Old Jan 23, 2012, 12:42 PM
DS will change your life
SpeedsterDEN's Avatar
Danmark, Nordjylland, Sæby
Joined May 2010
Spektrum DX 7 and 8 Glider set up.
Hi DX7 and DX8 glider pilots
If you have problems to set the DX7-8 up for 4 servo wing gliders.
I use this on my Vector lll and the F3J Trinitus glider on the DX7
and the Flyfly FOX on the DX8
Works great.
6 ch Reciver
The flaps are on the thottle stick.
When you use the elevator, the flaps is also mooving (snapflaps)
When you use the flaps, the elevator compensate. (for elevator trim)
When you use the ailerons, the flaps are also mooving as aileron.(all wing aileron)
Spoilers (up aileron, are on the flt mode switch) So full crow brake are possible if full flaps dont give enough braking.
My set up is:
wing setup is flapperons.
Aileron servos are in Aile and Aux
Flaps servos are in thro and gear.
The % in the mixing, are the settings I using in my Vector lll DX7, and may not be the perfekt setup you have to use in your glider, but it will be very close.
Max throw/ reversing/ subtrim, will change the % and +/ - set up
Mix 1
thro/gear +58% +88% This make the gear flap go with the thro flap.
(in the mix you have to offset the gear +125%)
Mix 2
aile/gear +23 +19 offset +11 This make the gear flap go as aileron
Mix 3
Aile/thro -18 -25 This make thro flap go as aileron.
Mix 4
Elev/thro +36 +24 This make the flaps go as Snapflaps
Mix 5
Elev/gear +36 +33 This make the flaps go as Snapflaps
Mix 6
Thro/elev 0 - 36 This give the elevator a bit down, when using the flaps.
Spoilers,
Are in the FLAP system MIX
Norm UP100% DH44% Spoilers Aileron up with elevator trim
land 0 0
Land 25% 0% termal flying
And if you also want the ailerons go as snapflaps, you can mix it in the Elev/flap MIX
And when using a 6 ch rx, the towing coupling are on a y lead together with the thro (OR GEAR, if it goes the wrong direction), so when giving full flaps I release the tow.
Good luck
S
RC glider, termal and aerobatic. (1 min 58 sec)
Towing the Vector lll (2 min 8 sec)
SpeedsterDEN is offline Find More Posts by SpeedsterDEN
Old Jan 24, 2012, 11:13 AM
No risk, no fun
Siggy101's Avatar
Switzerland, VD, Chéserex
Joined Jan 2011
Nicely done Speedster, I shall see where I get stuck with the new project and will no doubt be back on here all confused!!
Can you just confirm which aileron you plug into the aileron port, left or right?
Siggy101 is offline Find More Posts by Siggy101
Old Jan 24, 2012, 02:45 PM
Joined May 2010
Normaly, right aileron. But thats no problem.
Questions, you just ask.
Old Jan 24, 2012, 02:58 PM
Joined May 2010
explanation
Peewhit gave this explanation.
Spektrum DX7 Program For Four Servo Wing
Gives flaps linked to ailerons for increased roll rate, ailerons linked to flaps for full wing camber, and crow braking (using the throttle stick) with elevator compensation.
This program is based upon setting the ailerons as flaperons
The instuctions are for a 6 channel receiver.
If using a 7 channel receiver you can substitute Aux2 for GEAR which then leaves the GEAR channel free.
Please note that the programmable mix numbers used MUST be exactly as stated, as 5 and 6 give a different effect to 1,2,3, and 4
Ailerons
Enable flaperon mixing
Right aileron to AIL channel
Left aileron to AUX1 channel
Flaps
Disable gear switch by setting gear servo travel to 0%,0%
Right flap to GEAR channel
Left flap to THROTTLE channel
Set up PMIX5 as THROTTLE master to GEAR slave with setting of 100%,100%
This links both flaps together.
Crow braking
PMIX1 throttle master to elevator slave for crow braking elevator down compensation.
Rates are top 0%, bottom – whatever you need for your required down elevator compensation.
Offset value +100%. This sets the “mid point” of the throttle to stick full up and crow is activated by pulling the throttle stick down.
PMIX2 throttle master to flap slave. As the ailerons are set up as flaperons, the flap channel controls the ailerons as flaps. This gives both ailerons up movement for crow braking.
The throttle stick drives the left flap directly and as the flaps are linked by PMIX5, both flaps will move when the throttle stick is moved.
Full wing camber
The ailerons are set up as flapperons – use the flap system setting for the correct amount of camber and reflex, operated by the 3 postion flap switch.
Set the aileron travel first.
PMIX3 flap master to throttle slave this is the flap movement for camber and reflex.
As the flaps are linked by PMIX5, both of them will move.
Flaps moving with ailerons
PMIX4 aileron master to gear slave – moves right flap with ailerons.
PMIX6 aileron master to throttle slave – moves left flap with ailerons.
Old Feb 05, 2012, 07:18 AM
No risk, no fun
Siggy101's Avatar
Joined Jan 2011
Deleted
Last edited by Siggy101; Feb 05, 2012 at 07:59 AM. Reason: I didn't read properly!
Old Mar 24, 2012, 08:15 PM
Screamin' fast!
CrazyJB's Avatar
United States, CA, San Jose
Joined Nov 2011
I'm looking for this same info... ECCEPT I need throttle to be on the throttle.
Any help?
Thanks! -Joel
CrazyJB is offline Find More Posts by CrazyJB
Old Jul 13, 2012, 04:30 PM
Joined May 2010
DX8, 4 flap wing set up
My DX8, 4 flap wing set up
DX8. 4 flap wing Glider setup. (6 min 27 sec)
Old Jul 14, 2012, 03:04 AM
Joined May 2010
Failsafe
Program the failsafe on Orange 7 ch RX (1 min 28 sec)
Works for Orange 7 ch and many Spectrum rx
Help! Spektrum DX-7...setting up flaps Captain Ron Radios 19 Oct 12, 2011 10:05 PM
Discussion DX-7 set up for rudderless flying edwink Hand Launch 0 Oct 03, 2009 02:18 AM
Discussion DX-7 Set-up air4prs Radios 2 Feb 14, 2008 08:40 AM
Discussion DX-7 / V-tail set up CV580drvr Electric Sailplanes 2 Jan 03, 2008 05:45 PM
Discussion Need advice on set up of DX-7 H.Robinson Radios 3 Jul 22, 2007 11:12 AM
