Old May 09, 2008, 11:30 PM
Dayton, Ohio
Joined Mar 2008
Help ?
Just purchased a dg1000 from HL has anyone put a tow hook on, and if so approx. where did you place it? I'm looking to highstart launch mine, not many hills!
hvyjet is offline Find More Posts by hvyjet
Old May 10, 2008, 12:09 AM
Big Nuts 181's Avatar
Joined Jul 2004
right infront of the retract is safe
Big Nuts 181 is offline Find More Posts by Big Nuts 181
Old May 10, 2008, 02:48 AM
willhaney's Avatar
Fountain Valley, California
Joined Feb 2004
Ditto.
willhaney is offline Find More Posts by willhaney
Old May 10, 2008, 10:19 AM
Nothing like a good WOODIE!
cooper998's Avatar
USA, DE, Newark
Joined Jun 2005
If the DG1000 I am thinking of from HL is the one in the picture then you will need to set it up differently since there is no retract in the plane. Search for the thread on the DG1000 in this forum and you will see some of the weaknesses in the plane. Its fine for sloping or conversion to "E" power but the wing rod may be a weak point when using a high start.
As far as location of the hook, I would suggest 1/4" in front of the cg and watch the wing flex as she's going up. If the wing is flexing too much the stock carbon wing joiner will snap (yeah I snapped a couple) and even a steel joiner will bend(been there done that too). While I did not use a high start I did winch it once which required a lot of pumping on the pedal to keep from folding the wing.
Let us know how you make out,
Cooper998
I should have looked myself, the link is right here
cooper998 is offline Find More Posts by cooper998
Old May 10, 2008, 08:23 PM
Dayton, Ohio
Joined Mar 2008
Thx guys for the help, I've read all 19 pages on the build blog saw 1 photo of hook but no hints as to were it was put. I will keep posted on the launch.
Old May 11, 2008, 06:51 AM
The Far East
Joined Jan 2006
Tow hook location
I made a dual tow hook setup on my first DG1000. Each tow hook was placed about 5 mm behind LE and 15 mm or so below the wing. This setup was chosen to ease the load on the wing, at the cost of launch height. This is a scale sailplane, and NOT a competiotion thermal sailplane. I can't provide you with accurate measurements because I no longer have that fuse. With the carbon rod, yes, launches can be quite exciting, with the wing flexing upwards. Dont even think about pulling up elevator. Then, you might end up trying to control a lawn dart.
suirendoujin is offline Find More Posts by suirendoujin
Old May 11, 2008, 01:08 PM
ToniGe23's Avatar
United Kingdom, London
Joined Jun 2005
Hi,
I would not recommend fitting a Tow Hook anywhere near a retract the structure will not be strong enough.
For a Scale ship use the bridle method it's by far the best and safest.
With the bridle system the plane will not wonder on launch as a single tow hook will as it will pivot on the hook
http://www.soaringissa.org/Reference...inchLaunch.htm
Tony
ToniGe23 is online now Find More Posts by ToniGe23
Old May 11, 2008, 06:03 PM
The Far East
Joined Jan 2006
I should have said "bridle set up", instead of "dual tow hook setup" in my previous post. If you look through the other thread, I have loaded few images of how I did it with my DG1000.
Old May 13, 2008, 04:41 AM
Joined Jul 2004
Originally Posted by ToniGe23
Hi,
Tony
works for me....
Old May 16, 2008, 07:58 PM
Electric Airplane Junkie
bhchan's Avatar
San Mateo, Ca , USA
Joined Jun 2000
see pict, towhook on the 15 down line.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
