Old Jun 11, 2012, 05:34 PM
Joined Sep 2010
Backlight for Title Description on FPV Ground Station
Hi guys, i will start build my ground station next month, i would like to have led iluminated description title for each switch toggle function, but i dont know how can i do it,
For example, switch toggle for power on/of lcd, in title description under switch toggle i will have led illuminated title description: LCD Power,
See if it will work:
I will buy transparent acrylic, then i will use led backlight under acrylic (http://www.alibaba.com/product-gs/46...backlight.html)
and over acrylic i will have carbon fiber vinyl electronic cutted letters (LCD Power for example)
Link for Carbon Fiber Vinyl: http://www.ebay.com/itm/2D-High-Glos...ht_1937wt_1163
This will work ? I need these backlight, or can i simple put white paper with leds under acrylic that i will have same effect ?
Can somebody help me with it ? Thanks for all
felipesalomao is offline Find More Posts by felipesalomao
Old Jun 12, 2012, 07:44 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
I did something similar and used white paper with a light behind it and it worked great. Otherwise, you can sand the acrylic to get a diffused effect for the light and not need the paper. sand the back side of the acrylic so the top that you see will still be glossy.
techspy is online now Find More Posts by techspy
Latest blog entry: My Esprit Saga
Old Jun 13, 2012, 01:25 AM
Joined Sep 2010
Do you know if this 2D Gloss vinyl passes light (translucent) or not, because i will have to cut titles text and it have to block backlight, do you have photo of your groundstation updated with backlight ? Thanks !!!
Discussion Show Us Your Ground Station !!!! FPV Ground Station Design and Idea's found here :) JettPilot FPV Equipment 4098 Yesterday 05:03 PM
Sold GROUND STATION for FPV and UAV flying & 7" Monitor: TBello FPV Equipment (FS/W) 9 Mar 20, 2012 06:48 PM
Sold Complete FPV Kit Ground Station for any plane. crd FPV Equipment (FS/W) 2 Mar 13, 2012 11:01 PM
Discussion where to get cheap foam for fpv ground station? g3f0rc3 FPV Talk 4 Mar 08, 2012 03:25 AM
Discussion Best 15"-19" Monitor for my FPV Ground Station tvedit FPV Talk 7 Dec 13, 2011 07:24 PM
