Old Feb 11, 2014, 04:48 PM
jeep1990xj is offline
Find More Posts by jeep1990xj
United States, NJ, Washington
Joined Jan 2011
Gallery
Guillows Fairchild 24 laser cut
This is my first post, I just wanted to show off my newest bird in the hanger. The Guillows Fairchild 24, kit# 701LC. Its converted to a 3 channel RET setup. I started building it about a year ago, I got about 90% complete then spring came and fishing got in the way of building. I finally picked it back up a week or two ago and finished it up. It uses the p-51 motor, gearbox and prop, a night vapor brick, and a 160mah single cell. pushrods are carbon fiber with heat shrink and really thin music wire. The airframe is all kit supplied wood, except where I had to make additional pieces for the conversion. The laser cut stuff was pretty nice compared to the older guillows kits, and I made no real attempt to lighten the framework. Covering is cheap red tissue from wallyworld applied with nitrate dope, pretty well slobbered with it actually, LOL. Looking back I should have used the supplied tissue as I ended up painting it anyway. The new tissue guillows is supplying is pretty decent. I did a few covering tests on some old beat-up airframes I had kicking around, it was easier to use with less wrinkles, it tightens up better and feels much stronger once finished. Final finish was some red and black testors put on mostly with an airbrush, wing struts and such were hand painted, they we're glued on bare after the airframe was painted and I just didn't feel like masking everything up again. Final weight (minus the battery I forgot to put in it) is 2 1/2 ounces, or 70 grams. As far as flying goes I was really surprised, she'll just float around on half throttle, control response at full throttle is a little twitchy cause of the prop wash but manageable. Landing is gravy, just cut power and let it be a guillows, don't touch the sticks till its almost on the ground, then give a gentle flare. I still can't believe how well everything turned out, I think the Fairchild was a good choice for the first crack at a guillows conversion, and I'm definitely sticking with laser cut stuff as much as I can.
jeep1990xj is offline Find More Posts by jeep1990xj
Old Feb 11, 2014, 04:59 PM
Bill Smudge is offline
Find More Posts by Bill Smudge
Bill Smudge's Avatar
United States, KY, Bowling Green
Joined Jul 2011
Nice job Jeep, on your little Guillows. Sounds like she's a nice flying plane.
Bill
Bill Smudge is offline Find More Posts by Bill Smudge
Old Feb 11, 2014, 05:27 PM
glewis is offline
Find More Posts by glewis
Or current resident
glewis's Avatar
USA, FL, Tampa
Joined Jul 2002
Welcome to rc groups and the wonderful addiction of converting Guillows kits!
Nice job and sounds like it flies very well too.
Glenn
glewis is offline Find More Posts by glewis
Old Feb 11, 2014, 05:54 PM
jonquinn is offline
Find More Posts by jonquinn
USA, PA, Westmoreland Co.
Joined Aug 2008
Really nicely done and a good write up too
jonquinn is offline Find More Posts by jonquinn
Old Feb 11, 2014, 09:02 PM
phillip57 is offline
Find More Posts by phillip57
S/E Michigan
Joined Jun 2010
What a delightful little model you have, thanks for posting!
phillip57 is offline Find More Posts by phillip57
Old Feb 14, 2014, 05:22 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Nice one!
I just put it up on 'the list'
Cheers - Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Feb 14, 2014, 03:57 PM
Joined Jan 2011
Thanks for all the compliments guys, and thanks for adding me to "the list". Must have browsed that list a hundred times. She's got about ten flight on her now. Been tough to get out flying, having one of the snowiest winters on record here in NJ. I did solve one of the biggest problems I've had with her. Transportation! Between narrow basement stairs, multiple doors, icy sidewalks, and a very threatening looking tailgate I've been more nervous trying to get it to the field than actually flying it. Figured I'd better do something before a door decides to try and eat a wing so I whipped this together the other night. Made with a few sheets of dollar tree foam and a bunch of foam packing material I saved from all my computer parts. Tossed in a few higher res pics of the plane too
Old Mar 23, 2015, 10:44 AM
Mustang86 is offline
Find More Posts by Mustang86
Joined Mar 2015
Jeep,
Beautiful job on you plane. I am currently building this same kit but only for display. This is the first kit in 30 years for me.
I have an extremely basic question regarding the sanding of the plane. This laser cut model has the markings for each of the ribs. Did you sand off the lettering? I started doing that and it seemed I had to make the ribs extremely thin to remove the markings. I have yet to find anyone else with this issue and curious how this is usually handled. Thanks for any help you can provide.
Mustang86 is offline Find More Posts by Mustang86
Old Apr 04, 2015, 11:48 PM
coulee is offline
Find More Posts by coulee
I FLY ORANGE!
coulee's Avatar
United States, SD, Tripp
Joined Jun 2009
Jeep, very nice plane!
Originally Posted by Mustang86 View Post
Jeep,
Jeep, very nice plane.
Mustang, I had the same issue with my build (HERE - finished tonight). I finally gave up and let the tissue and paint more or less hide them.
Where are some pics of yours?
Ted
coulee is offline Find More Posts by coulee
Old Apr 05, 2015, 04:41 AM
R31 Mark is online now
Find More Posts by R31 Mark
amidoinitrite¿ ¿
R31 Mark's Avatar
Joined Feb 2012
I love it man, looks so sweet!
R31 Mark is online now Find More Posts by R31 Mark
Build Log Guillows Laser Cut BF109 500 series build scigs30 Free Flight 11 Jul 12, 2014 09:36 AM
Build Log Guillow Fairchild 24 Konrad Scale Kit/Scratch Built 314 Jun 25, 2010 06:31 PM
For Sale Guillow's Fairchild 24 Free Flight Balsa Kit (reduced) greghol Aircraft - General - Miscellaneous (FS/W) 1 Apr 10, 2008 07:43 PM
Video Fairchild 24 Guillow's at work Lance Nordby Electric Plane Talk 0 May 11, 2006 02:28 PM
