Old Nov 14, 2006, 01:56 PM
Colorado
Joined Oct 2002
'C' - rating of older blue-stripe Thunder Power ?
the pack is 2 or 3 years old. 2x1300 TP. and the label does not
say what the C-rating is.
i need to know if it can run a himax 2015-5400 .
also do you know how the individual cells are connected
together ? are the tabs spot welded ?
or are they soldered ?
i have a few packs with one bad cell each. and want to
combine the good ones into a 3-pack. only i dont know
how the cells are connected together electrically.
bw
barb wire is offline Find More Posts by barb wire
Old Nov 14, 2006, 02:07 PM
dave morris's Avatar
orlando fl
Joined Oct 2000
back when they were new, 5-6c max. Not enough info on your setup, besides since the cells are not new, even if we knew the answers on your setup who knows if those old used cells are good for even 5-6c (prob not). Your better off just buying some off brand cells, easy to get 5-6c performance on cheap packs.
dave morris is offline Find More Posts by dave morris
Old Nov 14, 2006, 05:15 PM
phillyphly
e-guru's Avatar
United States, PA, Philadelphia
Joined Sep 2005
Not worth it. The cells are just plain too old. If you're trying to save money think about the cost if your whole plane strikes earth because your batts couldn't keep up!
e-guru is offline Find More Posts by e-guru
Old Nov 14, 2006, 07:40 PM
Pasadena, CA
Joined Jun 2003
As if you can't bench test it. Sheesh!
derway is offline Find More Posts by derway
Old Nov 14, 2006, 07:46 PM
turn, turn, turn.
Athol, Massachusetts
Joined Oct 2005
Blue stripes are good for the museum. I keep one 1900 3s pack around just for kicks. Just like I keep old t-shirts around...to remind me where I've been.
Kenny Sharp is online now Find More Posts by Kenny Sharp
Discussion Thunder power C rating mtbrider Batteries and Chargers 8 Aug 28, 2006 08:00 AM
C rating on older thunder power packs? cmosfet Batteries and Chargers 3 Feb 10, 2005 10:03 PM
Thunder Power Gen 1 C rating SammyB Batteries and Chargers 8 Jan 20, 2005 06:56 PM
wtb: your older 3 cell thunder power 1250 packs snowfallonme Aircraft - Electric - Airplanes (FS/W) 2 Jul 25, 2004 10:03 PM
What is the C rate for a Thunder Power.... bobbddd Batteries and Chargers 3 May 27, 2004 08:48 AM
