Old Aug 24, 2014, 06:32 PM
Electric
Joined Oct 2009
I actually used a Dremel cutting disc to grind a perfect cut around the shaft and used the c-ring there.
DeadstickDuck is online now Find More Posts by DeadstickDuck
Old Aug 24, 2014, 06:35 PM
United States, WI, Fond du Lac
Joined Sep 2011
I'm thinking about pulling the whole shaft out and reversing it and then I shouldn't need a collar????
racerboy65 is online now Find More Posts by racerboy65
Old Aug 24, 2014, 07:12 PM
Joined Sep 2011
Never mind brain fart. Haha
Old Aug 24, 2014, 09:03 PM
Joined Jan 2013
Originally Posted by ChinoDiablo View Post
I cut a couple of little holes in the fuse and zip tied the motor leads to the inside so they would stay out of motor can's way.
Post 427 pic
9Mach is offline Find More Posts by 9Mach
Old Aug 24, 2014, 09:24 PM
Electric
Joined Oct 2009
I think that's the best way so far.
Old Aug 25, 2014, 01:15 AM
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Originally Posted by barracudahockey View Post
Kings, I'm just messing of course but I bet you knew that
I know. I'm taking mine out later this morning for a little more fun myself.
Originally Posted by Vintauri View Post
.... However it did put the Kunai on the back burner to getting finished. Something I need to remedy this week!
Steve
ASAP and you'll be glad you did. Only problem I had was wiping the smile off my face after each flight. Big Grins all around when the Kunai flies.
McD
kingsflyer is offline Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Aug 25, 2014, 03:23 PM
Faster is Better
OldeMan's Avatar
United States, AZ, Gilbert
Joined Jul 2012
Just a quick build-note: I was flying my Kunai a weekend ago, and was surprised to see something pop off and tumble to the ground. I immediate chopped throttle and glided in for a landing... no problems. It turned out to be the stock spinner/prop assembly that popped off of the motor shaft -- the grub screws that pinch the shaft had come loose. Not something I had thought to check, during the build, because it was factory attached.
If you are using the stock spinner/prop assembly, unscrew the spinner and double-check those grub screws.
OldeMan is offline Find More Posts by OldeMan
Old Aug 25, 2014, 03:31 PM
Electric
Joined Oct 2009
I took my spinner off last night after 20 flights on my #2. The grub screws were still holding but not as tight as they had been. Might want to file a flat and use locktite.
Old Aug 25, 2014, 03:38 PM
Faster is Better
OldeMan's Avatar
Joined Jul 2012
Originally Posted by DeadstickDuck View Post
... The grub screws were still holding but not as tight as they had been. Might want to file a flat and use locktite. ...
Probably a dozen flights on mine, by the time this happened.
You know, I was more than a little surprised the shaft didn't have a flat-landing for the grub screws. Your right, time to break out the dremel.
Old Aug 25, 2014, 03:41 PM
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Hmm my Kunai didn't ship with the prop adapter or spinner on the shaft. It's installed towards the end of the manual. I'll be sure to check for a flat spot and dremel one on if needed.
Vintauri is offline Find More Posts by Vintauri
Old Aug 25, 2014, 03:55 PM
Electric
Joined Oct 2009
Both of my stock motors have smooth shafts and came with their spinners disassembled in a bag.
Old Aug 25, 2014, 04:09 PM
Faster is Better
OldeMan's Avatar
Joined Jul 2012
Uh-oh... my memory may be faulty, then. Certainly no intention of bad-mouthing Great Planes -- I love my Kunai. Either way... those grub screws came loose after a dozen flights, and it's worth checking.
Old Aug 25, 2014, 06:24 PM
Joined Sep 2011
Well I found a collar and have motor installed. Still really concerned about the wires rubbing. I hate to have a zip tie in there but I guess I may have to do it.
Old Aug 25, 2014, 07:11 PM
Electric
Joined Oct 2009
Just align the motor screws so the wires are on the side behind a scoop.
Old Aug 25, 2014, 09:57 PM
Joined Sep 2011
That's where I have them. I have it all together will remainden tomorrow.
For Sale DG808S 4m/157'' Glider ARF For $269 richyan Aircraft - Electric - Airplanes (FS/W) 1 Apr 25, 2014 01:38 PM
Discussion Video - FPV perspective during aerobatics with a 4m glider mustang_jmz FPV Talk 5 Jan 10, 2014 10:55 AM
Discussion Venturi new 4m glider by CBmodélisme CBmodelisme Sailplane Talk 5 Oct 14, 2013 12:12 PM
Sold 3-piece DB9 Wing Wiring Harness for 3M to 4M Glider TDboy Aircraft - Sailplanes (FS/W) 0 Sep 26, 2013 01:47 AM
Discussion 4m Glider - Electric Upgrade KarbonBird Electric Plane Talk 3 May 23, 2009 11:09 PM
