Old Jan 07, 2011, 02:06 PM
RADAR_66's Avatar
Detroit, MI
Joined Dec 2010
lil vid with the 808HD
HD key fob cam snow vid (0 min 20 sec)
RADAR_66 is offline Find More Posts by RADAR_66
Old Jan 07, 2011, 03:44 PM
Dance the skies...
Tom Frank's Avatar
United States, MA, Walpole
Joined Dec 2003
Originally Posted by autorail1 View Post
Im using QuickTime Player. I cant get it to open on Media Player at all on 2 different computers. 1 Computer on Vista the other on XP
Thanks. I sent an email to my vendor contact about this to see if he might have seen this before. I'm guessing the file is not getting closed properly. I'd try to duplicate the issue with a different flash memory card if you have one just to rule out a problem with the card.
Tom Frank is offline Find More Posts by Tom Frank
Old Jan 07, 2011, 04:07 PM
define("BEASTMODE", "1");
KeithLuneau's Avatar
United States, LA, Moreauville
Joined Jan 2002
Another video with the HD 808... I'm really really happy with this little camera, and I just got it yesterday...
808 HD camera test, flying the EXI 450. (8 min 43 sec)
KeithLuneau is online now Find More Posts by KeithLuneau
Old Jan 07, 2011, 04:08 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Originally Posted by mavlo77 View Post
Thanks Tom for this correction! You're absolutely right! I was a bit too frustrated I think .
The frustration is understandable. My Transcend flash cards have a lifetime warranty against defects in materials or workmanship. Not all manufacturers have this, but maybe you can get a warranty replacment for yours?
Old Jan 07, 2011, 04:50 PM
Gravity - It's the law
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
I dunno Pirate,
I see vignetting, slight out of focusiness and your blades look bent as bad as mine were back in the reg keyfob thread
Just joking, ain't these things neat.
Good video, strap that puppy to the EXI and let's go fly!
btw, what flavor of Futaba is that? I use a 12MZ
Yabba
Yabba is online now Find More Posts by Yabba
Old Jan 07, 2011, 04:51 PM
Yabba's Avatar
USA, CO, Denver
Joined Jul 2008
Originally Posted by RADAR_66 View Post
Brrrrr
Old Jan 07, 2011, 04:57 PM
Joined Jan 2002
Yabba
Mine is a humble old 9CAP, the original and not the Super. I bought it when I started getting more into FPV, and absolutely love it! One of these days I'll get my hands on a newer one. If I ever win the lottery I'll pick up a 14MZ... Seriously though, the 9C is a great radio, and pretty much all I need!
Old Jan 07, 2011, 05:30 PM
RADAR_66's Avatar
Detroit, MI
Joined Dec 2010
Brrrrr
Yess it 22*f right now
Old Jan 07, 2011, 05:52 PM
mavlo77's Avatar
The Netherlands
Joined Oct 2008
Originally Posted by victapilot View Post
I have seen where folks have reformatted a non-responsive card in a camera (with format feature such as Casio), then it works. You say you tried PC's, which use complicated registry witchdoctoring, cameras might find the card easier and execute a reformat. Easy and safe to try!
Good luck!
Thanks, I tried this. But my photo camera locks up.... Can't even reach the menu to format it... Then I tried my cellphone, it says the card is unknown...
Then I have started a live distribution of Linux Gparted. But the card is invisible there. Nor from my integrated card reader as from the external USB reader.
So.... I think I need to try plan B (returning the card).
I won't pollute this thread much more with my card issues. Thanks for all suggestions!
Let's continue to share knowledge about the HD camera .
mavlo77 is offline Find More Posts by mavlo77
Old Jan 07, 2011, 07:44 PM
United States, IA, Mason City
Joined Oct 2008
I can only wish for such warm, inviting weather :P It will hit -5f (-20f with wind chill) tomorrow. And I intend to go throw my Stryker in the air!
Now if only I had a nice 720p camera to attach on it... although it probably wouldn't work. All three of my #3's die within 30 seconds of taking them outside, even if I'm very careful to keep them warm. Cold + cheap 1s lipo is not a good combo.
Acorns is offline Find More Posts by Acorns
Old Jan 07, 2011, 08:00 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
LAst suggestion before you return the card. Did you try to use the special SD card formatter with it? I don't know if it will do any different, but it is designed specifically for formatting SD cards.
Old Jan 07, 2011, 08:08 PM
United States, DE, Wilmington
Joined Jun 2007
Just tryed a different card and it does the exact same thing for any player I use.
autorail1 is offline Find More Posts by autorail1
Old Jan 07, 2011, 08:30 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
So far no one else has tried to duplicate your problem and post their findings here to see if it's a common problem with other HD key cams. I hope mine will arrive tomorrow and I'll be trying it for sure.
Also, have you done the date removal firmware replacement? I'm wondering if your firmware got corrupted somehow, and if the new "no date stamp" firmware would fix it? If you've read the link in the FAQs (post #3) page, you know there is a risk of bricking your camera doing this if it's a very early version. But the vendors have implied they will replace one that is bricked by this process, so you don't have much to lose by trying it.
Old Jan 07, 2011, 08:47 PM
Joined Jun 2007
I have not done anything to the cam except record.
Old Jan 07, 2011, 10:13 PM
Dance the skies...
Tom Frank's Avatar
Joined Dec 2003
Tips For Editing with AviDemux
I have done some editing of the HD key cam .MOV files using the latest version (V2.5.4) of AviDemux, and have the following tips that might save you some time and/or frustration:
Main Window Configuration
I like the two-pane display showing the Input Video and Output Video after your edits, like Vdub does. AviDemux can do this, but it doesn't default to that mode, nor can you save it in a configuration setting. The Window top tool bar has the pane orientation selection icons, and the pane sizes have to be set using the "View/Zoom Ratio" menu. Pretty clumsy at best.
"H.264 Detected" Alert
This alert box pops up whenever a video is opened that uses the H.264 video codec like this camera uses. I've always clicked on "no" to reply to this with no problems, fearing what the "loss of frame accuracy" might do. I found that doing this when I loaded back in a file I had just output which had been re-encoded with the MPEG-4AVC (H.264) codec option caused the program to crash! When I reloaded it and selected "yes" the file loaded fine, so sometimes you don't have a choice. I need to do some more testing to see how/if selecting "yes" every time affects the final video.
Sound Issues
The audio codec used in the .MOV file is not a mainstream one in the PC world. I've had troubles with it not working when using the direct "Copy" selection in the main editing window. I now routinely output all my files by selecting the "MP3 (lame)" option in the selection dropdown box under the Audio heading. It is NOT "lame"... EVERYTHING today plays MP3 files!
Sometimes when re-encoding the native .MOV file the sound is intermittant and breaks up while playing the video during editing. Not to worry... it always seems to play fine in the final saved video. Similarly, reloading a file that you just saved can result in some strange sound during playback in the editor, like the sound track plays at several times normal speed! Again, it always plays fine after you save out that revamped file.
Output File Naming
When you output a file you will be prompted for a file name and location. Be sure to add the file type suffix for the format you chose to the end of the file name when you type it in. AviDemux does NOT do this automatically (but it should!), so if you leave it off, there is no file suffix to call up your media player to play when you click the icon. You can also change the file name after you save it to add the suffix if you forget.
Simple Trimming
Clipping of unwanted sections of a video can be done without re-encoding the video... just leave the default drop down box set for "Copy" under the Video heading.
Use the orange "A" and "B" icons at the bottom of the window to set the beginning and end of the section you want to trim. The selected range will be highlighted with a blue outline on the timeline slider. Hitting the "Delete" key or selecting the Edit/Delete menu option will delete that portion. You can drag the timeline slider to quickly get near your trim points, or take short steps to get there with the left or right arrow keys. I've had an alert pop up on occasion when saving a file after trimming the first part of a file, saying the "the video does not start on a key frame". A key frame is the first full image that is used to define the next series of compressed frames, so if it's not there, the subsequent frames have no reference and the program will abort the output. The easiest way to make your cuts at a key frame seems to be to use the arrow keys to step to your final trim point before setting your "A" or "B" markers.
When outputting a simple trimmed, direct copy video file, DO NOT use .AVI file format... it will not work properly. You will need to re-encode the video to do that. Set the output to "MP4" in the dropdown box under the Format heading.
Improving Video Fidelity With Filters
Most of these cameras are set to record with over-saturated colors and with a high contrast setting. While this produces very vivid colors, it also looks somewhat un-natural, increasing the visibility of a central "hot spot" and darkening of the corners in the video. Applying several filters built into AviDemux editor can eliminate most of these undesired artifacts.
Some users prefer the very vivid colors the #11 camera produced. This post gives novices step-by step instructions for boosting the #16 colors to more closely match the #11 camera.
Re-encoding Video
It is necessary to re-encode the video whenever a direct copy into a different file format doesn't work properly (e.g. .AVI), or when you want to use a filter to modify the final video characteristics. Some useful filters you might consider are sharpening, color correction, brightness/contrast tweaks, cropping, and re-sizing. There are a lot more. Access them via the Video/Filters menu, highlight the ones you want, and click the green "+" icon to activate them for the output. I won't try to explain their individual settings that will pop up when you select one... best suggestion is to play with them to see what they do.
My best advice is to always output to the MP4 Format using the MPEG-4AVC (i.e. H.264) Video Codec and the MP3 (Lame) Audio codec. This will produce the most consistent and reliable results. All my video players and editors for Windows 7 will import and use MP4 files except Vdub. You can output the re-encoded video into an .AVI format so Vdub can load it, but there's really no need to unless Vdub can do something better than AviDemux. I haven't found anything yet other than interact with AviSynth scripts to do some fancy combining of multiple videos. But I have a commercial editor that I would normally use for that.
The "Configure" button under the Video Heading gives important toggles for the MPEG-4AVC codec. The only ones that need changing from the default settings for good results are the "Encoding Mode" under the "General" tab. The dropdown box gives 5 options. I have tried them all, and the two that produce slightly better results are the "two pass" options. I think the "Average Bitrate (two pass)" option is just a tiny bit better and easier to configure. Select that one and type in "7000" for the value in the "Average Bitrate" box. That is the approximate average bit rate that this camera normally produces, and will make your final output quality virtually identical to the the original.
If you need to reduce your final file size, you will need to reduce the average bitrate number which will reduce the video quality. An easier way to get a specific file size is to select the "File Size (2 pass)" Encoding Mode, and enter your desired file size in the Target File Size box.
Last edited by Tom Frank; Jan 31, 2012 at 12:37 AM. Reason: added more sound peculiarities.
Video Samurai with key cam AeroNut45 Electric Plane Talk 2 Oct 30, 2010 11:40 PM
Found found beladog FPV/RPV - Equipment and Vehicles (FS/W) 1 Oct 30, 2010 01:01 PM
Discussion Any sign of True real time HD FPV gear....not secondary HD CAM ???!! khaled_abobakr Video Piloting (FPV/RPV) 8 Oct 10, 2010 07:13 AM
Mini-Review Key Chain Cam for your autogyro!!! imsofaman Auto Gyros 7 Sep 10, 2010 07:10 AM
