Old Jul 12, 2013, 10:09 PM
Joined Jul 2013
good body filler?
hey guys,
new to nitro. Im doing some repairs after a crash and am wondering what makes a good flier that can still be covered by monokote? will bondo work or something hobby specific? just need to fill in some seems.
dirtbikinginger is offline Find More Posts by dirtbikinginger
Old Jul 12, 2013, 11:23 PM
Arceenut's Avatar
Canada, BC, Langley
Joined Nov 2007
Bondo is pretty heavy. Try the paint stores and weigh the tubes of hole fillers in your hand, then pick the lightest one. My choice is Spackle.
Arceenut is offline Find More Posts by Arceenut
Old Jul 13, 2013, 10:03 AM
team sleprock
whiskykid's Avatar
United States, WA, Port Angeles
Joined Dec 2009
Reddevil spackle what I use, quick dry and sands easley
whiskykid is offline Find More Posts by whiskykid
Latest blog entry: great day!
Old Jul 13, 2013, 11:12 AM
St Helens, Oregon
Joined Oct 2007
Spackle !!!! Clean up using water.
weswanson is offline Find More Posts by weswanson
Old Jul 13, 2013, 11:25 AM
The Prez....... again
kenh3497's Avatar
United States, IA, Rockwell
Joined Jul 2011
Lightweight spackle. There is a "heavy" version that is not really suitable for model use. you'll know you have the right one when you pick up the container and it feels empty.
kenh3497 is offline Find More Posts by kenh3497
Old Jul 13, 2013, 02:26 PM
Space power
cfircav8r's Avatar
United States, IA, Hampton
Joined May 2012
+1 on the lightweight spackle, but if you need strength as well then epoxy with micro balloons will be better.
cfircav8r is offline Find More Posts by cfircav8r
Old Jul 13, 2013, 04:42 PM
Joined Jul 2012
Beer...
On the model though, if strength is no issue- lightweight spackling compound from the hardware store. Otherwise epoxy and microballoons.
JKinTX is offline Find More Posts by JKinTX
Old Jul 13, 2013, 06:13 PM
Atl, Ga.
capt kurt's Avatar
Joined Dec 2012
I found FastWeld to work very well..... It hardens very well, is easily sanded and can be tapped and threaded if needed.
Hope this helps...
capt kurt is offline Find More Posts by capt kurt
Old Jul 15, 2013, 10:20 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
light weight model filler
magic model filler and DAP light spackle are, as far as I can tell, the same thing It is a non shrink spackle and that is important. Can be made rock hard with thin CA AFTER it dries.
Gorilla Glue can be used with or without Micro balloons. Wetting helps it expand more and set up faster. I prefer the WHITE stuff.
OR go old school and mix a bit of balsa dust with elmers or wood glue.
It does make a color matching patch on balsa.
ozmo01 is offline Find More Posts by ozmo01
Old Jul 22, 2013, 07:03 PM
Joined Nov 2012
I like lead fillings mixed with concrete
Machzx is offline Find More Posts by Machzx
Old Aug 08, 2013, 09:42 PM
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
Concrete dust is harmful, so is lead. Lead especially at very high speeds
such as greater than 1000' per second
Magic model filler and Spackle light weigh less than balsa when dry though
Old Aug 09, 2013, 04:47 PM
Canada, ON, Cottam
Joined Jan 2012
There is also a lightweight Bondo but I can't say for sure if the iron on films would stick or not. It would depend on the application. I don't use fillers much. Doublers on some repairs.
aspeed is online now Find More Posts by aspeed
Old Aug 09, 2013, 08:17 PM
Joined Jul 2012
You can use corn starch also instead of the balsa dust. Mix in glue or dope as needed to proper thickness.
Old Aug 10, 2013, 09:06 PM
United States, FL, Chuluota
Joined Jul 2013
Anyone ever used clear dope and baby powder. Makes excellent grain filler and sands nice. Not for filling holes, though.
bobmrbassman is offline Find More Posts by bobmrbassman
Discussion Good filler for EPP foam DYORD Painting and Finishing Tips 5 Feb 12, 2013 08:01 PM
Discussion Body (balsa) filler fmhans Scratchbuilt Indoor and Micro Models 2 Mar 17, 2010 08:49 AM
Discussion sanding "USC Icing" body filler safety question... Picoflyer Composites Fabrication 12 Apr 08, 2007 01:02 PM
Help! Body filler for GWS Foam catboater Foamies (Kits) 2 Apr 18, 2005 10:34 PM
body filler recommendation gologt GWS (Grand Wing Servo) 7 Mar 16, 2004 08:54 AM
