Old May 02, 2013, 08:37 PM
Hammer is offline
Find More Posts by Hammer
United States, NC, Harrisburg
Joined Mar 1999
Aurora Problem?
OK, I went to bind a new receiver today, and turned off the transmitter. When I turn it on the light above switch turns yellow/orange for a second or two, then solid red with a continuous beep, nothing on the screen. I can turn it off, back on, same thing. What am I doing wrong?
Hammer is offline Find More Posts by Hammer
Old May 02, 2013, 08:42 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
Perhaps turned off and on again to quickly - did not give time to properly save
data/initialise same as laptops and many other computerized devices.
Please refer to:
. Aurora 9 - Off/On Switch problem or Screen does not Display?
- A9 Auto Saves (flash) each session's programming & trim changes on shutdown.
Allow time to complete task before switching on again.
ex Hitec USA Support Forum Sticky:
Aurora 9, AFHSS 2.4Ghz Module, Transceivers_Receivers & Telemetry,
- FAQ, Setups & Tips {Individual Links often updated}
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
A.T. is offline Find More Posts by A.T.
Old May 02, 2013, 08:57 PM
Hammer is offline
Joined Mar 1999
No, I have tried it several times, waited 30 minutes, tried again. Nothing. I unplugged battery, and plugged it back in. Also tried taking the module out and reseating it. Still nothing.
Old May 03, 2013, 12:26 AM
A.T. is offline
Joined Aug 2002
Sorry, should have noted previous post that the beep indicates battery may be to low.
Try recharging with either quick charger (or wall charger for at least 30 minutes) and try again.
If that still fails, refer direct to:
Hitec Warranty & Service - homepage.
Note: Hitec USA only services North/South America and Canada.
"Hitec USA customer service department is available Monday through Friday*
from 7am- 4:30 pm Pacific time. Reach us at 858.748.8440 or
service@hitecrcd.com any time you have a question"
• If you are from a country that is outside North and South America, please contact the
Hitec distributor in your country for service.
Alan T.
Old May 03, 2013, 08:45 AM
Hammer is offline
Joined Mar 1999
I took the battery out and it checked to 7.9v on a meter. I charged it for an hour or so, and same thing, constant beep. I took that battery(Eneloop) out and put the standard battery back in, and charged it for an hour, and nothing.
Looks like I might need service.
Discussion Problem Updating Aurora 9 Firmware E-Challenged Hitec/Multiplex USA 3 Jan 23, 2014 08:06 AM
Help! Hitec Aurora 9 Problem TomerNassi Radios 1 Mar 24, 2013 06:59 PM
Careful! Problem with Aurora 9 hexajuc Radios 1 Feb 23, 2013 02:24 PM
Discussion Aurora 9 Problem lougedo Hitec/Multiplex USA 3 Feb 22, 2013 02:22 PM
Discussion Brand new unused Aurora 9 gimbal centering and end point problem mahd Hitec/Multiplex USA 2 Jan 22, 2013 03:15 PM
