, so I should be able to read the Ohms on it. What am I judging as good/bad? The battery has now completely lost its puffiness... so I'm hoping it isn't overly damaged from this flight, though I definitely want to avoid repeated stressing at this level. If checking the IR will help confirm that the batter is still "good", it would be good to know.
I generally don't like to run my lipos below 3.7 volts/cell (checking after landing). So as mentioned, I probably just need to cut back my flight time or cut back the time at WOT.
Last data point... after a full cooling period, I re-balanced the pack last night. It took about 2200 ma over a 90 minute charge time. As the pack is rated for 2650, it is just that I ran the discharge at too high of a rate? Perhaps with its age (~ 2 years) it just isn't up to the full 2650 capacity.
Thanks again,
Paul
Old Aug 25, 2014, 03:19 PM
green_flyer is offline
Find More Posts by green_flyer
we can take off without that
green_flyer's Avatar
London, UK
Joined Nov 2008
I don't know if this helps, I always fly by Tx timer, set to
60*0.8*Battery Capacity(Ah) / Max Throttle Amps
0.8 factor used for 80% of battery capacity
60 factor represents minutes
This way even if you fly at full throttle for the whole flight you know you should have 20% time in reserve just in case of go-arounds etc.
green_flyer is offline Find More Posts by green_flyer
Old Aug 26, 2014, 11:44 AM
plasoneal's Avatar
USA, OH, Hamilton
Joined Oct 2003
Originally Posted by green_flyer View Post
timer, set to
Thanks for sharing! Looks like a helpful formula.
I did have 3 flights in yesterday with the same battery. Keeping the flight timer set on 3 minutes along with a little throttle management seems to keep me out of trouble.
Still interestested in trying the new BOLT battery though, since the 2800 mah version has a very similar "footprint" to my current battery.
Here's a link of my last flight yestereday using the Nanotech 4s 2650 battery.
MacroSpot Flight 8 (3 min 36 sec)
Paul
Old Sep 08, 2014, 11:29 PM
flohio117 is offline
Find More Posts by flohio117
DroneWorksUSA.net
flohio117's Avatar
United States, TN, Clarksville
Joined Dec 2011
Has anyone tried the bolt batteries that has charged them to 4.35v per cell yet? I'm curious to see how they compare to standard 65c nano-techs.
flohio117 is offline Find More Posts by flohio117
Old Oct 12, 2014, 04:43 PM
RoninFPV is offline
Find More Posts by RoninFPV
Joined Mar 2014
I got 2 of the 3s 2400mah Bolts I just got a few flights but I have been charging them to 4.35v with my 308duo they seem good They are heavier then my 1800mah A spec g2 (159g) 2400mah Bolts (197g) and they seem to have a better punch also I am getting about 6-8 mins flights on a blackout mini H. That is with it power fpv gear and have a Gopro mounted on front for capture. 7-10 with out depending on flight style Hell for 1 dollar more I will buy more of these over the 1800 A specs G2 which I do like a lot Now interested to see how they hold up, I even ran one just above cut off today by accident forgot to reset voltage alarm. took it down to 2.90-3.1 a cell and it charged back up fine. It could barely keep the quad in the air with the Gopro at the end. wont do that again, But I must say until that point it was solid power. Uploading videos now to Youtube you can watch later does have some jello as i am just mounting the go pro with its standard sticky mounts. https://www.youtube.com/channel/UC7x...mdF5RsYnqVwaaQ
RoninFPV is offline Find More Posts by RoninFPV
Old Oct 12, 2014, 11:13 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
cool man I need to figure out how to up the power on my power lab 8 duo charger. I haven't built the quad to try the batteries on yet.
Old Mar 25, 2015, 08:40 PM
jmscard is online now
Find More Posts by jmscard
United States, ME, Portland
Joined Jul 2009
Originally Posted by everydayflyer View Post
Great then perhaps you or one of he moderators could combie all of the other Threads on this new LiPoly to this one. What I fail to see is how having numeriuos threads on the same new product / advancement helps the masses as the data is scattered here and there instead of being in one easier to read / Search thread.
Just so you know, the multiple threads also allow more exposure, and more people to chime in because they see the links.. if it was only one link few might see it.
I don't know about you, but the more info I can google and get answers and see enlightening threads that have many users not just advertisers/manufacturers info/advice on..... well that's what we are on a forum for, and if rcg has enough space to keep all these threads, well God bless them.
Lastly, one of mine and many here on this forums largest cost, and constant purchases is batteries, so I'm sure there are many that can attest its nice to get the lowdown on ANY advancements, I for one do love the fact our hobby gets more advanced every year... wonder what it will be like in 2020!!! Bet we'll have some real nice packs then!
jmscard is online now Find More Posts by jmscard
Old Mar 26, 2015, 03:46 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
By 2020 well all be flying fpv in 3D with 4k HD down link video standard lol. Lithium ion will probably replace lipo as things also become more efficient. Actually by 2020 the hobby will probably be band in the US, if the faa has there way!
Old Mar 26, 2015, 04:48 PM
Joined Feb 2010
They already have, only difference is we trade energy density for discharge rate.
Old Mar 26, 2015, 08:31 PM
DroneWorksUSA.net
flohio117's Avatar
Joined Dec 2011
They definitely haven't replaced lipos yet. I have a aircraft that flys on lithium ion but it still isn't practical. Li-ion batteries are extremely expensive still .they also can only fly aircraft that are extremely efficient. 99% of the people that fly fly on li-po still for these reasons. Lithium ion has made it a way to powering my ground station and my goggles though. That is a great use for them. As of right now lithium ion I'd say is another 2 years atleast from becoming even a little more mainstream.
Old Mar 26, 2015, 11:05 PM
Joined Feb 2010
Its the same chemistry, just that our "lipos" are designed for higher power output, this naturally makes them heavier for the same capacity.
The manufacturing process is not quite as good, hence the cheaper prices.
Sold Futaba SUPER T9CHP 9- Channel Transmitter, & NEW Turnigy LI-PO TX Battery Pack LADYHAWK13 Aircraft - General - Radio Equipment (FS/W) 0 May 17, 2014 04:52 PM
For Sale AGA POWER 5200Mah / 2S / 30C Hard Case Car Truck Li-Po Battery Pack Deans Ultra Giant_Scale_Gas Cars - Cars and Parts (FS/W) 0 Mar 12, 2014 07:40 PM
Sold DJI Phantom Battery - Turnigy 2200 mAh Battery Pack 11.1v 3s dotster77 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Feb 19, 2014 03:24 PM
Sold BRAND NEW Turnigy 2200mah 3s 25c battery packs. have 3 of them jasper7821 Aircraft - Electric - Batteries & Chargers (FS/W) 2 Nov 06, 2013 12:23 PM
For Sale Turnigy 9.6v 2000mah NiMH battery packs + exras Stradawhovious Aircraft - Electric - Batteries & Chargers (FS/W) 0 Oct 20, 2013 11:20 AM
