Old Jan 19, 2013, 12:17 PM
David Parry is online now
Find More Posts by David Parry
It only cost 50 honest!
David Parry's Avatar
United Kingdom, Bracknell
Joined Oct 2007
sd card
think I may have killed my 4gb card. Forgot and tried to format it with windows xp. now although it appears in the list, whenever I try to acces it it locks up. tried formating on my mac same thing. tried sd formatter that locks up also. running h2testw but that doesnt seem to be doing anything either. is it dead or can I get it working?
David Parry is online now Find More Posts by David Parry
Old Jan 19, 2013, 12:22 PM
victapilot is offline
Find More Posts by victapilot
Just thumbing through...
victapilot's Avatar
United States, SC, Simpsonville
Joined Feb 2009
Try formatting in a camera, such as Canon, etc. I saved one this way.
victapilot is offline Find More Posts by victapilot
Old Jan 19, 2013, 02:17 PM
Tom Frank is offline
Find More Posts by Tom Frank
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Is it a newer Sandisk card by any chance. They are subject to being put in a write protected state for which there is no recovery. But Sandisk will give a free warranty replacement. I've had two like this so far.
FWIW, I always format the card I'm using in the #16 with the camera's own formatting routine.
Tom Frank is offline Find More Posts by Tom Frank
Old Jan 19, 2013, 04:05 PM
Joined Oct 2007
think you may be right Tom, tried every device that will take a SD card in the house, and sometimes get a message that the card is locked. It is a sandisk one, about 3 or 4 yars old. Will contact sandisk and see what they say, but probably best to just get a new one. dont have a number 16 (yet) just a 3 and 11 so cant try formating in the camera.
Old Jan 19, 2013, 04:23 PM
Joined Oct 2007
changing the subject Tom just made the battery box you detailed, thanks for that. what do you use to charge the batteries insitu?
Old Jan 19, 2013, 07:53 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
I use my all-purpose RC battery charger which can charge most all battery chemistries. I made the battery cable short with a small gendered plug (micro Dean's plug if you are familiar with those). The I have two extensions that connect to that plug. One is an old USB cable with flakey data wires, but good power wires for powering the camera, and the other terminates in a full size Dean's plug to mate with my charger cable. The micro Dean's plug can easily handle the AAA cell 1C (800 mA) battery charging current.
Old Jan 21, 2013, 05:55 AM
Bill Glover is offline
Find More Posts by Bill Glover
Bill Glover's Avatar
Joined Nov 2000
Apologies if already posted, but I tried searching and couldn't find the answer!
Has anyone measured the current draw when recording?
Thanks in advance
Bill Glover is offline Find More Posts by Bill Glover
Old Jan 21, 2013, 09:39 AM
Isoprop is offline
Find More Posts by Isoprop
Joined Nov 2010
Thanks in advance
Since the #11 uses the same processor as the #16 I would assume the current draw to be the same as the #16 which is between 220mA and 300mA. That is with video-out disabled. Current draw while charging will most likely be different than the #16 since the cameras use different charging ICs.
The above figures are based on a #16 post I wrote here which I originally posted at the beginning of January 2012.
Isoprop is offline Find More Posts by Isoprop
Old Jan 21, 2013, 10:59 AM
Joined Nov 2000
Thanks Isoprop.
I'm looking at running one from a 5V booster/regulator to eliminate the weight of the internal cell, but the small/light ones are commonly limited to 200 mA. I didn't think that would be enough.
Old Jan 21, 2013, 01:22 PM
empeabee is online now
Find More Posts by empeabee
Fidler & twidler
empeabee's Avatar
Cranfield U.K.
Joined Mar 2004
Thanks Isoprop.
AnyVolt?
Half an amp Mike
empeabee is online now Find More Posts by empeabee
Old Jan 21, 2013, 01:34 PM
Joined Nov 2000
Thanks, will have a look at that.
Old Jan 22, 2013, 07:53 AM
e_lm_70 is offline
Find More Posts by e_lm_70
Austria
Joined Jan 2004
Thanks Isoprop.
A regulator and the internal cell, have a similar weight ...
Either you use directly 5V bec from your radios gear ... or if you run on 1S .. you can get directly the power ... as well .. if you use a lipo 2S or more ... you can take 1S Lipo from the Balancer connector.
So ... no need for any extra HW on my view
e_lm_70 is offline Find More Posts by e_lm_70
Old Jan 22, 2013, 09:13 AM
victapilot's Avatar
Joined Feb 2009
Only problem with tapping into the balance connector (which I have done also), is that if voltage drops below 3.6 v, the camera will quit and the video file may be lost. That can happen even when the battery is still half charged due to a sudden load as in acceleration.
Old Jan 22, 2013, 02:20 PM
Joined Nov 2000
Currently looking at this 5V boost regulator for 1.5 grams:
http://www.active-robots.com/bodhila...or-square.html
Think that's significantly lighter than the internal LiPo.
This is for a micro quad flying on 1S. I have already tried running it from the flight cell but the camera shuts down after about 90 secs due to the voltage drop under load. A boost regulator will stop that.
Old Jan 22, 2013, 03:03 PM
e_lm_70 is offline
Austria
Joined Jan 2004
http://www.hobbyking.com/hobbyking/s...idProduct=7565
This or similar (70mAh or 80mAh) .. look better match
I guess you run your #11 naked
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 30, 2010 11:40 PM
Found found beladog FPV Equipment (FS/W) 1 Oct 30, 2010 01:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr FPV Talk 8 Oct 10, 2010 07:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 07:10 AM
