Old Dec 30, 2011, 01:18 PM
UlteriorModem's Avatar
Joined Aug 2011
What kind of current..
Does the typicall parkzone use?
For example an 8.5mm coreless brushed with 4 channels and three of their servos?
Im just wondering because I am hard pressed to get more than 3 minutes out of a 150mah battery.
I guess I should add but should be self evident that they use 1S batterys.
UlteriorModem is offline Find More Posts by UlteriorModem
Old Jan 01, 2012, 04:19 AM
Pilot, Co-pilot, Navagator
nemoskull's Avatar
United States, AZ, Yuma
Joined Sep 2009
3 mins is terrible. is the battery old? you should get a bit more than that at worst.
try HobbyKing Nano. 130's are the same weight, 160s are a bit more. rated at 25C and worth it. hyperions 160 would be better still, but try the nano's night and day better than stock.
the stock 8.5mm on a stockish prop draws in the 1.2 to 1.5 amp area. dont know more than that
nemoskull is offline Find More Posts by nemoskull
Old Jan 01, 2012, 04:54 AM
Have fun
airpower's Avatar
Joined May 2007
3 mins could be, your gear box is rough and sapping power, the battery is almost dead (either from use, incorrect storage or over discharge), it's really cold, the battery may not be fully charged(the light has to blink once every ten seconds, some fly the battery after the charger starts flashing, which is really just a bit more than half charge), or your at full throttle all the time( if it's old, it could be combo of worn motor and worn battery)
airpower is online now Find More Posts by airpower
Discussion What kind of servos are best? papabearflying Electric Plane Talk 11 Oct 16, 2011 02:18 PM
Question What Kind Of Weight Can A 15 Size Engine Handle? NEW222 Engines 16 Oct 13, 2011 05:27 AM
Question What kind of performance from this D99 Setup? AEMontoya High Performance 2 Sep 21, 2011 02:30 PM
Discussion What kind of tool would I use to shorten the servo arms by just a little? AndrejaKo Coaxial Helicopters 5 Sep 19, 2011 03:26 PM
Discussion What kind of antenna should I get PeeMax FPV Talk 11 Sep 07, 2011 07:38 AM
