Old Mar 27, 2012, 11:33 AM
murdnunoc is offline
Find More Posts by murdnunoc
Victim of C.D.O.
murdnunoc's Avatar
United States, TX, Lubbock
Joined Oct 2007
Castle Bullet Connectors
I normally use Neu 6mm bullets for my battery-ESC connections. But I built up a plane for a friend of mine running a 200+ amp setup (Mega 22/60/1E, CC ICE 200, TP 7S 4400 65C) and we took it flying this past weekend.
He wanted to use Castle 6.5mm bullets because the LHS has them and they'd offer a little more current capacity than my Neu 6mm bullets.
During build and setup, I noticed the CC 6.5mm connectors are VERY tight to get plugged in, but when about halfway mated together, they get very loose, where they can wiggle and slide apart with very little effort.
Has anyone else found this??
The increased resistance of the loose connection is one concern for me.
But the biggest thing is that during the most recent flight, the ESC reset itself in flight. We heard the initialization chimes and cell count. Of course, no power during this restart!
A bit unnerving on a plane with a huge wing loading and the glide slope of a truck tire.
A look at the data log confirmed the restart, and there was no low volt, high amp, or other type of cutoff. Just restarted.
I have something of a trust issue with these connectors now.
Any thoughts are appreciated, as well as any good solutions.
murdnunoc is offline Find More Posts by murdnunoc
Old Mar 27, 2012, 11:52 AM
KRProton is offline
Find More Posts by KRProton
Tim Lampe; Hobbico R&D
KRProton's Avatar
Champaign, IL
Joined Dec 2009
I am using Castle 4mm bullets on my Sunracer that I set up last year. All of the bullets in the first three or four packages I orderd were IMPOSSIBLE to join together--way too tight. I was disappointed because they look like nice quality. I ordered several more packages (from our warehouse stock) and cherry-picked some good ones I could use.
They've been working great, but I did have to rummage through several to find enough good sets for my batteries.
Tim
KRProton is offline Find More Posts by KRProton
Old Mar 27, 2012, 12:50 PM
GeorgiMirov is offline
Find More Posts by GeorgiMirov
The props of tomorrow
Varna , Bulgaria
Joined Feb 2007
All 6mm connectors I have and I ever bought were very tight. So tight you cannot join them , and if you join them you cannot separate them. I use a 6mm lathe collet to press them until they start to join easily , but tight as well.
GeorgiMirov is offline Find More Posts by GeorgiMirov
Old Mar 27, 2012, 01:03 PM
vespa is offline
Find More Posts by vespa
Volunteer mud wrestler
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
By design, this type of connector makes contact only at the tips of the "fingers" which are flared out to a larger diameter to provide the spring force. This is why they are so difficult to get inserted, but once connected, they slide and wobble easily. What you describe sounds normal and I suspect your reset problem is due to a very bad solder joint or broken battery contact somewhere.
vespa is offline Find More Posts by vespa
Old Mar 27, 2012, 02:00 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
So "sliding and wobbling easily" couldn't be a cause for a brief connection loss?
I do notice the flared fingers of the male connectors. But this should result in a constant pressure as it slides into the female connector.
Since the pressure relieves as the male slides in, it seems to indicate the female connector increasing in diameter as it gets deeper
The ESC and battery are brand new, and the solder joints are well-soldered.
I know ESCs do occasionally do bad things but want to investigate the bullets, which are a red flag in my mind.
Old Mar 28, 2012, 01:12 AM
la528it is offline
Find More Posts by la528it
la528it's Avatar
United States, WA, Redmond
Joined Dec 2007
Go to pep boys and buy soe conductive greece, it makes it much easier for connection.
btw real men use 8mm connectors
la528it is offline Find More Posts by la528it
Old Mar 28, 2012, 02:22 AM
Peter M is offline
Find More Posts by Peter M
Peter M's Avatar
Newcastle, New South Wales, Australia
Joined Sep 2007
Murdo,
I have found that a marginal main battery connection can cause false error messages in my ICE controllers and cutouts: http://www.rcgroups.com/forums/showp...1&postcount=38 and http://www.rcgroups.com/forums/showp...3&postcount=58
I've also had the tolerances on some CC connectors I've bought to be excessive to the point of being unusable and had to be binned.
When they are good, they're good but when they are bad, they're horrible!
Peter M is offline Find More Posts by Peter M
Old Mar 28, 2012, 07:07 PM
jjmouris is offline
Find More Posts by jjmouris
Needs to do 52 legs !!
jjmouris's Avatar
Verenigd Koninkrijk, Fareham
Joined Aug 2008
I think you are speaking from your own experiance and are possibly not open to the idea that there might be some low quality connectors out there that don't really cut the mustard.
To me it sounds possible that the holes inside the female connectors could well be a bit wider deeper down leading to the problems described. Should be easy to figure out with a pair of calipers.
Funny that it should be the CC connectors and not the Hobbyking ones.
From the many Hobbyking 6mm gold connectors i have used, i have had 1 or 2 where the cuts where not nicely lined up but the other 98 of them where just fine and good for competative F5B (300A+) use.
I do plug them in and out 10-20 times with a pair of pliers before i even turn the soldering iron on.
jjmouris is offline Find More Posts by jjmouris
Old Mar 28, 2012, 07:16 PM
DownUnderPilot is offline
Find More Posts by DownUnderPilot
2012 NZ Speedcup - 231 MPH
DownUnderPilot's Avatar
New Zealand, Tasman, Richmond
Joined Mar 2006
With the 6mm HK ones, which I rate highly, if they are too tight you can squeeze the fingers in gradually with pliers or similar until you get the desired friction fit. Well that's what I had to do because they were impossible to separate once connected!
DownUnderPilot is offline Find More Posts by DownUnderPilot
Old Mar 28, 2012, 07:42 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Originally Posted by Peter M View Post
Murdo,
Peter, I believe I've run into the same issue you have. And it's a face-palm moment because I had your problems in mind when I set this thing up. Hoping it "wouldn't happen to me..."
I can measure the outside of the connector, but measuring the inside deep in the socket I don't know how to do. If the inside diameter really is larger than the outside diameter, then the only thing I'd be able to get with my caliper would be the I.D. right at the rim.
It IS the only explanation I can see, though, for the connector being tight initially, but loose once it's fully plugged in.
The Male connector does have a visible flare to the prongs. But it seems to not be enough to compensate for whatever flare there is to the female connector.
It seems also that it would be incredibly tough to machine/cast these female connectors with an inside diameter that's GREATER as you go deeper into the cylinder. But I guess that's not something for me to worry about...
I use HK 6mm bullets interchangeably with my Neu connectors. Love em!
I've had to squeeze opposing prongs on the male connectors, too. But I'd rather have a connector that starts too tight than one that can't hold a connection!
Old Mar 28, 2012, 07:48 PM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Right now I'm torn as to what to do about the issue.
I just plugged the plane up on the bench and started wiggling the battery connectors (pretending I was going through the air at 200mph )
It took a little while, but I did get the ESC to reset just by wiggling the connectors while fully plugged in. They're just too loose.
I can expand the Male connector with a knife blade to the point where it holds a tight connection, but then they're too tough to even plug in.
The only option I see short of an entire power system connector swap is to modify the connectors.
Maybe sanding a little cone shape onto the nose of the Male connector?
Combined with chamfering the lip of the Female connector?
Maybe that would make them possible to plug in, while still having the Male expanded enough to make solid contact deep in the socket.
But maybe that would be just as much work as a night of soldering to switch to Neu 8mm connectors.
Old Mar 28, 2012, 07:54 PM
vespa is offline
vespa's Avatar
Thousand Oaks, CA
Joined Mar 2004
It's reasonably easy to deliberately or accidentally machine the female sockets with an increasing radius since this type of machining is typically done on a lathe with a boring bar (single tooth drill bit of sorts). If the boring bar is fed in at an angle it will drill an expanding hole.
That said, I still think it's unlikely. Parts almost always err on the other end of the spectrum (flared opening) due to eccentricities in the tools or machines. But if you have metal calipers, give it a shot (with caution against shorting). Lock them at the I.D. and see if they wobble inside.
Old Mar 29, 2012, 04:56 AM
jjmouris is offline
jjmouris's Avatar
Joined Aug 2008
Why switch to 8mm?
Don't you have any 6mm? Time to order some more from Hobbyking or Neu?!
Old Mar 29, 2012, 08:33 AM
Victim of C.D.O.
murdnunoc's Avatar
Joined Oct 2007
Why switch to 8mm?
I do have a whole pile of 6mm connectors. But didn't feel great about them at 200+ amps. I'm sure they'd be OK. But the battery wires are already longer than I'd like so I'm going for every resistance drop I can get
There's not really any installation space issue, so I see the 8mm bullets as a benefit with no drawback.
Old Mar 29, 2012, 08:48 AM
sneu is offline
Find More Posts by sneu
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
We use them all the time for high current applications in F5B that can be over 400 amps.
Steve Neu
sneu is offline Find More Posts by sneu
Sold 8 rctimer 30amp esc with bullet connector 70$ windfou Aircraft - Electric - Multirotor (FS/W) 1 Mar 24, 2012 10:49 PM
Question Soldering vs Bullet Connectors AusTelemetry Multirotor Talk 39 Mar 13, 2012 03:45 PM
Wanted looking for some 5.5mm bullet connectors lv2soar Aircraft - Electric - Batteries & Chargers (FS/W) 1 Mar 13, 2012 06:36 AM
Discussion Castle Creations Bullet connectors squigg Multirotor Talk 0 Feb 01, 2012 02:36 AM
For Sale Wholesale connector is back! - 3.5mm bullet connector: $65 /100 pairs shipped ildo Aircraft - General - Miscellaneous (FS/W) 6 Jun 30, 2006 10:02 AM
