Old Jun 28, 2013, 09:34 AM
Ldm is online now
Ldm
Find More Posts by Ldm
Ldm
Ldm's Avatar
United States, PA, Conestoga
Joined Jun 2006
great job Ken , !!!
Ldm is online now Find More Posts by Ldm
Old Jun 29, 2013, 08:00 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Beautiful job, Ken. Good luck with the test flights.
D
Dereck is offline Find More Posts by Dereck
Old Jul 06, 2013, 06:17 PM
Ken Lapointe is online now
Find More Posts by Ken Lapointe
Build'em and Crash'em
Ken Lapointe's Avatar
Narragansett, RI
Joined Oct 2000
First Flight attempt
Thanks for all the kind words, I'm happy with the way it came out
Well the first flight attempt was less than stellar. Take off was fine, though a bit low on the power. I noticed the motor was louder than usual, that should have been my wake up call. But it was hot and I wanted to get the maiden done. Something happened with the speed controller, as you can see it did not fair well. On the first pass I noticed the smoke coming out of the plane, then on the turn the motor got quiet and it was belly land time. Some minor damage to the rudder was about all the damage to the plane. The plastic Cowl got melted a bit too.
So I took it apart and tested out the motor it was fine. Then I put the SBhobbies spinner pack on and noticed that there was alot of vibration on the motor. So the SB hobbies spinner gets tossed aside for now.
I did end up with a nice weathering effect behind the cowl thought
Time to try again next week I think.
Ken Lapointe is online now Find More Posts by Ken Lapointe
Old Jul 06, 2013, 06:45 PM
Gree is offline
Find More Posts by Gree
Gree's Avatar
Sydney, Australia
Joined Jun 2006
Bugger. Still vibration wouldn't cause the ESC to burn though would it? Over-propped?
Gree is offline Find More Posts by Gree
Old Jul 11, 2013, 03:57 AM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Ken , interesting thing .
I have the same spinner on an eflight 110. on the same plane .
I did not like the static testing on the ground and the larger two blade prop leave little room for error .
I so just this week I order two aluminum spinners from http://www.hobbylinc.com/ one for this plane and one for a Seafury .
They are not to bad in the scale shape department and when painted black they wont be far off but they will allow you to cut for what every prop you want to use from two to 5 blades .
Obviously I am going for three and they were relatively inexpensive vs comp spinners .
I hope the problem was not in the ESC, that is a good brand name and they need to deliver on quality especially when your paying more for the expected brand quality !
Old Jul 11, 2013, 07:34 AM
Narragansett, RI
Joined Oct 2000
I really believe it was the spinner being out of balance and causeing some addtional load on the motor.
It was a tried and true ESC that I have had for many years, so I dont think it was a controller issue. It was only a 13x10 prop, on 8S so not that big a load on its own.
I tried to put the SBhobbies spinner on a prop balancer but its too large to fit the ones I have.
I have an old P-51 spinner that has been painted black for inital flights. Once the plane gets flight tested then I'll proably get a 3 blade prop and cut the PICA spinner I have for this plane. And maybe even a new cowl
Old Jul 27, 2013, 01:29 PM
Narragansett, RI
Joined Oct 2000
Got 3 good flights on the plane today.
The eflite power 90 on 8S is plenty of power. Take offs are quick.
was well behaved in the air.
The split flaps work pretty well, the plane balloons a bit when the flaps are put down, I need to put some down trim in with the flap. Flaps don't seem to slow down the plane all that much, it floats down the runway.
My last landing was a bit hard and I can see a split in the top of the wing where the gear mount is.
I think the prop adapter on the motor is bent just a tad as it makes a bit of noise at the higher end, so I think I'll replace that.
All in all a nice plane added to the collection
Old Sep 27, 2014, 11:18 AM
Narragansett, RI
Joined Oct 2000
Well I've had a number of flights on the 190
Its a pretty smooth flying plane and the 8S power 90 is plenty of power
Some in flight shots
Old Sep 30, 2014, 09:01 PM
Ldm is online now
Ldm
Ldm
Ldm's Avatar
Joined Jun 2006
Congrats Ken
glad she is still a solid flyer !
Old Mar 11, 2015, 07:59 PM
Mitavec is offline
Find More Posts by Mitavec
United States, NJ, Pitman
Joined Jan 2011
I have a Pica FW190D9 kit on ebay for anyone interested:
http://www.ebay.com/itm/201302130632...84.m1555.l2649
Mitavec is offline Find More Posts by Mitavec
Old Mar 11, 2015, 08:54 PM
walter3rd is offline
Find More Posts by walter3rd
I just want to go fly!
walter3rd's Avatar
United States, MD, Towson
Joined Aug 2012
nice build!
walter3rd is offline Find More Posts by walter3rd
Discussion Alfamodel focke wulf 190 d9 dora GGRN Micro Ready-to-Fly 7 Jul 11, 2012 10:26 PM
Sold Pica Focke Wulf FW-190 D9 kit with extras jjscott Aircraft - Fuel - Airplanes (FS/W) 5 Apr 03, 2012 05:08 PM
Discussion Alfa Fw-190 D9 Dora sperry Electric Warbirds 22 Jun 19, 2007 01:25 PM
Video Fw-190-D9 "Dora" Maiden Flight Hans-Joachim Electric Plane Talk 0 Jan 07, 2007 11:58 AM
Discussion Top Flite FW-190 D9 Dora andernamen Fuel Warbirds 3 Oct 28, 2006 10:10 PM
