Old Feb 22, 2013, 03:10 AM
DJ41 is offline
Find More Posts by DJ41
DJ41's Avatar
The Netherlands, ZH, Nieuwerkerk aan den IJssel
Joined Jan 2013
Originally Posted by krijnberg View Post
still no Phantom software for the Mac. What a shame of DJI. Now I'm not able to turn on the IOC
Don't you have a bootcamp windows machine? You can install a trial version of windows 7 and then make the adjustments and delete the server afterwards. (When the trial period runs out)
DJ41 is offline Find More Posts by DJ41
Old Feb 22, 2013, 04:27 AM
CoolDevil is offline
Find More Posts by CoolDevil
Joined Nov 2012
Hi guys,
I have some good solution for the DJI Phantom jello
Winter Bike Duel Vol.3 - Pamporovo 2013 - trailer (0 min 45 sec)
P.S. I'll make it better this week
CoolDevil is offline Find More Posts by CoolDevil
Old Feb 22, 2013, 05:15 AM
Whig is offline
Find More Posts by Whig
Joined Feb 2013
My first test (second flight) with Phantom and GoPro 3 Black:
GoPro Hero 3 Black Edition and DJI Phantom Quadcopter (7 min 10 sec)
Everything was stock... is there too much jello on that video? My eyes can't notice it much but...
Whig is offline Find More Posts by Whig
Old Feb 22, 2013, 05:26 AM
DJI INNOVATIONS is offline
Find More Posts by DJI INNOVATIONS
Joined Jul 2011
Naza-M Assistant Software Error Code List
Here is the Naza-M Assistant Software Error Code List. Please read so that you can have a better understanding of the errors and how to fix it!
CFG-ERR
Configuration error, this may be caused by firmware upgrade from the old version, or abnormal Tx calibration. Re-calibrate your transmitter, power cycle your controller, and check all of the parameters.
VOL-LOW [4]
Voltage low
SN-ERR
Your S/N is not available, Please contact your dealer (Place of purchase)
VOL-LOW[6]
Voltage low
IMU-ERR
IMU ERROR,Please contact dealer. (Place of purchase)
X1-ERR
You’ve chose parameters tuning by X1/X2 channel with Tx Knob, but no signal detected on X1/X2 input channel, or Tx didn’t powered on.
X2-ERR
PMU-ERR
Please check the connection among battery, MC and PMU.
RX-ERR
Please make sure you are on the RC page of the NAZA Assistant Software, select the right receiver type or check the receiver connection, after that power cycle your controller to take effect.
COMPASS-ERR
Compass data is abnormal, please restart your Controller, if you still get this error, please contact your dealer (Place of purchase)
ERROR [25]
IMU initialization failure, may be caused by crash. Please contact dealer (Place of purchase)
ERROR [26]
Please perform Advanced Calibration.
ERROR [27]
GPS not calibrated, or magnetic field interference. Please calibrate GPS again in good condition.
Please contact your dealer for all technical support questions
We hope this answers your questions!
DJI INNOVATIONS is offline Find More Posts by DJI INNOVATIONS
Site Sponsor
Old Feb 22, 2013, 05:31 AM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
I am pretty sure you know SOMEONE with a windows machine. Ask around.
MCrites is offline Find More Posts by MCrites
Old Feb 22, 2013, 06:01 AM
Joined Jul 2011
Please Keep The Remindings in Mind about Phantom Flying.
1. Do NOT install any other equipments or covering on the top surface of Phantom, that will probably affect GPS signal and funtions.
2. Terrible crash of Phantom can cause internal sensor error or damage of main controller. please try to be careful to fly, and reach your dealer if you encounter this kind of problem.
Site Sponsor
Old Feb 22, 2013, 06:18 AM
Oztravels is offline
Find More Posts by Oztravels
Joined Jan 2013
Originally Posted by DJI INNOVATIONS View Post
Sharing Naza-M Assistant Software Error Code List here so that you can get a good knowledge of the errors and how to fix it!
CFG-ERR
Configuration error, this may cause by firmware upgrade from old version. or abnormal Tx calibration. Re-calibrate your transmitter, and power cycle your controller and check all of the parameters.
VOL-LOW [4]
Voltage low
SN-ERR
Your S/N is not available, Please contact our support!
VOL-LOW[6]
Voltage low
IMU-ERR
IMU ERROR,Please contact dealer or DJI for repair.
X1-ERR
Youíve chose parameters tuning by X1/X2 channel with Tx Knob, but no signal detected on X1/X2 input channel, or Tx didnít powered on.
X2-ERR
PMU-ERR
RX-ERR
Please may sure you select the right receiver type in the RC page or check the receiver connection, after that power cycle your controller to take effect.
COMPASS-ERR
Compass data is abnormal, please restart your Controller, if you still get this error, please contact the agent.
ERROR [25]
IMU initialization failure, may caused by crash. Please contact dealer or DJI for repair.
ERROR [26]
ERROR [27]
I have connected the assistant after my issue and it doesn't reconginise the Phantom. I am just getting beep, beep, beep, constantly with no lights. I would appreciate any help. The. David
Oztravels is offline Find More Posts by Oztravels
Old Feb 22, 2013, 06:33 AM
gervais is online now
Find More Posts by gervais
Made in Germany
Joined Feb 2013
ERROR [26]
What does this error mean, when this only shows up during Advanced Calibration, right after disconnecting the battery and vanishes by the end of cali ?
Message is:
Other ERR[26]
gervais is online now Find More Posts by gervais
Old Feb 22, 2013, 07:02 AM
JUCD VPR is online now
Find More Posts by JUCD VPR
SEMPER FI
JUCD VPR's Avatar
United States, IL, Belleville
Joined Oct 2006
http://www.youtube.com/watch?v=pIq8NkwnoVY
So I see you are taking off in the snow. How is your compass not getting wet? It's installed on the legs of the landing gear, I figured it would be buried in snow? Any problems?
JUCD VPR is online now Find More Posts by JUCD VPR
Old Feb 22, 2013, 07:27 AM
T J Gilbert is online now
Find More Posts by T J Gilbert
DJI and Empire Support
T J Gilbert's Avatar
United States, MS, Ridgeland
Joined Feb 2009
@ tanasit re: locknuts
Be careful using the flex top and special lock nuts that you have pictured.
These nuts are steel and, I believe, the Phantom/DJI motor shaft is aluminum.
Because these nuts use a mechanical pressure on the shaft threads to lock, they can potentially harm the threads on the motor shaft.
Their spring lock action actually causes something similar to running a die down over the threads.
A sure indication of this is aluminum glitter on the top of the prop...
Also, if that's red locktite on your modified DJI prop nuts, I'd be careful there too.
Many times it takes heat to get red to release.
FWIW locktite blue is adequate.
Also, it looks like some loctite might be getting on the prop.
Locktile will cause plastics to degrade...
T J Gilbert is online now Find More Posts by T J Gilbert
Site Sponsor
Old Feb 22, 2013, 07:29 AM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
Will someone pls link where I can buy one. The amazon storefront only shows Vcs hobbies and they take two weeks to ship per their store. Is rc drones .com legit? Tax return hit, one man party time. Links pls!!!
branflakes is offline Find More Posts by branflakes
Old Feb 22, 2013, 07:33 AM
MCrites is offline
Joined Jan 2012
I buy everything I can fron Tony at rc-drones.
http://rc-drones.com/dji-phantom.php
Old Feb 22, 2013, 07:35 AM
branflakes's Avatar
Joined Jan 2011
Party time thanks for fast link I'm about to have a good day gracias. That took ten seconds to complete, awesome.
Old Feb 22, 2013, 07:44 AM
MCrites is offline
Joined Jan 2012
Good luck and happy flying! Pretty much every order I have ever done with Tony has been at my door in like 3 days. You might be airborne next weekend!
Old Feb 22, 2013, 08:11 AM
branflakes's Avatar
Joined Jan 2011
One last q in prep planning. All I have for fpv is 900 MHz stuff, I planned on strapping the vtx to the opposite landing gear of the compass, think thats spaced far enough so it won't interfere?
Discussion DJI Quadcopter Frame BUILD Thread Quad_Addict Multirotor Talk 78 Mar 17, 2014 10:20 PM
Mini-HowTo POSTING VIDEO: How to Upgrade a Gaui 330x quadcopter with a DJI NAZA Lucidity47 Multirotor Talk 5 Jun 07, 2012 12:31 AM
Video Multiwii Quadcopter Dji F-450 frame Updated Video Anda Inc. Electric Heli Talk 1 May 23, 2012 02:51 PM
Discussion DJI S800 Spreading Wings has landed at Quadcopters UK Headquarters QuadcoptersUk Multirotor Talk 8 May 14, 2012 01:27 PM
