Old May 23, 2015, 05:53 PM
suxi is offline
Find More Posts by suxi
Open Source It!
suxi's Avatar
Joined May 2013
Thanks a lot everyone for explaining the different power options. And thank you for pointing out to remove the jumper when using a power module.
Geoff, I didn't know a channel pass through was possible. That seems to be the best solution. What do you mean by splitting the power load between 2 sources? ESC for all servos and power module for apm and receiver?
happy returns
suxi
suxi is offline Find More Posts by suxi
Old May 23, 2015, 05:56 PM
Noircogi is offline
Find More Posts by Noircogi
United States, CA, Pleasanton
Joined Feb 2013
Yes, and that will happen normally if you remove the jumper, have the power module and an ESC or BEC on the servo rail. Just don't short the two back together via the power bus of your receiver or something.
The main point of the power module is to provide clean, filtered power to the APM which doesn't have noise on it from servos and other loads.
As I mentioned over in the Dragonlink thread, another option is to power your DL Receiver from the BEC/ESC/Servo rail of the APM and connect the servos there. In that case, you'd remove the middle wire of the PPM cable from your receiver to the APM. You'd also remove the top (signal) wire for the power connection between the servo rail and the DL rx.
If it's not clear, all of the ground pins on the servo rail are connected together. The same goes for the power pins and likewise the respective pins on the Dragonlink RX. So, connecting power and ground to any two of them will work.
Noircogi is offline Find More Posts by Noircogi
Old May 23, 2015, 06:33 PM
gbmarsh is offline
Find More Posts by gbmarsh
Wait...what?
gbmarsh's Avatar
Canada, BC, Abbotsford
Joined Sep 2010
happy returns
suxi
suxi, yes exactly right on splitting the power between the two sources.
For the rest, Noircogi has it covered
Just a note RCPassThru is only valid on CH5 and up.
http://plane.ardupilot.com/wiki/ardu...n_rc5_function
Cheers,
Geoff
gbmarsh is offline Find More Posts by gbmarsh
Old Yesterday, 12:08 AM
flipflap is offline
Find More Posts by flipflap
Joined Mar 2009
Originally Posted by gbmarsh View Post
Hmmm, I would leave the power module in place, remove the jumper, connect the servos to the output rail and set the 2 channels for those servos to pass-through in APM parameters. More complicated but then you retain the voltage and current sensor aspect of the power module and split the power load between 2 sources.
Cheers,
Geoff
Good idea, I didn't think about the pass-through.
flipflap is offline Find More Posts by flipflap
Old Yesterday, 12:17 AM
gbmarsh is offline
Wait...what?
gbmarsh's Avatar
Joined Sep 2010
I use it on my Bixler2 for my pan servo. I have a RMRC 7amp bec on the output rail powering 7 servos and a 3amp low noise bec on the input side to power the APM, MinimOSD, telemetry radio and rx. I don't use the power module at all, instead I opted for the separate voltage and current sensor.
Cheers,
Geoff
Old Yesterday, 01:58 AM
suxi is offline
Open Source It!
suxi's Avatar
Joined May 2013
Thank you guys. That helped big time! My two gimbal servos are currently assigned to ch5 and 6 so I should be fine.
Have a great Sunday!
Old Yesterday, 06:09 AM
jlander is offline
Find More Posts by jlander
jlander's Avatar
United States, FL, Gainesville
Joined Feb 2012
Flipflap, thanks al lot for the fast reply. So my idea of additionally connecting 5V and ground from the ESC the receiver wont work?
I don't know if anyone has already answere this question, so I'll tel you what I do. When I connect my receiver via ppm, I strip off the +5v wire and then connect a BEC +5v and ground to another channel on the receiver. This will prevent receiver brown outs.
jlander is offline Find More Posts by jlander
Old Yesterday, 08:10 AM
suxi is offline
Open Source It!
suxi's Avatar
Joined May 2013
Sooooo ... removed the jumper, updated ArduPlane to 3.3.0, configured passthrough for channels 5 and 6 and everything works like I dreamed it would ;-)
Again, thanks for your help!
@jlander, why would that be necessary? In my setup the receiver and APM should now get their clean power from the power module. All servos are getting their power from the ESC. So a brownout because of servos overloading the ESC should not be possible, should it?
Happy flying
suxi
Old Yesterday, 11:56 AM
gbmarsh is offline
Wait...what?
gbmarsh's Avatar
Joined Sep 2010
Happy flying
suxi
Nope, you should be golden at this point There are lots of different ways to power the APM, rx, sensors and servos though, nice to have that flexibility
@suxi, how about some pictures/details of your aircraft?
Cheers,
Geoff
Discussion Swapping electronics to HK Bixler or Bixler 2 High_Octane Beginner Training Area (Aircraft-Electric) 2 Apr 07, 2013 05:22 PM
Help! Need help with my FPV uav project. Soren64able Engines 9 Feb 02, 2013 04:00 PM
Sold HK Bixler with Retractable FPV Camera Mount....will trade crd FPV Equipment (FS/W) 4 Sep 24, 2012 07:39 PM
Sold FPV HK Bixler $35 Orcoz Aircraft - Electric - Airplanes (FS/W) 10 Aug 07, 2012 02:25 PM
For Sale Ardupilot Mega APM V1/900 MHz Xbee/Bixler Chassis - $300 shipped justjason Aircraft - Electric - Multirotor (FS/W) 2 Jul 13, 2012 01:22 PM
