Old Mar 14, 2012, 11:21 PM
overmyhead is offline
Find More Posts by overmyhead
United States, FL, Bradenton
Joined Jan 2012
Low battery alarm question?
Do those cheap little Chinese Ebay $5. plug-in onboard low battery voltage alarms really work and can you hear them o.k.?
overmyhead is offline Find More Posts by overmyhead
Old Mar 14, 2012, 11:27 PM
Ranandar is offline
Find More Posts by Ranandar
Ranandar's Avatar
Kentucky
Joined Dec 2008
The ones with two buzzers work OK.
You can hear them on a fly-by.
Kind of depends on how good your ears are though.
Ranandar is offline Find More Posts by Ranandar
Old Mar 15, 2012, 12:01 AM
sgomes is offline
Find More Posts by sgomes
Alameda, CA
Joined Dec 2006
A waste of money in my opinion.
Find out how much time others are getting with the various batteries, and set your timer for somthing less than that. When you charge your battery, note how many mah you put back. If it was less than 80% of the rated mah for the battery, you know you can add a little flying time; if more than 80% you need to cut back.
Steve
sgomes is offline Find More Posts by sgomes
Old Mar 15, 2012, 12:51 AM
ffinybryn is offline
Find More Posts by ffinybryn
Crash or unscheduled landing?
Joined Dec 2011
I have one and it works great. I was originally landing my plane after 10 minutes so as to be sure not to run out of power, but managed 20 with the alarm.
Initially, I kept flying low fly-bys to try and hear it, but when it went off I could hear it easily from quite a distance. There was minimal background noise.
ffinybryn is offline Find More Posts by ffinybryn
Old Mar 15, 2012, 02:24 AM
flydiver is online now
Find More Posts by flydiver
flydiver's Avatar
United States, WA, Seattle
Joined Jan 2007
I got one of the single speaker ones that also change LEDs from green to red. Used in a pusher delta (admittedly not quiet but not a screamer) I can neither hear the alarm nor see the lights in daylight even at close range. Might work in a quiet plane.
flydiver is online now Find More Posts by flydiver
Old Mar 15, 2012, 03:41 AM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
I had a similar one in my heli, and couldn't hear it until the motor stopped. I now use a timer which activates a bank of leds on the heli, 'cause I can't hear the timer beeper on my trannie either while the heli's up close.
abenn is offline Find More Posts by abenn
Old Mar 15, 2012, 08:55 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
I've tried one with two beepers, and it's not very good. It's not very loud and the trigger voltage seems a bit odd - maybe there are different levels and different beep codes, but it doesn't seem very predictable.
OTOH I've got one of these (http://liglow.com/Liglow.htm) on my heli and it's great. The beeper is huge (30-40mm diameter, looks similar to the one from a smoke alarm) and easily audible over a 450 size heli doing aerobatics. If often causes people 100m in the pits to check their chargers.
RobinBennett is offline Find More Posts by RobinBennett
Cool New! MaxAmps.com LiPo Battery Tester and Low Voltage Alarm brandonwilcox Batteries and Chargers 9 May 14, 2012 10:56 PM
Discussion At what voltage should my low voltage alarm sound? Physics_Dude Multirotor Talk 5 Mar 12, 2012 03:07 PM
Discussion On-board low voltage battery alarm question---again Barbosa2 DIY Electronics 3 May 29, 2011 06:27 PM
Cool Build A Simple Low Battery Audible Alarm Circuit Levent Suberk DIY Electronics 0 Aug 22, 2006 02:35 AM
Futaba 9C super false low battery alarm laum Radios 3 Nov 07, 2005 02:29 PM
