Old Sep 26, 2011, 09:12 PM
in memory of dez RIP
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
Careful!
if you are new to lipos its a must read !!!
Important Safety Instructions And Warnings
WARNING: Please read before charging or using any Lithium battery
• You must read these safety instructions and warnings before using or charging your batteries.
• Lithium Polymer batteries are volatile. Failure to read and follow the below instructions may result in fire, personal injury and damage to property if charged or used improperly.
1) Use specific Lithium Polymer charger only. Do not use a NiMH or NiCd charger - Failure to do so may a cause fire, which may result in personal injury and property damage.
2) Never charge batteries unattended. When charging LiPo batteries you should always remain in constant observation to monitor the charging process and react to potential problems that may occur.
3) Some LiPo chargers on the market may have technical deficiencies that may cause it to charge the LiPo batteries incorrectly or at an improper rate. It is your responsibility solely to assure the charger you purchased works properly. Always monitor charging process to assure batteries are being charged properly. Failure to do so may result in fire.
4) If at any time you witness a battery starting to balloon or swell up, discontinue charging process immediately, disconnect the battery and observe it in a safe place for approximately 15 minutes. This may cause the battery to leak, and the reaction with air may cause the chemicals to ignite, resulting in fire.
5) Since delayed chemical reaction can occur, it is best to observe the battery as a safety precaution. Battery observation should occur in a safe area outside of any building or vehicle and away from any combustible material.
6) Wire lead shorts can cause fire! If you accidentally short the wires, the battery must be placed in a safe area for observation for approximately 15 minutes. Additionally, if a short occurs and contact is made with metal (such as rings on your hand), severe injuries may occur due to the conductibility of electric current.
7) A battery can still ignite even after 10 minutes.
In the event of a crash, you must remove battery for observation and place in a safe open area away from any combustible material for approximately 15 minutes.
9) If for any reason you need to cut the terminal wires, it will be necessary to cut each wire separately, ensuring the wires to not touch each other or a short may occur, potentially causing a fire.
10) To solder a connector: Remove insulating tape of Red wire and solder to positive terminal of a connector, then remove insulating tape of Black wire and solder to the negative terminal of connector. Be careful not to short the wire lead. If you accidentally cause the battery to short, place it in a safe open space and observe the battery for approximately 15 minutes. A battery may swell or even possibly catch fire after a short time.
11) Never store or charge battery pack inside your car in extreme temperatures, since extreme temperature could ignite fire.
Charging Process
1) Never charge batteries unattended.
2) Charge in an isolated area, away from other flammable materials.
3) Let battery cool down to ambient temperature before charging.
4) Do not charge batteries packs in series. Charge each battery pack individually. Failure to do so may result in incorrect battery recognition and charging functions. Overcharging may occur and fire may be the result.
5) When selecting the cell count or voltage for charging purposes, select the cell count and voltage as it appears on the battery label. As a safety precaution, please confirm the information printed on the battery is correct.
a. Example: The label on a 2-Cell battery pack in series will read – “Charge as 2-Cell (7.4V), or may cause fire” – You must select 2-Cell for charging.
b. Example: The label on a 3-Cell battery pack in series will read – “Charge as 3-Cell (11.1V), or may cause fire” – You must select 3-Cell for charging.
6) Selecting a cell count other than the one printed on the battery (always confirm label is correct), can cause fire.
7) You must check the pack voltage before charging. Do not attempt to charge any pack if open voltage per cell is less than 3.3v
Example Do not charge a 2-cell pack if below 6.6v
Do not charge a 3 cell pack if below 9.9v
You must select the charge rate current that does not to exceed 1C (one times the capacity of the battery). A higher setting may cause fire. The below chart is calculated at 1 x capacity of pack.
Example 730 mAh: Charge below 730 mA
860 mAh: Charge below 860 mA
1320 mAh: Charge below 1.32 Amps
1900 mAh: Charge below 1.9 Amps
2100 mAh: Charge below 2.1 Amps
7800 mAh: Charge below 7.8 Amps
8000 mAh: Charge below at 8 Amps
First Discharge
Keep the flight time to 6-minute sessions with 15-minute breaks.
Storage & Transportation
1) Store battery at room temperature between 40 and 80 degrees F for best results.
2) Do not expose battery pack to direct sunlight (heat) for extended periods.
3) When transporting or temporarily storing in a vehicle, temperature range should be greater than 20 degrees F but no more than 150 degrees F.
4) Storing battery at temperatures greater than 170 degrees F for extended periods of time (more than 2 hours) may cause damage to battery and possible fire.
Caring for Battery
1) Charge battery with good quality Lithium Polymer charger. A poor quality charger can be dangerous.
2) Set voltage and current correctly (failure to do so can cause fire).
3) Please check cell voltage after the first charge.
Example 1-Cell: 4.2V (4.15 to 4.22) 2-Cell: 8.4V (8.32 to 8.44) 3-Cell: 12.6V (12.48 to 12.66) 4-Cell: 16.8V (16.64 to 16.8 5-Cell: 18.5V (18.30 to 18.60)
4) Do not discharge battery to a level below 3V per cell under load. Deep discharge below 3V per cell can deteriorate battery performance.
5) Use caution to avoid puncture of the cell. Puncture of cells may cause a fire.
Operating Temperature
Charge: 32 to 113 degrees F
Discharge: 32 to 140 degrees F
1) Let battery cool down to an ambient temperature before charging.
2) During discharge and handling of batteries, do not exceed 160 degrees F.
Battery Life
Batteries that lose 20% of their capacity must be removed from service and disposed of properly.
Discharge the battery to 3V/Cell, making sure output wires are insulated, then wrap battery in a bag for disposal.
note: do not put a heavy load/amp draw on LiPos that are below 85-90F(95-100F is a 'safer' temp for FE boating). putting a big draw on them when cool/cold leads to bloating
(thanks rex r for giving additional info not listed )
this was a post from david hajj on rumrunner thanks david
if possable moderator make a sticky please
rcphreak is offline Find More Posts by rcphreak
Old Sep 27, 2011, 05:20 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
with the ammount of new users this should be a sticky !!!
Old Sep 27, 2011, 06:07 PM
Joined Oct 2008
I just leave my 1s batterys in the house dont see the point in worrying about them .
dazzzer1 is offline Find More Posts by dazzzer1
Old Sep 27, 2011, 08:42 PM
Intermediate rc plane pilot
Pimpbaa's Avatar
Joined Aug 2011
I've seen plenty of youtube videos of large multicell lipos going up in flames (more like shooting flames like a blowtorch!), but not small ones for micro helicopters. Curious as to what a single cell 120mah lipo can do.
Pimpbaa is offline Find More Posts by Pimpbaa
Old Sep 27, 2011, 09:19 PM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
if not being watched and catches fire if it is near anything flamable such as but not limited to . clothes, drapes, paper, ect..... it WILL burn your house down !!!! and or cause serious burns to yourself as we have already seen .
one cell or six cells once the chemical hits oxygen it ignites lipos should be handeld with care and caution .
i have personaly seen a lipo swell and burst from a guy simply dropping one .
in this post this clearly not his falt but a result of what can and will happen if the one cell lipo decides it wasnts to .
http://www.rcgroups.com/forums/showp...postcount=7954
Old Sep 27, 2011, 10:38 PM
Canada, AB, Edmonton
Joined May 2008
Always, always, always charge lipos in a safe container like a lipo bag. Lipos are always the most dangerous during charging. Lipo charging bags are like airbags, hope you never need them but they're there if you do and can save your life.
I keep a fire extinguisher and bucket of sand where I charge my lipos. Like lipo sacks, hope you never need them but....
Just to clarify, did you mean RUNRYDER not rumrunner? I believe rumrunner is a restaruante in the bahamas...
Druss is offline Find More Posts by Druss
Old Sep 28, 2011, 05:24 AM
rcphreak's Avatar
USA, FL, Fort Myers
Joined Jun 2008
rum runner is a electric boat forum heres a link .
http://www.google.com/url?sa=t&sourc...JJJbjfF85fdcAA
Discussion if you are new to lipos this is a must read !!! rcphreak Racing Boats - Electric 35 Aug 08, 2013 08:23 PM
Alert If you are planning on being in the Los Angeles area July 15-18, READ THIS! bjaffee Slope 4 Jun 18, 2011 10:55 AM
Discussion Very few will read this.But if you are an independent, read it and discuss! yucafrita Life, The Universe, and Politics 202 Oct 28, 2010 10:46 AM
Download If you fly E at COSTA MESA, CA flying field, you must read this or lose your field! Troy Electric Plane Talk 72 May 16, 2003 12:29 PM
If you fly E at COSTA MESA, CA flying field, you must read this or lose your field! Troy Foamies (Kits) 0 Nov 19, 2002 01:47 PM
