Old Mar 05, 2014, 09:02 PM
Don't take any wooden nickels
finguz's Avatar
United States, CA, San Diego
Joined Mar 2012
Question
Solvent? For removing paint from windows of rc car body to make clear
I have a rc car with a lexan body, painted (silkscreened?) from the inside, with a sticker on the outside. The actual body is for an Axial Ridgecrest.
What I want accomplish is clear windows, by removing the sticker & maybe removing the paint from the inside. Is there something I can put on the paint that will remove the paint but not hurt the plastic, leaving the window clear? I could sand it, but it wouldn't end up very clear. Any ideas?
finguz is offline Find More Posts by finguz
Last edited by finguz; Mar 06, 2014 at 11:13 PM. Reason: removed repeated sentence, more coherent
Old Mar 06, 2014, 10:16 PM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
If you have a scrap of the body you could try some different solvents like acetone of lacquer thinner. Actually sanding could be a solution. Use 1000 grit or finer and then spray a clear paint on the window. It will turn clear again.. I've used worn out 600 grit with good results also. Just be sure to sand with water to lube the sandpaper.
Ken
kenh3497 is offline Find More Posts by kenh3497
Old Mar 06, 2014, 11:08 PM
finguz's Avatar
Joined Mar 2012
Ken
I recently used a similar process to sand the old graphics off the inside of a lexan rear wing for a 1/24 car. Except I just sanded it with fine grit, painted it & sealed the paint with clearcoat. The point is, the color looks great through the topside of the spoiler with no scratches just nice a solid color.
On the Ridgecrest body I think I'm going to try like you are saying by sanding and clear coat. I hope the clear coat doesn't yellow over time.
Thank you. I'll post it up here if it turns out.
Old Mar 09, 2014, 07:30 PM
"Take Off" eh!
vettster's Avatar
Canada, ON, Beeton
Joined Aug 2008
Use Spray on Oven Cleaner. Wont hurt the plastic and will remove all the paint. Be cautious though... first dab a bit on an inconspicuous area.
vettster is online now Find More Posts by vettster
Latest blog entry: 3DTRYER ripped me off!!!
Old Apr 06, 2014, 01:55 AM
Joined Jan 2011
Testors ELO. It's made to do just that on plastic. Albeit a little pricey.
LAR43 is offline Find More Posts by LAR43
Old Apr 08, 2014, 03:53 PM
finguz's Avatar
Joined Mar 2012
I actually ended up using the sanding/clearcoat method, I forgot to give an update how it worked out. I think it works pretty good actually. But my problem was that I used a leftover can of clearcoat, and it splattered instead of spraying. So I said what the heck, so I laid the splatter on thick and went with it. It's a little thick, so it's not perfectly transparent, but it's decent with things close to the window itself but forget looking through to the next window. I think it would've worked out better with a good can of clearcoat.
I would definitely be interested in trying the other 2 methods listed in this thread. I still have another trekker body to experiment with, and a few other bigger bodies I'd like to do also.
Old Apr 08, 2014, 03:55 PM
finguz's Avatar
Joined Mar 2012
vettster, how long do you leave the cleaner on for?
LAR43, I'll look into that stuff. It might be worth it for me to just start over with a clear body if the stuff is too pricey.
Old Apr 17, 2014, 11:07 PM
Joined Jan 2011
It's about 10.00-12.00 a pint but it goes a long way.
Old Apr 18, 2014, 08:33 AM
Ochroma Lagopus Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
DO NOT use acetone or any type of thinner on polycarbonate! Thinners will at the very least haze up the plastic, and acetone will reduce it to a puddle of nondescript goo.
Fly Wheel is offline Find More Posts by Fly Wheel
Old May 09, 2014, 01:42 AM
Joined Aug 2013
Automotive Brake Fluid works the best. I will also remove the stickers on the out side of the body.
fcox04 is offline Find More Posts by fcox04
Old Sep 24, 2014, 12:05 AM
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
It has to be a particular number DOT brake fluid, can't remember which number off hand but the videos are all over Youtube.
North_of_49 is offline Find More Posts by North_of_49
Latest blog entry: HobbyZone Sport Cub S BNF
Old Sep 24, 2014, 01:37 PM
finguz's Avatar
Joined Mar 2012
I've heard a lot about oven cleaner more than anything else. But I'll look up the brake fluid on youtube.
I still haven't done any of my other rc's windows, but I'm getting ready to do my other trekker body so maybe I'll try a few different things on it. With solvents my only worry was that it might soak into the masking tape and maybe ruin the whole body.
Discussion solvent to remove double stick foam firehorse The Builders Workshop 11 Dec 08, 2013 02:26 AM
Wanted WANTED: I need a good custom rc car body painted for me Offroadrc4x4 Cars - Cars and Parts (FS/W) 0 Apr 25, 2013 04:28 PM
Discussion Easiest way to remove paint from car body? ronmeister Car Talk 4 Jun 29, 2010 01:37 AM
Discussion Best way to remove old paint from lexan body? SlowDriver Off-road Cars 8 Feb 22, 2006 02:53 PM
Clear windows for scale body. ticketec Scale Helicopters 10 Aug 01, 2005 06:54 PM
