Old Mar 09, 2015, 02:41 PM
bigmoebbq is online now
Find More Posts by bigmoebbq
bigmoebbq's Avatar
United States, GA, Atlanta
Joined Mar 2008
I bought one of these a few months back. It is all stock but when I went to fly it it seems like l needed a ton of aileron trim to get it to fly straight and level. Anyone else have this issue? I like this plane, it is no MPX BLizzard but will scoot fine. I really do miss my Blizzard though.
bigmoebbq is online now Find More Posts by bigmoebbq
Old Mar 09, 2015, 02:54 PM
FireHawx is offline
Find More Posts by FireHawx
FireHawx
FireHawx's Avatar
United States, NV, Reno
Joined Oct 2011
If you read back in the thread, some have wing warp issues. It was common. I thought it was correct by now. If you look back i believe some found a fix for this, not sure. Mine would pull when i came out of step dives but it wasn't as bad as some have had.
FireHawx is offline Find More Posts by FireHawx
Old Mar 09, 2015, 10:07 PM
Lou is offline
Lou
Find More Posts by Lou
Lou
Ground Penetration Tester
United States, VA, Waynesboro
Joined Dec 2005
Part of the problem as I recall is that one wing was often thicker than the other wing. This was due to the construction of the wing.
My Blaze disassembled itself one day during a loop and I discovered the wing is actually composed of several foam and spar parts that are all glued together to make a wing. I would suspect that the 'fit' during the gluing process is fouled or the moulds are off.
Some of the planes that had good wings had poor mounting at the wing saddle and poor decalage.
Lou is offline Find More Posts by Lou
Old Mar 10, 2015, 04:44 AM
slothy89 is offline
Find More Posts by slothy89
Head in the clouds
slothy89's Avatar
Australia, VIC, Sebastopol
Joined Apr 2012
It's foam, and it flies like foam. Enjoy it for what it is
I flew the tits off my Dynamic-S on the slope, no motor, and now I've moved onto better models I put the prop back on for something different.
Even with 40% left trim its a good slope trainer
slothy89 is offline Find More Posts by slothy89
Discussion X-models xray sport hotliner details needed. stevext Electric Sailplanes 1 Nov 03, 2014 02:34 PM
Discussion ST Models Fox EP ARTF Kn0bby Electric Sailplanes 10 Jun 29, 2011 10:42 PM
Sold ST models RTF Cessna avoidingexpert Aircraft - Electric - Airplanes (FS/W) 2 Jan 25, 2010 05:15 PM
Discussion ST Models DG1000 Elite Aerial Photography 0 Dec 20, 2009 11:07 PM
Discussion ST Models Piper Cub EP ARTF Baz Ck Electric Plane Talk 0 Sep 02, 2009 10:37 AM
