Old Feb 17, 2013, 05:51 AM
Joined Dec 2004
6.7geared motor: front bearing replacement
Hi All,
I've got a 1509/1Y with 6.7-P32 gearbox. The front bearing of the rotor feels gritty, so I'd like to replace it.
However, this bearing is lodged between the rotor and the pinion. Is there anyway I could replace this bearing myself?
Gerben
Gerben is offline Find More Posts by Gerben
Old Feb 23, 2013, 09:35 AM
sneu's Avatar
United States, CA, San Diego
Joined Dec 1999
Originally Posted by Gerben View Post
Hi All,
Gerben
I assume your motor does not have a spacer between the gear box and the motor housing? If so the following applies.
In the older motors(3 years or older) the front bearing can not be replaced since the gear was larger than the shaft. The only solution is to install the new style which has a 6mm shaft and bearing. With the 6mm shaft the gear is smaller than the ID of the bearing. Contact us and we can get you a new rotor and bearings. Lisa Talia <ltalia@neutronics.com> can help get you the parts.
Steve Neu
sneu is offline Find More Posts by sneu
Old Feb 25, 2013, 02:00 PM
Joined Dec 2004
Hi Steve,
Sounds right, the motor is probably older than 3 years, and it's a 'short' motor without spacer.
Bit unfortunate to hear it needs a new rotor. I only bought this motor to pass it on to someone interested to start in F5B. The new rotor will probably make this second-hand option less interesting financially, but I'll contact Lisa and see what she comes up with.
Many thanks, best regards from the Netherlands,
Gerben
Old Feb 26, 2013, 08:04 AM
sneu's Avatar
Joined Dec 1999
Often bearings making noise will run along time with out problems. check for radial play--if it is still good then it could run many more flights.
Steve
Discussion Hyperion ZS4045 bearing replacement jackosmeister Power Systems 1 Feb 17, 2013 05:34 PM
Idea Motor shaft replacement, custom shafts, and bearing replacement service scatsob Electric Motor Design and Construction 14 Aug 01, 2012 06:19 AM
Found Wanted: front bearing from PZ vapor motor box mikeythev Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Dec 14, 2010 09:32 PM
Discussion MPJet inrunner : How to open the motor for a bearing replacement? Bare Power Systems 7 Dec 27, 2008 04:39 PM
Help! How do I Replace front bearing? Sir-Ipswich Car Talk 2 Jul 14, 2007 02:16 AM
