Old Jan 12, 2014, 09:32 AM
Joined Jan 2014
HK-450TT PRO V2 Flybarless 3D Torque - Which servos
Hi,
I'm building a HK-450TT PRO V2 Flybarless helikopter, and don't know which servos to choose.
My other parts are:
- Motor: Scorpion Scorpion HKII-2221-8 (12T pinion)
- ESC: Scorpion Commander 15V 45A ESC SBEC (V3)
- Receiver: Spektrum AR7200BX
My budget for all 4 servos is around 150€ ($200).
I think, that for cyclic servos, I'm going to use the Hitec HS-5065MG or does anyone suggest something else.
UFOking is offline Find More Posts by UFOking
Old Jan 13, 2014, 10:25 AM
JesseFDB's Avatar
Belgium, Flanders, Lanaken
Joined Dec 2013
I've gone for the same cyclic servos, after hearing a lot of good things about them (no first hand experience yet).
For tail I went for Align DS525M. If your budget is bigger, you could consider MKS DS8910A+. Cheaper option would be Turnigy TGY-306G(-HV) but it's smaller and will require an adapter piece. Also might wanna open it up and insulate the inside of the metal casing.
JesseFDB is offline Find More Posts by JesseFDB
Old Jan 13, 2014, 10:49 AM
Joined Jan 2014
Thanks JesseFDB!
What about the Futaba S9257 for tail?
How would it work in combination with the AR7200BX receiver?
Or maybe MKS DS9670A+ http://www.hobbyking.com/hobbyking/s...56&aff=1295381
Old Jan 17, 2014, 09:00 PM
just gotta mess with it!
2Doggs's Avatar
North West Louisiana
Joined Nov 2009
The Futaba 9257 has to run at 4.8v. It's OK - it used to be one of the best tail servos - but I think the Turnigy 306G is even better, and it works great on cyclic on a 450 Pro. If you like, you can get the MKS version for a lot more. Having to use an adaptor on the tail servo mount is no big deal.
The Hitec servos would be fine on cyclic, but they're not as fast as the 306. I use a Hitec 5084 on one of my 450 tails, and it's not quite as good as a 306.
To be honest, I'd prefer an ESC with 6v or even 7.2v output options, and more than a 3A BEC. The YGE 45A is good, with a great governor mode and strong 5.5v 6A SBEC or you can pay a lot less for the YEP 45A, along with the program card.
2Doggs is offline Find More Posts by 2Doggs
Latest blog entry: Nano Tech 1800mah 4S 25-50c
Discussion HK-450TT PRO V2 or CopterX 450 pro? Advice needed. carl1864 Electric Heli Talk 5 Nov 09, 2013 07:49 PM
For Sale HK-450TT PRO V2 3D Torque-Tube with futaba 7cap conversion to 2.5 fathallah2 Aircraft - Electric - Helis (FS/W) 0 Dec 30, 2012 03:27 PM
For Sale HK-450TT PRO 3D Torque-Tube Helicopter Kit adrenahelin Aircraft - Electric - Helis (FS/W) 0 Nov 04, 2012 10:42 PM
Discussion HK-450TT PRO V2 Flybarless 3D Torque-Tube Helicopter Kit a2j812 Electric Heli Talk 4 Sep 29, 2012 12:23 PM
Discussion HK-450TT PRO 3D Torque-Tube caliero Mini Helis 166 Jul 29, 2010 03:37 AM
